pc-ble-driver sd_ble_gap_sec_params_reply got error 0x10 NRF_ERROR_INVALID_ADDR
Just continue my work on implementing LESC MITM on hear_rate_collector (Please check my development environment settings here as well).
Since sd_api_v6 on pc-ble-driver doesn't work with sd_ble_gap_authenticate on PCA10059. I switched to sd_api_v3.
Then sd_ble_gap_authenticate returns OK.
Then I added sd_ble_gap_sec_params_reply as such:
diff --git a/examples/heart_rate_collector/main.c b/examples/heart_rate_collector/main.c
index 3ee6c9c..8aa379a 100644
--- a/examples/heart_rate_collector/main.c
+++ b/examples/heart_rate_collector/main.c
@@ -104,6 +104,15 @@ enum
 #define STRING_BUFFER_SIZE 50
+#define SEC_PARAM_BOND                      1                                 /**< Perform bonding. */
+#define SEC_PARAM_MITM                      1                                 /**< Man In The Middle protection not required. */
+#define SEC_PARAM_LESC                      1                                 /**< LE Secure Connections enabled. */
+#define SEC_PARAM_KEYPRESS                  0                                 /**< Keypress notifications not enabled. */
+#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_KEYBOARD_DISPLAY  /**< No I/O capabilities. */
+#define SEC_PARAM_OOB                       0                                 /**< Out Of Band data not available. */
+#define SEC_PARAM_MIN_KEY_SIZE              7                                 /**< Minimum encryption key size. */
+#define SEC_PARAM_MAX_KEY_SIZE              16                                /**< Maximum encryption key size. */
 typedef struct
     uint8_t *     p_data;   /**< Pointer to data. */
@@ -166,6 +175,21 @@ static const ble_gap_conn_params_t m_connection_param =
     (uint16_t)CONNECTION_SUPERVISION_TIMEOUT
+/** @brief Predefined example public key that is associated with example private key
+ *  @ref alice_raw_private_key.
+static const uint8_t m_raw_public_key[] =
+    0x02, 0x17, 0xE6, 0x17, 0xF0, 0xB6, 0x44, 0x39,
+    0x28, 0x27, 0x8F, 0x96, 0x99, 0x9E, 0x69, 0xA2,
+    0x3A, 0x4F, 0x2C, 0x15, 0x2B, 0xDF, 0x6D, 0x6C,
+    0xDF, 0x66, 0xE5, 0xB8, 0x02, 0x82, 0xD4, 0xED,
+    0x19, 0x4A, 0x7D, 0xEB, 0xCB, 0x97, 0x71, 0x2D,
+    0x2D, 0xDA, 0x3C, 0xA8, 0x5A, 0xA8, 0x76, 0x5A,
+    0x56, 0xF4, 0x5F, 0xC7, 0x58, 0x59, 0x96, 0x52,
+    0xF2, 0x89, 0x7C, 0x65, 0x30, 0x6E, 0x57, 0x94,
 /** Global functions */
@@ -608,7 +632,26 @@ static void on_connected(const ble_gap_evt_t * const p_ble_gap_evt)
     m_connection_handle         = p_ble_gap_evt->conn_handle;
     m_connection_is_in_progress = false;
-    service_discovery_start();
+    ble_gap_sec_params_t m_sec_params;   /**< Security requirements for this application. */
+    memset(&m_sec_params, 0, sizeof(m_sec_params));
+    m_sec_params.bond         = SEC_PARAM_BOND;
+    m_sec_params.mitm         = SEC_PARAM_MITM;
+    m_sec_params.lesc         = SEC_PARAM_LESC;
+    m_sec_params.keypress     = SEC_PARAM_KEYPRESS;
+    m_sec_params.io_caps      = SEC_PARAM_IO_CAPABILITIES;
+    m_sec_params.oob          = SEC_PARAM_OOB;
+    m_sec_params.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
+    m_sec_params.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
+    uint32_t error_code = sd_ble_gap_authenticate(m_adapter, m_connection_handle, &m_sec_params);
+    if (error_code != NRF_SUCCESS)
+        printf("sd_ble_gap_authenticate failed with error code: 0x%04X\n", error_code);
+    } else
+        printf("sd_ble_gap_authenticate succeeded\n");
+    fflush(stdout);
 /**@brief Function called on BLE_GAP_EVT_ADV_REPORT event.
@@ -686,6 +729,37 @@ static void on_timeout(const ble_gap_evt_t * const p_ble_gap_evt)
+/**@brief Function called on BLE_GAP_EVT_SEC_PARAMS_REQUEST event.
+ * @param[in] ble_gap_evt_t Security parameters request.
+static void on_sec_params_request(const ble_gap_evt_t * const p_ble_gap_evt)
+    printf("BLE_GAP_EVT_SEC_PARAMS_REQUEST received: ");
+    ble_gap_sec_keyset_t s_sec_keyset;   /**< Security key set for both local and peer keys. */
+    memset(&s_sec_keyset, 0, sizeof(s_sec_keyset));
+    s_sec_keyset.keys_peer.p_enc_key  = NULL;
+    s_sec_keyset.keys_peer.p_id_key   = NULL;
+    s_sec_keyset.keys_peer.p_sign_key = NULL;
+    s_sec_keyset.keys_peer.p_pk       = NULL;
+    s_sec_keyset.keys_own.p_enc_key   = NULL;
+    s_sec_keyset.keys_own.p_id_key    = NULL;
+    s_sec_keyset.keys_own.p_sign_key  = NULL;
+    s_sec_keyset.keys_own.p_pk        = NULL;
+    // s_sec_keyset.keys_own.p_pk        = &m_raw_public_key;
+    uint32_t err_code = sd_ble_gap_sec_params_reply(m_adapter, m_connection_handle,
+                                                    BLE_GAP_SEC_STATUS_SUCCESS, NULL, &s_sec_keyset);
+    if (err_code != NRF_SUCCESS)
+        printf("Security parameters reply failed, err_code 0x%04X\n", err_code);
+    else
+        printf("Security parameters replied.\n");
+    fflush(stdout);
 /**@brief Function called on BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event.
  * @details Update service state and proceed to discovering the service's GATT characteristics.
@@ -854,6 +928,36 @@ static void on_hvx(const ble_gattc_evt_t * const p_ble_gattc_evt)
     fflush(stdout);
+#if NRF_SD_BLE_API >= 5
+/**@brief Function called on BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST event.
+ * @details Data length update request
+ * @param[in] p_ble_gap_evt Data length update request Event.
+static void on_conn_data_length_update_request(const ble_gap_evt_t * const p_ble_gap_evt)
+    printf("BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST received: ");
+    ble_gap_data_length_params_t const dlp =
+        .max_rx_octets = 27, /* ref: NRF_SDH_BLE_GAP_DATA_LENGTH in sdk_config.h */
+        .max_tx_octets = 27, /* ref: NRF_SDH_BLE_GAP_DATA_LENGTH in sdk_config.h */
+        .max_rx_time_us = BLE_GAP_DATA_LENGTH_AUTO,
+        .max_tx_time_us = BLE_GAP_DATA_LENGTH_AUTO
+    ble_gap_data_length_limitation_t dll = { 0 };
+    uint32_t err_code = sd_ble_gap_data_length_update(m_adapter, m_connection_handle, &dlp, &dll);
+        printf("sd_ble_gap_data_length_update failed, err_code %d\n", err_code);
+        fflush(stdout);
+#endif
 /**@brief Function called on BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST event.
  * @details Update GAP connection parameters.
@@ -951,6 +1055,30 @@ static void ble_evt_dispatch(adapter_t * adapter, ble_evt_t * p_ble_evt)
             on_timeout(&(p_ble_evt->evt.gap_evt));
+        case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
+            on_sec_params_request(&(p_ble_evt->evt.gap_evt));
+            break;
+        case BLE_GAP_EVT_CONN_SEC_UPDATE:
+            printf("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x\n",
+                   p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
+                   p_ble_evt->evt.gap_evt.params.auth_status.bonded,
+                   p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
+                   *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
+                   *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
+            fflush(stdout);
+            if (p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
+                service_discovery_start();
+            else
+                printf("Authorization failed with code: %u!\n",
+                       p_ble_evt->evt.gap_evt.params.auth_status.auth_status);
+                fflush(stdout);
+            break;
         case BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP:
             on_service_discovery_response(&(p_ble_evt->evt.gattc_evt));
@@ -971,6 +1099,20 @@ static void ble_evt_dispatch(adapter_t * adapter, ble_evt_t * p_ble_evt)
             on_hvx(&(p_ble_evt->evt.gattc_evt));
+        case BLE_GAP_EVT_CONN_PARAM_UPDATE:
+            printf("Connection interval updated: 0x%x, 0x%x.\n",
+                p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.min_conn_interval,
+                p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.max_conn_interval);
+            fflush(stdout);
+        } break;
+    #if NRF_SD_BLE_API >= 5
+        case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
+            on_conn_data_length_update_request(&(p_ble_evt->evt.gap_evt));
+            break;
+    #endif
         case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
             on_conn_params_update_request(&(p_ble_evt->evt.gap_evt));
@@ -1077,6 +1219,6 @@ int main(int argc, char * argv[])
         // Toggle notifications on the HRM characteristic every time user input is received.
         cccd_value ^= BLE_CCCD_NOTIFY;
-        hrm_cccd_set(cccd_value);
+        // hrm_cccd_set(cccd_value);
Then I got error 16 which is NRF_ERROR_INVALID_ADDR:
$ ./heart_rate_collector_v3 /dev/ttyACM0
Serial port used: /dev/ttyACM0
Baud rate used: 1000000
Info: Successfully opened /dev/ttyACM0. Baud rate: 1000000. Flow control: none. Parity: none.
Status: 6, message: Target Reset performed
Status: 7, message: Connection active
Scan started
Received advertisement report with device address: 0xF69EF1EC5743
Connection established
BLE_GAP_EVT_SEC_PARAMS_REQUEST received: Security parameters reply failed, err_code 0x0010
I also tried PCA10040 with sd_api_v3 connectivity firmware but got the same error.
BR/Chencheng
  • Hello, I am responsible for this ticket as well. However, I am new to the pc-ble-driver and need some time to learn how it all works. I will try to answer this and your other ticket (224877) as soon as possible.
    Simon
  • Hi, some update on my findings:
    I switch to an old release which is used by pc-ble-driver-js by pc-nrfconnect-ble.
    The version of pc-ble-driver-js is 2.4.3. I guess the corresponding pc-ble-driver version is 2.3.1.
    And I found that I am stuck by a Mutex lock in BLESecurityContext in SerializationTransport::eventHandlingRunner().
    So when I do sd_ble_gap_sec_params_reply, I could not get the Mutex.
    Now sure the source from the event yet. Continue looking. And I will switch back to master branch and analyze the error from transport layer.
    BR/Chencheng
  • In master branch of sd_api_v3, similar to related ticket, some "clue":
    ../src/common/app_ble_gap.cpp : 150	app_ble_gap_set_current_adapter_id EVENT_CODEC_CONTEXT
    ../src/common/app_ble_gap.cpp : 153	app_ble_gap_set_current_adapter_id mutex LOCKED
    Received advertisement report with device address: 0xCB76125C099D
    ../src/sd_api_v3/ble_gap_impl.cpp : 59	gap_encode_decode try get adapterLayer...
    ../src/sd_api_v3/ble_gap_impl.cpp : 68	gap_encode_decode RequestReplyCodecContext...
    ../src/common/app_ble_gap.cpp : 157	app_ble_gap_set_current_adapter_id REQUEST_REPLY_CODEC_CONTEXT
    ../src/common/app_ble_gap.cpp : 159	app_ble_gap_set_current_adapter_id mutex LOCKED
    ../src/sd_api_v3/ble_gap_impl.cpp : 70	gap_encode_decode encode_decode...
    ../src/sd_api_common/sdk/components/serialization/common/ble_serialization.c : 75	ASSERT...
    ../src/sd_api_common/sdk/components/serialization/common/ble_serialization.c : 81	check packet_len...
    ../src/sd_api_common/sdk/components/serialization/common/ble_serialization.c : 88	check p_buf...
    ../src/sd_api_common/sdk/components/serialization/common/ble_serialization.c : 108	NRF_SUCCESS
    ../src/common/ble_common.cpp : 141	encode_decode return result_code = 0.
    ../src/common/app_ble_gap.cpp : 175	app_ble_gap_unset_current_adapter_id REQUEST_REPLY_CODEC_CONTEXT
    ../src/common/app_ble_gap.cpp : 178	app_ble_gap_unset_current_adapter_id mutex UNLOCKED
    ../src/common/app_ble_gap.cpp : 168	app_ble_gap_unset_current_adapter_id EVENT_CODEC_CONTEXT
    ../src/common/app_ble_gap.cpp : 171	app_ble_gap_unset_current_adapter_id mutex UNLOCKED
    Got p_pk
    ../src/sd_api_v3/ble_gap_impl.cpp : 738	gap_encode_decode...
    ../src/sd_api_v3/ble_gap_impl.cpp : 698	app_ble_gap_sec_keys_storage_create...
    ../src/sd_api_v3/ble_gap_impl.cpp : 709	app_ble_gap_sec_keys_update...
    ../src/sd_api_v3/ble_gap_impl.cpp : 719	ble_gap_sec_params_reply_req_enc...
    ../src/sd_api_v3/ble_gap_impl.cpp : 730	ble_gap_sec_params_reply_rsp_dec...
    ../src/sd_api_v3/sdk/components/serialization/application/codecs/s132/serializers/ble_gap_app.c : 646	SER_RSP_DEC_BEGIN...
    ../src/sd_api_common/sdk/components/serialization/common/ble_serialization.c : 103	after decode *p_result_code = 16.
    ../src/sd_api_v3/sdk/components/serialization/application/codecs/s132/serializers/ble_gap_app.c : 648	*p_result_code != NRF_SUCCESS SER_ASSERT_LENGTH_EQ(index=5, packet_len=5)...
    ../src/sd_api_v3/sdk/components/serialization/application/codecs/s132/serializers/ble_gap_app.c : 648	SER_RSP_DEC_BEGIN NRF_SUCCESS.
    ../src/common/ble_common.cpp : 141	encode_decode return result_code = 16.
    Please be aware that the line numbers are after insertion of debugging traces.
    And I came up with something more. In app_ble_gap.cpp line 132-134, there are:
        // TODO: if this key is used in request_reply_key
        // TODO: or event_key, remove them from the keys
        // TODO: and unlock any keys
    I am not sure how exactly they should be implemented.
  • I am thinking those "clue"s from master branch are misleading since I don't see any dead lock with codec context mutex lock & unlock. But what will lead to a need which are indicated by "TODO"s in app_ble_gap.cpp?
  • And I found that I am stuck by a Mutex lock in BLESecurityContext in SerializationTransport::eventHandlingRunner().
    In pc-ble-driver v2.3.2, I solved problem of stuck by dead lock by moving out the reply out of the context mutex lock during event codec.
    So it is not related to mutex.
    But error code 0x10 still sustains. And it is definitely caused by serializer codecs.
