pc-ble-driver sd_ble_gap_sec_params_reply got error 0x10 NRF_ERROR_INVALID_ADDR
Just continue my work on implementing LESC MITM on hear_rate_collector (Please check my development environment settings here as well).
Since sd_api_v6 on pc-ble-driver doesn't work with sd_ble_gap_authenticate on PCA10059. I switched to sd_api_v3.
Then sd_ble_gap_authenticate returns OK.
Then I added sd_ble_gap_sec_params_reply as such:
diff --git a/examples/heart_rate_collector/main.c b/examples/heart_rate_collector/main.c
index 3ee6c9c..8aa379a 100644
--- a/examples/heart_rate_collector/main.c
+++ b/examples/heart_rate_collector/main.c
@@ -104,6 +104,15 @@ enum
 #define STRING_BUFFER_SIZE 50
+#define SEC_PARAM_BOND                      1                                 /**< Perform bonding. */
+#define SEC_PARAM_MITM                      1                                 /**< Man In The Middle protection not required. */
+#define SEC_PARAM_LESC                      1                                 /**< LE Secure Connections enabled. */
+#define SEC_PARAM_KEYPRESS                  0                                 /**< Keypress notifications not enabled. */
+#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_KEYBOARD_DISPLAY  /**< No I/O capabilities. */
+#define SEC_PARAM_OOB                       0                                 /**< Out Of Band data not available. */
+#define SEC_PARAM_MIN_KEY_SIZE              7                                 /**< Minimum encryption key size. */
+#define SEC_PARAM_MAX_KEY_SIZE              16                                /**< Maximum encryption key size. */
 typedef struct
     uint8_t *     p_data;   /**< Pointer to data. */
@@ -166,6 +175,21 @@ static const ble_gap_conn_params_t m_connection_param =
     (uint16_t)CONNECTION_SUPERVISION_TIMEOUT
+/** @brief Predefined example public key that is associated with example private key
+ *  @ref alice_raw_private_key.
+static const uint8_t m_raw_public_key[] =
+    0x02, 0x17, 0xE6, 0x17, 0xF0, 0xB6, 0x44, 0x39,
+    0x28, 0x27, 0x8F, 0x96, 0x99, 0x9E, 0x69, 0xA2,
+    0x3A, 0x4F, 0x2C, 0x15, 0x2B, 0xDF, 0x6D, 0x6C,
+    0xDF, 0x66, 0xE5, 0xB8, 0x02, 0x82, 0xD4, 0xED,
+    0x19, 0x4A, 0x7D, 0xEB, 0xCB, 0x97, 0x71, 0x2D,
+    0x2D, 0xDA, 0x3C, 0xA8, 0x5A, 0xA8, 0x76, 0x5A,
+    0x56, 0xF4, 0x5F, 0xC7, 0x58, 0x59, 0x96, 0x52,
+    0xF2, 0x89, 0x7C, 0x65, 0x30, 0x6E, 0x57, 0x94,
 /** Global functions */
@@ -608,7 +632,26 @@ static void on_connected(const ble_gap_evt_t * const p_ble_gap_evt)
     m_connection_handle         = p_ble_gap_evt->conn_handle;
     m_connection_is_in_progress = false;
-    service_discovery_start();
+    ble_gap_sec_params_t m_sec_params;   /**< Security requirements for this application. */
+    memset(&m_sec_params, 0, sizeof(m_sec_params));
+    m_sec_params.bond         = SEC_PARAM_BOND;
+    m_sec_params.mitm         = SEC_PARAM_MITM;
+    m_sec_params.lesc         = SEC_PARAM_LESC;
+    m_sec_params.keypress     = SEC_PARAM_KEYPRESS;
+    m_sec_params.io_caps      = SEC_PARAM_IO_CAPABILITIES;
+    m_sec_params.oob          = SEC_PARAM_OOB;
+    m_sec_params.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
+    m_sec_params.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
+    uint32_t error_code = sd_ble_gap_authenticate(m_adapter, m_connection_handle, &m_sec_params);
+    if (error_code != NRF_SUCCESS)
+        printf("sd_ble_gap_authenticate failed with error code: 0x%04X\n", error_code);
+    } else
+        printf("sd_ble_gap_authenticate succeeded\n");
+    fflush(stdout);
 /**@brief Function called on BLE_GAP_EVT_ADV_REPORT event.
@@ -686,6 +729,37 @@ static void on_timeout(const ble_gap_evt_t * const p_ble_gap_evt)
+/**@brief Function called on BLE_GAP_EVT_SEC_PARAMS_REQUEST event.
+ * @param[in] ble_gap_evt_t Security parameters request.
+static void on_sec_params_request(const ble_gap_evt_t * const p_ble_gap_evt)
+    printf("BLE_GAP_EVT_SEC_PARAMS_REQUEST received: ");
+    ble_gap_sec_keyset_t s_sec_keyset;   /**< Security key set for both local and peer keys. */
+    memset(&s_sec_keyset, 0, sizeof(s_sec_keyset));
+    s_sec_keyset.keys_peer.p_enc_key  = NULL;
+    s_sec_keyset.keys_peer.p_id_key   = NULL;
+    s_sec_keyset.keys_peer.p_sign_key = NULL;
+    s_sec_keyset.keys_peer.p_pk       = NULL;
+    s_sec_keyset.keys_own.p_enc_key   = NULL;
+    s_sec_keyset.keys_own.p_id_key    = NULL;
+    s_sec_keyset.keys_own.p_sign_key  = NULL;
+    s_sec_keyset.keys_own.p_pk        = NULL;
+    // s_sec_keyset.keys_own.p_pk        = &m_raw_public_key;
+    uint32_t err_code = sd_ble_gap_sec_params_reply(m_adapter, m_connection_handle,
+                                                    BLE_GAP_SEC_STATUS_SUCCESS, NULL, &s_sec_keyset);
+    if (err_code != NRF_SUCCESS)
+        printf("Security parameters reply failed, err_code 0x%04X\n", err_code);
+    else
+        printf("Security parameters replied.\n");
+    fflush(stdout);
 /**@brief Function called on BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event.
  * @details Update service state and proceed to discovering the service's GATT characteristics.
@@ -854,6 +928,36 @@ static void on_hvx(const ble_gattc_evt_t * const p_ble_gattc_evt)
     fflush(stdout);
+#if NRF_SD_BLE_API >= 5
+/**@brief Function called on BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST event.
+ * @details Data length update request
+ * @param[in] p_ble_gap_evt Data length update request Event.
+static void on_conn_data_length_update_request(const ble_gap_evt_t * const p_ble_gap_evt)
+    printf("BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST received: ");
+    ble_gap_data_length_params_t const dlp =
+        .max_rx_octets = 27, /* ref: NRF_SDH_BLE_GAP_DATA_LENGTH in sdk_config.h */
+        .max_tx_octets = 27, /* ref: NRF_SDH_BLE_GAP_DATA_LENGTH in sdk_config.h */
+        .max_rx_time_us = BLE_GAP_DATA_LENGTH_AUTO,
+        .max_tx_time_us = BLE_GAP_DATA_LENGTH_AUTO
+    ble_gap_data_length_limitation_t dll = { 0 };
+    uint32_t err_code = sd_ble_gap_data_length_update(m_adapter, m_connection_handle, &dlp, &dll);
+        printf("sd_ble_gap_data_length_update failed, err_code %d\n", err_code);
+        fflush(stdout);
+#endif
 /**@brief Function called on BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST event.
  * @details Update GAP connection parameters.
@@ -951,6 +1055,30 @@ static void ble_evt_dispatch(adapter_t * adapter, ble_evt_t * p_ble_evt)
             on_timeout(&(p_ble_evt->evt.gap_evt));
+        case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
+            on_sec_params_request(&(p_ble_evt->evt.gap_evt));
+            break;
+        case BLE_GAP_EVT_CONN_SEC_UPDATE:
+            printf("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x\n",
+                   p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
+                   p_ble_evt->evt.gap_evt.params.auth_status.bonded,
+                   p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
+                   *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
+                   *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
+            fflush(stdout);
+            if (p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
+                service_discovery_start();
+            else
+                printf("Authorization failed with code: %u!\n",
+                       p_ble_evt->evt.gap_evt.params.auth_status.auth_status);
+                fflush(stdout);
+            break;
         case BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP:
             on_service_discovery_response(&(p_ble_evt->evt.gattc_evt));
@@ -971,6 +1099,20 @@ static void ble_evt_dispatch(adapter_t * adapter, ble_evt_t * p_ble_evt)
             on_hvx(&(p_ble_evt->evt.gattc_evt));
+        case BLE_GAP_EVT_CONN_PARAM_UPDATE:
+            printf("Connection interval updated: 0x%x, 0x%x.\n",
+                p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.min_conn_interval,
+                p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.max_conn_interval);
+            fflush(stdout);
+        } break;
+    #if NRF_SD_BLE_API >= 5
+        case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
+            on_conn_data_length_update_request(&(p_ble_evt->evt.gap_evt));
+            break;
+    #endif
         case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
             on_conn_params_update_request(&(p_ble_evt->evt.gap_evt));
@@ -1077,6 +1219,6 @@ int main(int argc, char * argv[])
         // Toggle notifications on the HRM characteristic every time user input is received.
         cccd_value ^= BLE_CCCD_NOTIFY;
-        hrm_cccd_set(cccd_value);
+        // hrm_cccd_set(cccd_value);
Then I got error 16 which is NRF_ERROR_INVALID_ADDR:
$ ./heart_rate_collector_v3 /dev/ttyACM0
Serial port used: /dev/ttyACM0
Baud rate used: 1000000
Info: Successfully opened /dev/ttyACM0. Baud rate: 1000000. Flow control: none. Parity: none.
Status: 6, message: Target Reset performed
Status: 7, message: Connection active
Scan started
Received advertisement report with device address: 0xF69EF1EC5743
Connection established
BLE_GAP_EVT_SEC_PARAMS_REQUEST received: Security parameters reply failed, err_code 0x0010
I also tried PCA10040 with sd_api_v3 connectivity firmware but got the same error.
BR/Chencheng
    I have tired to run the full testsuite. But got most of the testcases failed.
    I build with:
    cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug -DARCH=x86_64 -DBLE_DRIVER_TEST_PCA10040_A=682622313:/dev/ttyACM0 -DBLE_DRIVER_TEST_PCA10040_B=682866779:/dev/ttyACM1 -DTEST_ALL=1 ..
    And ran with:
    ./test/test_sd_api_v6 --port-a /dev/ttyACM0 --port-b /dev/ttyACM1 --log-level trace
    And here is the error log:
    test_pc_ble_driver_master.log
  • Sorry, I made a mistake in the previous testsuite run. Tests were all passed.
    And I updated my code snippet according to your test code to:
        printf("BLE_GAP_EVT_SEC_PARAMS_REQUEST received\n");
        ble_gap_sec_keys_t keys_own;
        ble_gap_sec_keys_t keys_peer;
        memset(&keys_own, 0, sizeof(keys_own));
        memset(&keys_peer, 0, sizeof(keys_peer));
        keys_own.p_pk          = nrf_ble_lesc_public_key_get();
        s_sec_keyset.keys_own  = keys_own;
        s_sec_keyset.keys_peer = keys_peer;
        if (s_sec_keyset.keys_own.p_pk == NULL)
            printf("Got NULL p_pk!\n");
            printf("Got p_pk\n");
        fflush(stdout);
        fflush(stdout);
    Still the 0x10 error persists.
  • BTW, your testcase_security.cpp only contain SECTION("legacy_passkey")...
    We are doing LESC LV4 Passkey entry on Central here.
  • I have managed to successfully run sd_ble_gap_sec_params_reply() from the central device (pc-ble-driver collector example), but the peripheral device receives an invalid public key. Could you share the function nrf_ble_lesc_public_key_get?
    Simon
  • Have you seen this link, which shows how to implement LESC (without bonding). It is based on an old version of the pc-ble-driver, but shows the concept.
