Connectivity firmware with sd_api_v6 for PCA10040 does not work
Using https://github.com/NordicSemiconductor/pc-ble-driver (abce7974fe983c23930d362b1769e51c8fa13cbf).
Just followed the instruction and compiled hex/sd_api_v6/connectivity_<ver>_1m_with_s132_6.1.0.hex
Cannot run any example. Error log:
$ ./heart_rate_monitor_v6 /dev/ttyACM0
Serial port used: /dev/ttyACM0
Baud rate used: 1000000
Info: Successfully opened /dev/ttyACM0. Baud rate: 1000000. Flow control: none. Parity: none.
Status: 6, message: Target Reset performed
Status: 7, message: Connection active
Status: 4, message: Error sending packet to target. Code: 0x802a
Failed to set advertisement data. Error code: 0x8005
BR/Chencheng
    Are you using this connectivity firmware? connectivity_4.0.0_1m_with_s132_6.1.0.hex?
    Can you find out where you get this error code? which function is returning this?
    As I mentioned, I compiled the connectivity firmware from source based on abce7974fe983c23930d362b1769e51c8fa13cbf
    I have also tried connectivity_4.0.0_1m_with_s132_6.1.0.hex
    Same error code 0x802a.
    I believe 0x802a means NRF_ERROR_SD_RPC_H5_TRANSPORT_NO_RESPONSE.
    BR/Chencheng
    1) Have you disabled the modem manager: https://github.com/NordicSemiconductor/pc-ble-driver/blob/master/README.md#validating-on-ubuntu-linux
    2) Do you use a Ubuntu distribution?
    Could you run the system tests on your machine?
    They can be compiled by providing -DTEST_ALL=1 to the cmake invocation provided here: https://github.com/NordicSemiconductor/pc-ble-driver/blob/master/README.md#compiling-pc-ble-driver-on-ubuntu-linux-or-macos
    After compilation there will be a test application (build/test/test_main_v6) that may assist us in figuring out what the issue is.
    The application has a help feature (–help) that describes parameters to provide. If the issue persists, increase the log level (--log-level trace) and provide us with the logs.
  • Thanks for your reply.
    I am running Ubuntu 18.04.
    I have followed your suggestions and here is the test log based on the latest commit
    a365694d68c4c43e1d4f39ccd4e67c687332d4dd
    $ ./test_main_v6 --log-level trace
    test_main_v6 is a Catch v2.5.0 host application.
    Run with -? for options
    advertising_sdv6
    ../test/softdevice_api/testcase_advertising.cpp:56
    ../test/softdevice_api/testcase_advertising.cpp:63: FAILED:
      REQUIRE( env.serialPorts.size() >= 2 )
    with expansion:
      0 >= 2
    with message:
      No serial ports setup.
      retransmission-interval:250
      response-timeout:1500
      ble-mtu:150
      hardware-info:No hardware info provided.
      log-level:TRACE
      iterations(if relevant):10
    driver_open_close_sdv6
    ../test/softdevice_api/testcase_driver_open_close.cpp:54
    ../test/softdevice_api/testcase_driver_open_close.cpp:64: FAILED:
      REQUIRE( !env.serialPorts.empty() )
    with expansion:
      false
    with message:
      ble-mtu:150
      log-level:TRACE
    issue_gh_112_sdv6
    ../test/softdevice_api/testcase_issue_gh_112.cpp:59
    ../test/softdevice_api/testcase_issue_gh_112.cpp:63: FAILED:
    with expansion:
      0 >= 2
    with message:
      ble-mtu:150
      log-level:TRACE
    issue_stuck_in_scan_mode_sdv6
    ../test/softdevice_api/testcase_issue_stuck_in_scan_mode.cpp:54
    ../test/softdevice_api/testcase_issue_stuck_in_scan_mode.cpp:66: FAILED:
    with expansion:
      0 >= 2
    with message:
      ble-mtu:150
      log-level:TRACE
    phy_update_sdv6
    ../test/softdevice_api/testcase_phy_update.cpp:59
    ../test/softdevice_api/testcase_phy_update.cpp:71: FAILED:
    with expansion:
      0 >= 2
    with message:
      ble-mtu:150
      log-level:TRACE
    rssi_sdv6
    ../test/softdevice_api/testcase_rssi.cpp:55
    ../test/softdevice_api/testcase_rssi.cpp:69: FAILED:
    with expansion:
      0 >= 2
    with message:
      ble-mtu:150
      log-level:TRACE
    security_sdv6
    ../test/softdevice_api/testcase_security.cpp:55
    ../test/softdevice_api/testcase_security.cpp:59: FAILED:
    with expansion:
      0 >= 2
    with message:
      ble-mtu:150
      log-level:TRACE
    test cases:   8 |   1 passed | 7 failed
    assertions: 279 | 272 passed | 7 failed
  • Hi, you need to specify the kits to use (The tests require two). Specify the COM ports with - - port-a and - - port-b
