Contiguous output from SPIM with EasyDMA on the nRF52840
As background, what I am trying to implement is continuous uninterrupted SPI master output from the nRF52840, compatible with the MCP4822 two-channel 12-bit DAC.
The MCP4822 requires programming waveforms from the nRF52840 as shown in this photo.
i.e. it requires two bytes of data to be sent via SPI while the CSN signal is low (to program one channel), followed by another two bytes of data to be sent via SPI while the CS signal is low (to program one channel), and then finally, it needs the LDAC signal to go low to cause the two analog outputs to change simultaneously.
The desired output frequency for this entire sequence is 16KHz, and I want too involve the CPU as little as possible in the process (as it will be busy doing other things.)
My understanding so far is that that the SPIM3 device is capable of controlling the CSN line, and that it can be used with EasyDMA in ArrayList mode.
I gather that the EasyDMA is limited to outputting a MAXCNT of 256 bytes, but that the ArrayList mode allows a list of pointers to contiguously allocated blocks of 256 bytes to be given to the EasyDMA, which allows it to transmit a longer burst of data.
It is not clear to me from the documentation how the timings of that data transmission are controlled.
For example:
What controls the SCK clock rate of the SPIM?
What controls how many bits/bytes of data are written out of the SPIM before the CSN line is brought high again?
What controls the time interval between successive SPIM writes (of 2-bytes each) from the ArrayList?
In order to allow contiguous transmission from the SPIM, I will need to have two memory "swing" buffers, wherein the CPU fills one buffer while the contents of the other is being transmitted by the SPIM. Then, when the transmission is complete, the buffers swap over and the process continues seamlessly.
I have several questions related to how to implement this.
Firstly I don't know how to trigger an interrupt routine when the SPIM's steadily incrementing TXD.PTR has exceeded a particular value within the ArrayList. (which will be longer than 256 bytes long)
Secondly, as there will typically be a delay between the interrupt triggering and the interrupt service routine (ISR) actually being executed, we need to allow the SPIM module to continue transmitting extra data from the buffer after the interrupt triggers, then, within the ISR read the TXD.PTR to see where the SPIM has actually go to, and use that value as the starting offset when the swing buffers are swapped over. The trouble is, I have no idea how to configure the SPIM and EasyDMA ArrayLists to behave this way, as I am lacking any detailed usage documentation.
For Example:
We could create two "swing buffer" EasyDMA ArrayLists, each with the capacity to transmit data for 30ms each. This could contiguously transmit a series of 20ms audio "frames".
If we fill the first 30ms capacity transmit buffer with 20ms of audio from frame 0, and 10ms from frame 1. The Easy DMA transmission is then started from the first buffer, address 0.
We then start filling a second 30ms buffer with 20ms of audio from frame 1 and 10ms from frame 2.
The interrupt is triggered when the TXD.PTR has reached the 20ms mark, but the SPIM continues to transmit subsequent data from the buffer until told otherwise.
The actual interrupt service routine is later entered and serviced at (say) 24ms. The EasyDMA transmission is then switched to start transmitting from the second buffer, at address 4ms.
The transfer between playing audio from the first buffer and playing audio from the second buffer is then seamless.
None of the above complexity would be required if the SPIM and EasyDMA supported ring-buffers, but oh well.
Finally, we have the issue of generating the LDAC pulses, which (ideally) need to be one SCK clock long, and synchronised with the end of each pair of SPIM transmissions.
I'm not sure how to implement this. Would something to do with the GPIOTE and PPI systems do the trick, perhaps if the timers were regularly re-synchronised within the ISR?
There are a number of errata involving the SPIM3 module, so answers that take those "gotchas" into account would be appreciated.
Nicholas Lee
  • Dear Constantin,
    Documented??, Good grief no.
    Based on the paucity of explanatory documentation or plain-english tutorials, there's basically no way to start from scratch and create a working project. For developers, it's basically so bad that the only viable technique is to start from one of their example projects and then make tiny incremental changes (testing after each change) until you get the functionality you need. I don't think Nordic fully appreciates just how incomprehensible their SDKs and macro-based configuration system documentation is for developers, or how unnecessarily time-consuming and expensive (in wages) that makes it to design Nordic chips into products. I really hope they address this issue.
    Here is my working version of nrfx_glue.h, I hope it helps. Good luck.
     * Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #ifndef NRFX_GLUE_H__
    #define NRFX_GLUE_H__
    #ifdef __cplusplus
    extern "C" {
     * @defgroup nrfx_glue nrfx_glue.h
     * @ingroup nrfx
     * @brief This file contains macros that should be implemented according to
     *        the needs of the host environment into which @em nrfx is integrated.
    #include <legacy/apply_old_config.h>
    #include <soc/nrfx_irqs.h>
    #include <nrf_assert.h>
     * @brief Macro for placing a runtime assertion.
     * @param expression  Expression to evaluate.
    #define NRFX_ASSERT(expression)     ASSERT(expression)
    #include <app_util.h>
     * @brief Macro for placing a compile time assertion.
    #define NRFX_STATIC_ASSERT(expression)  STATIC_ASSERT(expression)
    #ifdef NRF51
    #ifdef SOFTDEVICE_PRESENT
    #define INTERRUPT_PRIORITY_IS_VALID(pri) (((pri) == 1) || ((pri) == 3))
    #else
    #define INTERRUPT_PRIORITY_IS_VALID(pri) ((pri) < 4)
    #endif //SOFTDEVICE_PRESENT
    #else
    #define INTERRUPT_PRIORITY_IS_VALID(pri) ((((pri) > 1) && ((pri) < 4)) || \
                                              (((pri) > 4) && ((pri) < 8)))
    #else
    #define INTERRUPT_PRIORITY_IS_VALID(pri) ((pri) < 8)
    #endif //NRF52
     * @brief Macro for setting the priority of a specific IRQ.
     * @param irq_number  IRQ number.
     * @param priority    Priority to set.
    #define NRFX_IRQ_PRIORITY_SET(irq_number, priority) \
        _NRFX_IRQ_PRIORITY_SET(irq_number, priority)
    static inline void _NRFX_IRQ_PRIORITY_SET(IRQn_Type irq_number,
                                              uint8_t   priority)
        ASSERT(INTERRUPT_PRIORITY_IS_VALID(priority));
        NVIC_SetPriority(irq_number, priority);
     * @brief Macro for enabling a specific IRQ.
    #define NRFX_IRQ_ENABLE(irq_number)  _NRFX_IRQ_ENABLE(irq_number)
    static inline void _NRFX_IRQ_ENABLE(IRQn_Type irq_number)
        NVIC_EnableIRQ(irq_number);
     * @brief Macro for checking if a specific IRQ is enabled.
     * @retval true  If the IRQ is enabled.
     * @retval false Otherwise.
    #define NRFX_IRQ_IS_ENABLED(irq_number)  _NRFX_IRQ_IS_ENABLED(irq_number)
    static inline bool _NRFX_IRQ_IS_ENABLED(IRQn_Type irq_number)
        return 0 != (NVIC->ISER[irq_number / 32] & (1UL << (irq_number % 32)));
     * @brief Macro for disabling a specific IRQ.
    #define NRFX_IRQ_DISABLE(irq_number)  _NRFX_IRQ_DISABLE(irq_number)
    static inline void _NRFX_IRQ_DISABLE(IRQn_Type irq_number)
        NVIC_DisableIRQ(irq_number);
     * @brief Macro for setting a specific IRQ as pending.
    #define NRFX_IRQ_PENDING_SET(irq_number) _NRFX_IRQ_PENDING_SET(irq_number)
    static inline void _NRFX_IRQ_PENDING_SET(IRQn_Type irq_number)
        NVIC_SetPendingIRQ(irq_number);
     * @brief Macro for clearing the pending status of a specific IRQ.
    #define NRFX_IRQ_PENDING_CLEAR(irq_number) _NRFX_IRQ_PENDING_CLEAR(irq_number)
    static inline void _NRFX_IRQ_PENDING_CLEAR(IRQn_Type irq_number)
        NVIC_ClearPendingIRQ(irq_number);
     * @brief Macro for checking the pending status of a specific IRQ.
     * @retval true  If the IRQ is pending.
    #define NRFX_IRQ_IS_PENDING(irq_number) _NRFX_IRQ_IS_PENDING(irq_number)
    static inline bool _NRFX_IRQ_IS_PENDING(IRQn_Type irq_number)
        return (NVIC_GetPendingIRQ(irq_number) == 1);
    #include <nordic_common.h>
    #include <app_util_platform.h>
     * @brief Macro for entering into a critical section.
    #define NRFX_CRITICAL_SECTION_ENTER()   CRITICAL_REGION_ENTER()
     * @brief Macro for exiting from a critical section.
    #define NRFX_CRITICAL_SECTION_EXIT()    CRITICAL_REGION_EXIT()
     * @brief When set to a non-zero value, this macro specifies that
     *        @ref nrfx_coredep_delay_us uses a precise DWT-based solution.
     *        A compilation error is generated if the DWT unit is not present
     *        in the SoC used.
    #define NRFX_DELAY_DWT_BASED 0
    #include <soc/nrfx_coredep.h>
    #define NRFX_DELAY_US(us_time) nrfx_coredep_delay_us(us_time)
    #include <soc/nrfx_atomic.h>
     * @brief Atomic 32 bit unsigned type.
    #define nrfx_atomic_t               nrfx_atomic_u32_t
     * @brief Stores value to an atomic object and returns previously stored value.
     * @param[in] p_data  Atomic memory pointer.
     * @param[in] value   Value to store.
     * @return Old value stored into atomic object.
    #define NRFX_ATOMIC_FETCH_STORE(p_data, value) nrfx_atomic_u32_fetch_store(p_data, value)
     * @brief Performs logical OR operation on an atomic object and returns previously stored value.
     * @param[in] value   Value of second operand of OR operation.
    #define NRFX_ATOMIC_FETCH_OR(p_data, value)   nrfx_atomic_u32_fetch_or(p_data, value)
     * @brief Performs logical AND operation on an atomic object and returns previously stored value.
     * @param[in] value   Value of second operand of AND operation.
    #define NRFX_ATOMIC_FETCH_AND(p_data, value)   nrfx_atomic_u32_fetch_and(p_data, value)
     * @brief Performs logical XOR operation on an atomic object and returns previously stored value.
     * @param[in] value   Value of second operand of XOR operation.
    #define NRFX_ATOMIC_FETCH_XOR(p_data, value)   nrfx_atomic_u32_fetch_xor(p_data, value)
     * @brief Performs logical ADD operation on an atomic object and returns previously stored value.
     * @param[in] value   Value of second operand of ADD operation.
    #define NRFX_ATOMIC_FETCH_ADD(p_data, value)   nrfx_atomic_u32_fetch_add(p_data, value)
     * @brief Performs logical SUB operation on an atomic object and returns previously stored value.
     * @param[in] value   Value of second operand of SUB operation.
    #define NRFX_ATOMIC_FETCH_SUB(p_data, value)   nrfx_atomic_u32_fetch_sub(p_data, value)
    #ifndef NRFX_CUSTOM_ERROR_CODES
    #include <sdk_errors.h>
     * @brief When set to a non-zero value, this macro specifies that the
     *        @ref nrfx_error_codes and the @ref ret_code_t type itself are defined
     *        in a customized way and the default definitions from @c <nrfx_error.h>
     *        should not be used.
    #define NRFX_CUSTOM_ERROR_CODES 1
    typedef ret_code_t nrfx_err_t;
    #define NRFX_SUCCESS                    NRF_SUCCESS
    #define NRFX_ERROR_INTERNAL             NRF_ERROR_INTERNAL
    #define NRFX_ERROR_NO_MEM               NRF_ERROR_NO_MEM
    #define NRFX_ERROR_NOT_SUPPORTED        NRF_ERROR_NOT_SUPPORTED
    #define NRFX_ERROR_INVALID_PARAM        NRF_ERROR_INVALID_PARAM
    #define NRFX_ERROR_INVALID_STATE        NRF_ERROR_INVALID_STATE
    #define NRFX_ERROR_INVALID_LENGTH       NRF_ERROR_INVALID_LENGTH
    #define NRFX_ERROR_TIMEOUT              NRF_ERROR_TIMEOUT
    #define NRFX_ERROR_FORBIDDEN            NRF_ERROR_FORBIDDEN
    #define NRFX_ERROR_NULL                 NRF_ERROR_NULL
    #define NRFX_ERROR_INVALID_ADDR         NRF_ERROR_INVALID_ADDR
    #define NRFX_ERROR_BUSY                 NRF_ERROR_BUSY
    #define NRFX_ERROR_ALREADY_INITIALIZED  NRF_ERROR_MODULE_ALREADY_INITIALIZED
    #define NRFX_ERROR_DRV_TWI_ERR_OVERRUN  NRF_ERROR_DRV_TWI_ERR_OVERRUN
    #define NRFX_ERROR_DRV_TWI_ERR_ANACK    NRF_ERROR_DRV_TWI_ERR_ANACK
    #define NRFX_ERROR_DRV_TWI_ERR_DNACK    NRF_ERROR_DRV_TWI_ERR_DNACK
    #endif // NRFX_CUSTOM_ERROR_CODES
    #include <sdk_resources.h>
     * @brief Bitmask defining PPI channels reserved to be used outside of nrfx.
    #define NRFX_PPI_CHANNELS_USED  NRF_PPI_CHANNELS_USED
     * @brief Bitmask defining PPI groups reserved to be used outside of nrfx.
    #define NRFX_PPI_GROUPS_USED    NRF_PPI_GROUPS_USED
     * @brief Bitmask defining SWI instances reserved to be used outside of nrfx.
    #define NRFX_SWI_USED           NRF_SWI_USED
     * @brief Bitmask defining TIMER instances reserved to be used outside of nrfx.
    #define NRFX_TIMERS_USED        NRF_TIMERS_USED
    #ifdef __cplusplus
    #endif // NRFX_GLUE_H__
