Mesh proxy got disconnecting after connected
Hi
   I am using nrf sdk 15.2.0 for MEsh networking.(Mesh SDK version 3.3).
Hardware platform -nrf52832(pca10040).
Steps followed:
1. Compile and Run light switch demo with proxy enabled is working fine.
2. after that tested with proxi-coexist example with nrf mesh App .
3.i enabled PB_GATT and and GATT_Feature enabled .system got reset ..or fatal error will display on console in advertising_init
   for this i changed advertising settings from fast to slow mode.
    init.config.ble_adv_slow_enabled  = true;
    init.config.ble_adv_slow_interval = 1600;
    init.config.ble_adv_slow_timeout  = 0;
    I can able proximity coexist example is advertising in nrfmesh app. If i try to connect ,connection successful i can see connected message in terminal. But after that it got disconnected. Why it is getting disconnecting.or any other changes is there to do for mesh to get work .Please help me on this.
Regards
Raji
  • So is 1. working as expected? Are you disconnecting on purpose, or are you having trouble provisioning?
    Yes. Test:1 working as expected. We disconnected for just testing....
    Are 2. and 3. attempts to fix 1.? Or are you trying to add features to 1.?
    Yes. I am trying to add PROXY_FEATURE in base code.
    NRF_LOG_INFO("disconnected reason %d", p_ble_evt->evt.gap_evt.params.disconnected.reason);
    Here, I need to clarify my understanding. We can understand the scenario like below from the Test:3 screenshot,
    1. ble stack initialized.
    2. mesh initialized
    3. models initialized
    4. mesh advertising started
    5. device listed in nRF_Mesh app
    6. Connecting device by tap the device name
    In nRF_Mesh side, we can saying it as Disconnecting.
    In Firmware side,  we getting ASSERTION_ERROR in some place. it may not be from disconnect event . so we need to find it out that why it happens and where? Am I right ?
    I will update the disconnect event reason..
    Thanks.
  • SDK3.1.0 (Mesh) has the proxy feature included in both the light switch server and client.
    When you get this empty assert, it is one of the NRF_MESH_ASSERT(false). I am afraid you have to try them out by setting a breakpoint. Alternatively, changing the "false" with something you can recognize.
