Issue when Debugging the nRF Dongle with DK
Hi, I have modified the twi_scanner example of the 52840 DK to be compatible with nRFDongle.
I fully erased the dongle with Segger and passed the new hex file with SWD cable.
Then I connected an I2C device on the dongle and I can see with logic analyzer that the dongle
communicates with the I2C device properly by finding its address.
The problem I encounter is that the messages I want to print to the terminal with NRF_LOG_INFO() are not printed.
I also disabled the deferred mode in the sdk_config through CMSIS and commended the NRF_LOG_FLUSH();
If any ideas please share
Here is the code
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#if TWI0_ENABLED
#define TWI_INSTANCE_ID     0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID     1
 /* Number of possible TWI addresses. */
 #define TWI_ADDRESSES     127
 // SDA and SCL pins for nRF Dongle 52840
 #define TWI_SCL NRF_GPIO_PIN_MAP(1,13)
 #define TWI_SDA NRF_GPIO_PIN_MAP(1,10)
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
 * @brief TWI initialization.
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = TWI_SCL,
       .sda                = TWI_SDA,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
    uint8_t address;
    uint8_t sample_data;
    bool detected_device = false;
    NRF_LOG_INFO("TWI scanner started.");
    //NRF_LOG_FLUSH();
    twi_init();
    for (address = 1; address <= TWI_ADDRESSES; address++)
        err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
        if ((err_code == NRF_SUCCESS) && (detected_device == false) )
            detected_device = true;
            NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
        //NRF_LOG_FLUSH();
    if (!detected_device)
        NRF_LOG_INFO("No device was found.");
        //NRF_LOG_FLUSH();
    else{
      bsp_board_led_invert(2);
      nrf_delay_ms(100);
    while (true){
     nrf_delay_ms(500);
