Hangs on sd_softdevice_enable
It happens on a new board. It is possible that an HW problem occurs (Xtall), but how to debug it?
How to know if Xtall correctly runs? The same code runs correctly on another board...
It is also possible, that the SD (112  v. 5.1) is not correctly loaded, but how to check it with Keil?
In my case, I suspect a wrong Xtall frequency (16MHz instead of  32), but why does it hang the application?
It is strange enough, only the radio part of application does not run (hangs up). The not "ble" functions work well.
How to manage this kind of errors?
Thank you in advance for any help
