Build nRF Connect SDK Project via Command Line
I'm working on an application for the nRF9160 using the nRF Connect SDK. I want to integrate this app into our build system and thus would like to be able to build the project via the command line. One thing I'm concerned about is what operations Segger EM Studio is doing behind the scenes when you click "Open nRF Connect SDK Project... ". Doing this links all of the Zephyr files as well as the GNU ARM Embedded Toolchain files.
So my question is, Is there a way to replicate this on our build server using the command line?
- Jack
  • Jack,
    I have not begun to develop the nRF9160 to date, but my nRF52 series development utilizes the armgccs folder of the SDK. This only requires a text editor and a command line interface with the complete toolchain in place. I do think it is very effective, but there is a slight learning curve from compiling to programming the chips. I  will attach a recipe for the toolchain on to a windows 10 machine. The recipe places the toolchain on to a work environment but I am not sure you should have any problem putting this on to a server. Good luck!
    Nordic Semiconductor Toolchain Setup.docx
  • Yes.  Most of what is happening "behind the scenes" is creating an output directory, running cmake, and possibly adjusting configuration. All of this is based on normal Zephyr build flow, which was developed on command line primarily.
    You can find more detailed instructions here:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/getting_started/index.html#getting-started-run-sample
  • Hi Jack,
    Just adding to what jbrzozoski is referring to:
    • When using the command line you need to define the environment variables for the GNU Arm Embedded toolchain:
    export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    export GNUARMEMB_TOOLCHAIN_PATH=/c/gnuarmemb
    • Set up build environment
    cd $NCS_BASE/zephyr
    source zephyr-env.sh
    cd $NCS_BASE/nrf/samples/nrf9160/mqtt_simple/
    mkdir build && cd build
    # Use cmake to configure a Ninja-based build system:
    cmake -GNinja -DBOARD=nrf9160_pca10090ns ..
    # Now run ninja on the generated build system:
    ninja
    ninja flash
    Also worth noticing that there is a difference when building Secure/Non-Secure Zephyr applications.
    Extra tip:
    To flash precompiled .hex files you can either use the nRF Connect Programmer application or do it via command line nrfjprog:
    nrfjprog --program <application>.hex -f nrf91 --sectorerase -r --verify
    Best Regards,
    Martin L.
  • Hi, I'm trying to build the coap_client application using the command line on Windows since I'm having problems using Segger.
    I already flashed the Secure Boot, now I'm trying using this commands
    cd C:\Nordic_SDK\ncs\zephyr
    zephyr-env.cmd
    set ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
    set GNUARMEMB_TOOLCHAIN_PATH = “C:\Program Files (x86)\GNU Tools ARM Embedded\8 2018-q4-major”
    cd C:\Nordic_SDK\ncs\nrf\samples\nrf9160\coap_client
    cmake .. -DBOARD=nrf9160_pca10090ns -GNinja
    ninja flash
    But then it reports the following message
    C:\Nordic_SDK\ncs\nrf\samples\nrf9160\coap_client\build>cmake .. -DBOARD=nrf9160_pca10090ns -GNinja
    Zephyr version: 1.14.0
    -- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.2", minimum required is "3.4")
    -- Selected BOARD nrf9160_pca10090ns
    CMake Error at C:/Nordic_SDK/ncs/zephyr/cmake/extensions.cmake:1104 (message):
    Assertion failed: GNUARMEMB_TOOLCHAIN_PATH is not set
    C:/Nordic_SDK/ncs/zephyr/cmake/toolchain/gnuarmemb/generic.cmake:11 (assert)
    C:/Nordic_SDK/ncs/zephyr/cmake/generic_toolchain.cmake:55 (include)
    C:/Nordic_SDK/ncs/zephyr/cmake/app/boilerplate.cmake:395 (include)
    CMakeLists.txt:9 (include)
    It says that the Toolchain Path is not set but I set it with the Gnuarmemb Path I set in the Getting Started Assistant to verify if the Toolchain was correctly installed. Do I have to set a different path?
    Thanks in advance for any clarification you can give me.
    On a side note, will it be possible to build projects using Segger soon? Everytime I try to build a project it gives me an error unless I switch to the v3.0.0 release and then it works.
  • Hello Marco,
    1. I would recommend you to switch to the version 7-2018-q2-update, since the newest version (8-2018-q4-major) has a critical bug and should not be used.
    2. I think the issue can be the same as Hellesvik is experiencing in this thread.
    (There may also be an issue with spaces in the paths)
    Here is my path to the ARM Toolchain:
    I set:
    and here is what's in this path: C:\gnuarmemb\arm-none-eabi\
    There is a Segger release that is coming very soon, I can update you when it's ready.
    Best Regards,
    Martin L.
