Can't resume addvertising after disconnect.
I'm using the PSA1001 eval board with SD 110. The device comes up advertising, I can connect and access my services. I need to the Central to be able to issue a disconnect command, and for my device to disconnect and resume advertising.
I execute:
    sd_err = sd_ble_gap_disconnect 	( m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION	) ;
    advertising_start();
The return value is 0 (NRF_SUCCESS) - I do check the value of sd_err in my code, I just omitted it for carity here, as stated sd_err = NRF_SUCCESS after the call.
I then call advertising_start();
    uint32_t             err_code;
    ble_gap_adv_params_t adv_params;
    // Start advertising
    memset(&adv_params, 0, sizeof(adv_params));
    adv_params.type        = BLE_GAP_ADV_TYPE_ADV_IND;
    adv_params.p_peer_addr = NULL;
    adv_params.fp          = BLE_GAP_ADV_FP_ANY;
    adv_params.interval    = APP_ADV_INTERVAL;
    adv_params.timeout     = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = sd_ble_gap_adv_start(&adv_params);
//    nrf_gpio_pin_set(ADVERTISING_LED_PIN_NO);
I'm getting an NRF_ERROR_INVALID_STATE error from the sd_ble_gap_adv_start(&adv_params); call.
What am I doing wrong?
Thanks
  • I believe you have to wait for a BLE_GAP_EVT_DISCONNECTED event to be returned by the stack before you can restart your advertising. So, rather than calling advertising_start(); immediately after calling the sd_ble_gap_disconnect just add the advertising_start(); call in your disconnect event handler.
