nRF9160 failing with nrf_cloud_connect failed: 60 for asset_tracker
I'm seeing similar problems to others in getting highly unreliable connections to the network.  I *VERY* occasionally get LED3 and LED4 to blink simultaneously, but it's very rare, and generally something times out and the board loses that connection shortly therafter.
This is tested in Southern California from various points roughly from Irvine, CA to San Diego, CA.  This is the home of Qualcomm, so I'm assuming the network isn't the issue...
I can't run any AT commands against the asset_tracker code as it never gets past the nrf_cloud_connect.
Running the at_client code I can do a AT+CGMR and that gives me:
mfw-m1_nrf9160_0.6.8-30.alpha
Any help would be very appreciated.  Thanks.
  • Good grief.  This website is horrifically slow.  Uploading screenshots is beyond painful.  Hopefully this will upload before the website goes offline again.
    Yes, we are painfully aware of this Speak no evil Though it is something we currently working with and hope to improve ASAP.
    Andrew Lentvorski said:
    Here is my log from having installed the asset_tracker hex.  You will note that the code never gets to a point where I can send anything an AT command.
    The asset_tracker does not support AT Commands and therefore will not give anything other than  "Error: 'AT+CFUN?' timed out". It is a little misleading that it says "Type AT Command here".
    I will discuss the output from the AT_client with my colleagues and get back to ASAP.
    Thanks!
    Oeyvind
  • Looking at the log we can see that you connect and disconnect several times, but we do not know why at this moment.
    Can you please try to program this file, uicr_tcxo.hex. This sets the configuration of the 32 MHz temperature compensated crystal oscillator (TCXO).
    nrfjprog --program uicr_txco.hex --sectorerase -f nrf91 -r --verify
    After it is done, please reset the board and try the AT_Client one more time.
    Oeyvind
  • Okay, I tried that and here is the initial log.  I'll let this run for a while and then upload a larger log later.
    AT+CFUN?
    +CFUN: 4
    OK
    AT+CFUN=1
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    +CGSN: "352656100106007"
    OK
    AT+CGMI
    Nordic Semiconductor ASA
    OK
    AT+CGMM
    nRF9120
    OK
    AT+CGMR
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    %XCBAND: (3,4,13,20)
    OK
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    OK
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    OK
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    +CGDCONT: 0,"IP","","",0,0
    OK
    AT+CGACT?
    +CGACT: 0,0
    OK
    AT+CGEREP=1
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    +CEREG: 2,2,"2801","09C706B5",7
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    +CESQ: 99,99,255,255,255,37
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813511297
    OK
    +CGEV: ME PDN ACT 0,0
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CEREG: 5,"2801","09C706B5",7
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.25.231",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    OK
    AT+CGMI
    OK
    AT+CGMM
    nRF9120
    OK
    AT+CGMR
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    OK
    AT+CMEE?
    +CMEE: 1
    OK
    AT+CNEC?
    +CNEC: 24
    OK
    AT+CGEREP?
    +CGEREP: 1,0
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    +CEREG: 2,5,"2801","09C706B5",7
    OK
    AT+COPS=3,2
    OK
    AT+COPS?
    +COPS: 0,2,"311480",7
    OK
    AT%XCBAND
    %XCBAND: 13
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813511297
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT?Applying at_client here
    +CME ERROR: 0
    AT+CESQ
    OK
    ***** Booting Zephyr OS v1.13.99-ncs1-4488-ga76f833d24 *****
    Secure Boot: configure flash
    Secure Boot: SPU: set region 0 as Secure
    Secure Boot: SPU: set region 1 as Secure
    Secure Boot: SPU: set region 2 as Secure
    Secure Boot: SPU: set region 3 as Secure
    Secure Boot: SPU: set region 4 as Secure
    Secure Boot: SPU: set region 5 as Secure
    Secure Boot: SPU: set region 6 as Secure
    Secure Boot: SPU: set region 7 as Secure
    Secure Boot: SPU: set Flash region 8 as Non-Secure
    Secure Boot: SPU: set Flash region 9 as Non-Secure
    Secure Boot: SPU: set Flash region 10 as Non-Secure
    Secure Boot: SPU: set Flash region 11 as Non-Secure
    Secure Boot: SPU: set Flash region 12 as Non-Secure
    Secure Boot: SPU: set Flash region 13 as Non-Secure
    Secure Boot: SPU: set Flash region 14 as Non-Secure
    Secure Boot: SPU: set Flash region 15 as Non-Secure
    Secure Boot: SPU: set Flash region 16 as Non-Secure
    Secure Boot: SPU: set Flash region 17 as Non-Secure
    Secure Boot: SPU: set Flash region 18 as Non-Secure
    Secure Boot: SPU: set Flash region 19 as Non-Secure
    Secure Boot: SPU: set Flash region 20 as Non-Secure
    Secure Boot: SPU: set Flash region 21 as Non-Secure
    Secure Boot: SPU: set Flash region 22 as Non-Secure
    Secure Boot: SPU: set Flash region 23 as Non-Secure
    Secure Boot: SPU: set Flash region 24 as Non-Secure
    Secure Boot: SPU: set Flash region 25 as Non-Secure
    Secure Boot: SPU: set Flash region 26 as Non-Secure
    Secure Boot: SPU: set Flash region 27 as Non-Secure
    Secure Boot: SPU: set Flash region 28 as Non-Secure
    Secure Boot: SPU: set Flash region 29 as Non-Secure
    Secure Boot: SPU: set Flash region 30 as Non-Secure
    Secure Boot: SPU: set Flash region 31 as Non-Secure
    Secure Boot: configure SRAM
    Secure Boot: SPU: set SRAM region 0 as Secure
    Secure Boot: SPU: set SRAM region 1 as Secure
    Secure Boot: SPU: set SRAM region 2 as Secure
    Secure Boot: SPU: set SRAM region 3 as Secure
    Secure Boot: SPU: set SRAM region 4 as Secure
    Secure Boot: SPU: set SRAM region 5 as Secure
    Secure Boot: SPU: set SRAM region 6 as Secure
    Secure Boot: SPU: set SRAM region 7 as Secure
    Secure Boot: SPU: set SRAM region 8 as Non-Secure
    Secure Boot: SPU: set SRAM region 9 as Non-Secure
    Secure Boot: SPU: set SRAM region 10 as Non-Secure
    Secure Boot: SPU: set SRAM region 11 as Non-Secure
    Secure Boot: SPU: set SRAM region 12 as Non-Secure
    Secure Boot: SPU: set SRAM region 13 as Non-Secure
    Secure Boot: SPU: set SRAM region 14 as Non-Secure
    Secure Boot: SPU: set SRAM region 15 as Non-Secure
    Secure Boot: SPU: set SRAM region 16 as Non-Secure
    Secure Boot: SPU: set SRAM region 17 as Non-Secure
    Secure Boot: SPU: set SRAM region 18 as Non-Secure
    Secure Boot: SPU: set SRAM region 19 as Non-Secure
    Secure Boot: SPU: set SRAM region 20 as Non-Secure
    Secure Boot: SPU: set SRAM region 21 as Non-Secure
    Secure Boot: SPU: set SRAM region 22 as Non-Secure
    Secure Boot: SPU: set SRAM region 23 as Non-Secure
    Secure Boot: SPU: set SRAM region 24 as Non-Secure
    Secure Boot: SPU: set SRAM region 25 as Non-Secure
    Secure Boot: SPU: set SRAM region 26 as Non-Secure
    Secure Boot: SPU: set SRAM region 27 as Non-Secure
    Secure Boot: SPU: set SRAM region 28 as Non-Secure
    Secure Boot: SPU: set SRAM region 29 as Non-Secure
    Secure Boot: SPU: set SRAM region 30 as Non-Secure
    Secure Boot: SPU: set SRAM region 31 as Non-Secure
    Secure Boot: configure peripherals
    Secure Boot: MSP_NS 20024808
    Secure Boot: prepare to jump to Non-Secure image
    ***** Booting Zephyr OS v1.13.99-ncs1-4741-g1d6219ffec *****
    The AT host sample started
    AT+CESQ
    +CESQ: 99,99,255,255,255,255
    OK
    AT+CFUN?
    +CFUN: 4
    OK
    AT+CFUN=1
    OK
    AT+CESQ
    +CESQ: 99,99,255,255,255,38
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    OK
    AT+CGMI
    OK
    AT+CGMM
    nRF9120
    OK
    AT+CESQ
    OK
    AT+CGMR
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    OK
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    OK
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    OK
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    +CGDCONT: 0,"IP","ibasis.iot","10.160.25.239",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CGEREP=1
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    OK
    AT+COPS=3,2
    OK
    AT+COPS?
    OK
    AT%XCBAND
    %XCBAND: 13
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813511297
    OK
    +CGEV: ME PDN DEACT 0
    +CNEC_EMM: 10
    AT+CGDCONT?
    +CEREG: 2,"2801","09C706B5",7
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.25.242",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.25.244",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.25.246",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    +CNEC_ESM: 50,0
    AT+CGDCONT?
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.25.250",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    Send
    AT
    AT+CFUN?
    AT+CFUN=1
    Log
    06:14:52.893	Application data folder: C:\Users\andrewl\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    06:15:03.148	Modem port is opened
    06:15:05.604	Nordic Semiconductor ASA nRF9120 [mfw-m1_nrf9160_0.6.8-30.alpha] SerNr: 352656100106007
    06:15:06.317	IMSIdentity: 204080813511297
    06:15:16.413	Nordic Semiconductor ASA nRF9120 [mfw-m1_nrf9160_0.6.8-30.alpha] SerNr: 352656100106007
    06:15:17.567	IMSIdentity: 204080813511297
    06:15:40.464	Error: AT?Applying at_client here
     failed: phone failure
    06:16:13.306	Nordic Semiconductor ASA nRF9120 [mfw-m1_nrf9160_0.6.8-30.alpha] SerNr: 352656100106007
    06:16:16.332	IMSIdentity: 204080813511297
  • Thank you!
    It does not solve the issue. We are trying to find the solution and will get back to you ASAP.
    -Oeyvind
  • Here is the larger log.  Looks like the board hung.
    AT+CFUN?
    +CFUN: 4
    OK
    AT+CFUN=1
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    OK
    AT+CGMI
    OK
    AT+CGMM
    nRF9120
    OK
    AT+CGMR
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    OK
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    OK
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    OK
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,0
    OK
    AT+CGEREP=1
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813511297
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    OK
    AT+CGMI
    OK
    AT+CGMM
    nRF9120
    OK
    AT+CGMR
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    OK
    AT+CMEE?
    +CMEE: 1
    OK
    AT+CNEC?
    +CNEC: 24
    OK
    AT+CGEREP?
    +CGEREP: 1,0
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    OK
    AT+COPS=3,2
    OK
    AT+COPS?
    OK
    AT%XCBAND
    %XCBAND: 13
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813511297
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    +CME ERROR: 0
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CFUN?
    +CFUN: 4
    OK
    AT+CFUN=1
    OK
    AT+CESQ
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    OK
    AT+CGMI
    OK
    AT+CGMM
    nRF9120
    OK
    AT+CESQ
    OK
    AT+CGMR
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    OK
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    OK
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    OK
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CGEREP=1
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    OK
    AT+COPS=3,2
    OK
    AT+COPS?
    OK
    AT%XCBAND
    %XCBAND: 13
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813511297
    OK
    +CNEC_EMM: 10
    AT+CGDCONT?
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    +CNEC_ESM: 50,0
    AT+CGDCONT?
    +CIND: "service",1
    +CIND: "roam",1
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.2",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.5",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.14",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.19",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    %CESQ: 43,2
    AT+CESQ
    +CESQ: 99,99,255,255,255,43
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.42",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.45",0,0
    OK
    AT+CESQ
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.49",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    +CNEC_ESM: 50,0
    AT+CGDCONT?
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.52",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.60",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.64",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.75",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.77",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.26.84",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CESQ
    OK
    AT+CGDCONT?
    +CNEC_EMM: 10
    +CIND: "service",0
    +CIND: "roam",0
    +CGEV: NW DETACH
    OK
    AT+CGACT?
    OK
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CIND: "service",1
    +CIND: "roam",1
    Send
    AT
    AT+CFUN?
    AT+CFUN=1
    Log
