I was examining the power supply part of the Thingy and I noticed that the charging current is set to 0.5 C, wich is 720 mA (checking XR6804's datasheet it seems that actually it has been set to 784 mA). Given that there a USB port (max current is 500 mA) is used to charge the device, isn't the required current set too high?
I also checked the way the SOC is estimated and I found out that a "Battery voltage - SOC" look-up table is used. How has been that table filled, are those OCV measurements? If not, I guess a constant discharge current has been used and I'd like to know what is the value of that current.
Thank you in advace!
Aleksandar
