I use SDK15.2, SES4.12 and custom board with nRF52840.
I have a strip of ws2812b LED's connected to my device. I've made a simple RGB animation, each frame of which is transferred via SPIM. It works fine.
Now I need to add some USB HID functionality. I have simple custom descriptor with one output report. And it works fine too, if there is no SPIM transfer.
When I try to run both SPIM and USB, my code breaks somewhere with no call stack available. If I manually break the execution, it breaks on line 72 in ses_startup_nrf52840.s file, here is a snippet from there:
.thumb_func .weak HardFault_Handler HardFault_Handler: b .
Here is my main
nrf_gpio_cfg_output( LOGO );
Logo_Initialize(LOGO);
init_hid();
RGB_Refresh();
while (true)
while (app_usbd_event_queue_process())
/* Nothing to do */
/* Sleep CPU only if there was no interrupt since last loop processing */
__WFE();
SPIM part:
void spim_event_handler(nrfx_spim_evt_t const * p_event, void * p_context)
NRF_LOG_INFO("Transfer completed.");
nrf_delay_ms(10);
RGB_Refresh();
void Logo_Initialize(uint8_t logo_pin)
uint8_t m_rx_buf[DATA_LENGTH];
nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(m_tx_buf, DATA_LENGTH, m_rx_buf, DATA_LENGTH);
nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
spi_config.frequency = NRF_SPIM_FREQ_4M;
spi_config.mosi_pin = logo_pin;
spi_config.use_hw_ss = true;
spi_config.ss_active_high = false;
APP_ERROR_CHECK(nrfx_spim_init(&spi, &spi_config, spim_event_handler, NULL));
transfer_descriptor = &xfer_desc;
NRF_LOG_INFO("NRFX SPIM example started.");
bitmanio_init_array8(&bio_arr, m_tx_buf, CODED_BYTES_PER_RGB_BYTE);
//animation array initialization here
void RGB_Refresh()
//get next frame here
APP_ERROR_CHECK(nrfx_spim_xfer_dcx(&spi, transfer_descriptor, 0, 15));
Basically now I can have either RGB_Refresh() call or app_usbd_event_queue_process() call in my main function, but not both.
