nrf52840 ncp bit rate
Hello everyone!
I have started to work with openthread recently, and now I have to build a mqttsn client into a stm32 uController.
I'm doing that by using the spinel protocol between stm and a nrf52840. The nrf52840 is configured as NCP.
The problem actually seems to be very simple: I just want to change the transmition speed to increase the module's range, but I couldn't find where i should change it inside the NCP's example file in the nRF5_SDK_for_Thread_and_Zigbee_2.0.0  (I'm programming the board using segger IDE, inside Windows 10 OS)
So I was hoping that someone here should know something :D
Thanks for any help!
    So is it the UART bitrade that you want to change? Or the radio bitrate?
    As you can see here, a handful of the peripherals such as the UART are set up and compiled in the openthread build that is included in the SDK. If you want to change the UART settings, you must rebuild the openthread library. As you can see from the link, the UART baudrate/bitrate is set in platform-config.h, on line 110. If you want the new openthread build to work with the current SDK, you should use the same build commit that was used with the SDK. The commit number is mentioned in SDK_for_Thread\external\openthread\project\readme.txt.
    Edvin
  • Hello!
    Thanks for your reply
    I may have expressed myself badly ( first i talked about the uart, and then asked about the radio, without saying it... sorry)
    what I do want to change is the radio bitrate. Is it possible to change it?
    BR,
    Tiago Morais
  • Ah. It didn't quite add up, but I saw we discussed spinel and UART in one of your earlier tickets, so I assumed it was the same.
    But unfortunately, no. It is not possible to change the bitrate of IEEE (which is what OpenThread uses). It is by default set to 250kbps using 2.4GHz, and this is included all the headers. You will see that the payload bitrate is lower than this.
    The only option if you want to change the bitrate between two devices  is to run e.g. BLE concurrently. BLE or even ESB (Enhanced ShockBurst, Nordic Proprietary radio protocol, which would require Nordic chips in both ends). This will however not increase the throughput of the network, only between these two nodes.
    Edvin
  • Yeah! Once I created a topic about the spinel protocol, but I was able to solve that already :D
    it took me a while, but I was able start a code using the spinel protocol to communicate the uController and the NCP. For a starter version, it works quite well
    I wanted to decrease the bitrate because my team only had the nrf52840 dongle and wanted to try to increase its range. Instead we found another compatible device to work with ncp: BL654 that has a external antenna, and also I received the news, after doing some tests, that the distance we were able to communicate was over 1000 m using the ncp code and our mqttsn client.
    Eventhough we were able to increase that range, I was still trying to decrease its bitrate just to test it :D, but since it's not possible to change the openthread's default bitrate, I'll keep that way for now
    Thank you very much Edvin!
    untill next time!
    Best Regards,
    Tiago
