When open the SAADC, it cannot be closed in the low power
Hi
I open the SAADC to get the battery after initial the SAADC, using nrf_drv_saadc_sample_convert to get the ADC data . After nRF52832 is initialed, it enter power_manage, but the cutrrent cannot enter low power(about 6.8mA),because the SAADC cannot be closed.  If I don't use the nrf_drv_saadc_sample_convert function after saadc_init, the current could be entered low power. Thus, nrf_drv_saadc_sample_convert is the key. So, how to control SAADC when MCU enter the low power.
The code is as following:
void saadc_init(void)
ret_code_t err_code;
nrf_saadc_channel_config_t mmysaadc1=
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
//NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(SAADC_CH_PSELP_PSELP_VDD);//VDD
nrf_saadc_channel_config_t mmysaadc=
//NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
err_code=nrf_drv_saadc_init(NULL,saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &mmysaadc);
// err_code = nrf_drv_saadc_channel_init(1, &mmysaadc1);
// APP_ERROR_CHECK(err_code);
nrf_saadc_value_t saadc_val;//, saadc_val1;
float voltage=9.99;
int init_ADC_battary(void)
      saadc_init(); //
       nrf_drv_saadc_sample_convert(0,&saadc_val);
       voltage=(float)saadc_val*3.6/1024;
       vol_send_phone = (uint8_t)(voltage * 10);
void main()
      init_ADC_battary();
// Start execution.
      NRF_LOG_INFO("Blinky example started.");
      advertising_start();
// Enter main loop.
      for (;;)
                  power_manage();
Thanks.
