hi...
i am working on mesh , i have done light switch example , now i want to get some message from node and send to particular node . how to print the same message which is from particular node to uart termite
please help me out.
thanks in advance
hi...
please help me out.
thanks in advance
It seems the message has been received on the server side. The client also responded with an acknowledged message success, which means that the client has successfully sent the message & the server responded to the client saying it has received the message. Go to line 204 in app_onoff.c & line 96 in main.c for more info.
but i didn't receive that character , how to get that char in server side .
see the code below this how i set the character in client side
char arr[5] = "code";
char ara[5] = "set";
switch(button_number)
case 0:
case 2:
set_params.on_off = arr;
case 1:
case 3:
set_params.on_off = Ara;
set_params.tid = tid++;
transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
check whether it is correct or wrong
What is the type of set_params.on_off ?
arr[] and Ara[] are char arrays, so:
Expects that set_params.on_off is a char pointer.
What does
actually print?
You would usually use %p to print a pointer...
hi.... Bjorn kvaale , did you get my question, waiting for your response .
Thanks in advance .
Which particular question?
Did you see my question about the type of set_params.on_off ?
