pc-ble-driver-js for Raspberry Pi
Hey guys,
we are currently evaluating the pc-ble-driver-js. We want to get it running on a Raspberry Pi 3.
The Nordic nRF52840 module was flashed with SD Version 6.1.0. and the ble_connectivity Application.
The module is detected on the RPi as ttyACMx inertface - so this works basically.
We also tested it with pc-ble-driver-js on macOS... successful.
Now we are trying to get pc-ble-driver-js project working on the pi.
-> clone pc-ble-driver-js from git
-> cd pc-ble-driver-js
-> npm install
Following Error:
Unsupported platform: 'linux'. Cannot install nrfjprog libraries.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for [email protected]: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: `node scripts/pre-install.js && ( node-pre-gyp install --fallback-to-build=false || node build.js )`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /home/essentim/.npm/_logs/2019-03-18T21_24_41_807Z-debug.log
-> We built pc-ble-driver in the pc-ble-driver-js folder successfully.
-> We failed to build pc-ble-driver-js and pc-nrfjprog-js from scratch.
On build " Fatal Error: No such file or directory" for several files is thrown in both projects.
F.e. #include "nan.h" is one of the "missing" files, but nan.h exists in node_modules folder....
If we try to run an an example via node, the following error output is thrown:
nordic/pc-ble-driver-js/node_modules/bindings/bindings.js:135
throw err;
Error: Could not locate the bindings file. Tried:
→ /home/nordic/pc-ble-driver-js/build/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/build/Debug/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/build/Release/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/out/Debug/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/Debug/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/out/Release/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/Release/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/build/default/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/compiled/8.12.0/linux/arm/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/addon-build/release/install-root/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/addon-build/debug/install-root/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/addon-build/default/install-root/pc-ble-driver-js-sd_api_v2.node
→ /home/nordic/pc-ble-driver-js/lib/binding/node-v57-linux-arm/pc-ble-driver-js-sd_api_v2.node
at bindings (/home/nordic/pc-ble-driver-js/node_modules/bindings/bindings.js:126:9)
at Object.<anonymous> (/home/nordic/pc-ble-driver-js/api/adapterFactory.js:41:41)
at Module._compile (module.js:653:30)
at Object.Module._extensions..js (module.js:664:10)
at Module.load (module.js:566:32)
at tryModuleLoad (module.js:506:12)
at Function.Module._load (module.js:498:3)
at Module.require (module.js:597:17)
at require (internal/module.js:11:18)
at Object.<anonymous> (/home/nordic/pc-ble-driver-js/index.js:38:24)
So, has anybody successfully ran the pc-ble-driver-js on a ARM platform respectively a raspberry pi?
Any suggestions how to proceed?
Thanks so far for your help, best,
fpic
