hi ... i am using nRF52832 ,i want to save the battery so i am planning to use system off mode . how to wake up the device from system off mode using threshold value or either system on mode
is it possible ? how to do
Thanks in advance
Thanks in advance
Thank you sitan . option 2 is good , i can go with this , actually i tried using timer to interrupt the sleep but i couldn't reach . i don't how to write the flow to interrupt the sleep using timer .. i have succeed upto checking the threshold using timer .can you help me
If you are successful in checking the threshold using timer, there's not really much more to do. The CPU automatically goes to IDLE between the interrupts, as long as there is a __WFE() in the main loop somewhere. Can you post your main function, then I can have a look.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
ret_code_t err_code =app_timer_create(&m_led_a_timer_id, APP_TIMER_MODE_REPEATED ,timer_sensor_event_handler);
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
advertising_start();
err_code = app_timer_start(m_led_a_timer_id,APP_TIMER_TICKS(60000),NULL);
twi_init();
MAX30_set_mode();
// Start execution.
for(;;)
idle_state_handle();
In time event handler i am comparing threshold
Is it possible for option 1 . if manually i am setting threshold in my program , and by using led pin
