hi ... i am using nRF52832 ,i want to save the battery so i am planning to use system off mode . how to wake up the device from system off mode using threshold value or either system on mode
is it possible ? how to do
Thanks in advance
Thanks in advance
Ok, so I think you are finished with you code now. It goes to sleep in the idle_state_handle() and wake up using app_timer interrupt.
Using LED pin for what?
led pin to wake up the device from system off mode ..as per option 1
Not sure what "led pin" is, but yes you can wake the chip up from system OFF using a GPIO pin interrupt signal from the temperature sensor.
How to do that can you explain me
