Proximity app ADC Input
I am using nRF51422 with the SDK 11.  I am using the proximity application to measure the battery service.  By default, the device uses VDD as its ADC input.  I would like to change the input to another available pin (for example p0.00).  How would I be able to do this?
    I assume you mean the ADC uses VDD as the ADC voltage reference?
    From the Proximity Application's main.c:
    /**@brief Function for configuring ADC to do battery level conversion.
    static void adc_configure(void)
        #ifdef NRF51
        ret_code_t err_code = nrf_drv_adc_init(NULL, adc_event_handler);
        static nrf_drv_adc_channel_t channel = NRF_DRV_ADC_DEFAULT_CHANNEL(NRF_ADC_CONFIG_INPUT_DISABLED);
        //channel.config.config.input = NRF_ADC_CONFIG_SCALING_SUPPLY_ONE_THIRD;
        channel.config.config.input = (uint32_t)NRF_ADC_CONFIG_SCALING_SUPPLY_ONE_THIRD;
        nrf_drv_adc_channel_enable(&channel);
        err_code = nrf_drv_adc_buffer_convert(&adc_buf[0], 1);
    This is where the ADC is configured using the ADC HW driver. You must change NRF_ADC_CONFIG_INPUT_DISABLED to wanted channel.
    More information about the ADC driver can be found here. The channels that are available for the ADC can be found here. Be aware that AIN0 (P0.00) is ADC/LPCOMP reference input. Please read the nRF51422 Reference Manual chapter 31 Analog to Digital Converter (ADC) to ensure correct usage. Please have a look at this document .
    Oeyvind
