Getting issue in nRF9160 Application
i am facing two issue in nRF9160 cellular application.
1.Asset tracker Application:
       i loaded Asset tracker example firmware in nRF9160 eval. board. when i run this application, error was displayed on console: "nrf_cloud_connect failed: 60".
2. custom firmware:
     in this firmware when "getaddrinfo" API is called to resolved IP, i am getting error 22:No more processes. i have attached code.please review it.
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <logging/log.h>
#define LOG_DOMAIN sr_uart
#define LOG_LEVEL CONFIG_LOG_AT_HOST_LEVEL
LOG_MODULE_REGISTER(LOG_DOMAIN);
#include <zephyr.h>
#include <stdio.h>
#include <uart.h>
#include <net/socket.h>
#include <string.h>
#include "SR_Main.h"
// Define Constant and Variable
#define INVALID_DESCRIPTOR -1
#define UART_RX_BUF_SIZE 4096 /**< UART RX buffer size. */
 * @brief Size of the buffer used to parse an AT command.
 * Defines the maximum number of characters of an AT command (including null
 * termination) that we can store to decode. Must be a power of two.
#define AT_MAX_CMD_LEN 4096
RINGBUFF_T    SR_UART_rxring;        // Transmit and receive ring buffers
uint8_t       SR_UART_rxRingbuff[SR_UART_RRB_SIZE];                                                // Transmit and receive buffers
uint8_t       SR_UART_rxbuff[SR_UART_RRB_SIZE], SR_UART_txbuff[SR_UART_SRB_SIZE];                       // Transmit and receive
uint8_t       SR_UART_rxbuffbase64[SR_UART_RRB_SIZE];
struct device *uart_dev;
static int at_socket_fd = INVALID_DESCRIPTOR;
// Functions
void at_host_at_socket_write(const void *data, size_t datalen)
  if ((data != NULL) && (datalen > 0)) {
    //printf("Cell Tx: %d, Rx Data: %s\r\n", datalen, (char *)data);
    int bytes_written = send(at_socket_fd, data, datalen, 0);
    if (bytes_written <= 0) {
      LOG_ERR("\n Could not send AT-command to modem: [ %d ]", bytes_written);
    gtsSR_ProcessState.CellRespPending = true;
void at_host_at_socket_read(void)
  uint8_t data_buf[SR_UART_RRB_SIZE];
  int err;
  /* Read AT socket in non-blocking mode. */
  int bytes = recv(at_socket_fd, data_buf, sizeof(data_buf), MSG_DONTWAIT);
  /* Forward the data over UART if any. */
  /* If no data, errno is set to EGAIN and we will try again. */
  if (bytes > 0)
   // printf("Cell RxLen: %d, Rx Data: %s\r\n", bytes, data_buf);
    switch(gtsSR_ProcessState.Conn_State)
       case SR_Conn_PowerOff:
         if(!gtsSR_ProcessState.CellInitDone)
           if(0 == memcmp(AT_SUCCESS, data_buf, AT_CMD_SIZE(AT_SUCCESS)))
             gtsSR_ProcessState.CellInitDone = true;
             gtsSR_ProcessState.CellRespPending = false;
           if (!memcmp(AT_STATUS_1, data_buf, AT_CMD_SIZE(AT_STATUS_1)) ||
                !memcmp(AT_STATUS_2, data_buf, AT_CMD_SIZE(AT_STATUS_2)) ||
                !memcmp(AT_STATUS_3, data_buf, AT_CMD_SIZE(AT_STATUS_3)) ||
                !memcmp(AT_STATUS_4, data_buf, AT_CMD_SIZE(AT_STATUS_4)))//||
                //!memcmp(AT_STATUS_5, data_buf, AT_CMD_SIZE(AT_STATUS_5)))
             gtsSR_ProcessState.Conn_State = SR_Conn_CellReg;
             gtsSR_ProcessState.CellInitDone = false;
             gtsSR_ProcessState.RegistrationStatus = true;
             at_uart_send(uart_dev, data_buf, bytes);
            gtsSR_ProcessState.RegistrationStatus = false;
       case SR_Conn_CellReg:
        gtsSR_ProcessState.Conn_State = SR_Conn_CellIdle;
       case SR_Conn_Connected:
        linux_NBIoT_write(uart_dev, data_buf, bytes);
        memset(SR_UART_txbuff, 0, sizeof(SR_UART_txbuff));
	sprintf(SR_UART_txbuff, "Host Socket Rx Data Len: %d\r\n Data:", bytes);
        uint8_t len = strlen(SR_UART_txbuff);
        memcpy(&SR_UART_txbuff[strlen(SR_UART_txbuff)], data_buf, bytes);
	at_uart_send(uart_dev, SR_UART_txbuff, len +bytes);
int at_socket_init(void)
  at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
//  printk("Starting simple AT socket application\n\r");
  if (at_socket_fd < 0) {
    printk("Socket err: %d, errno: %d\r\n", at_socket_fd, errno);
  return at_socket_fd;
int SR_ResolveServerURL(void)
  int err;
  struct addrinfo *res;
  struct addrinfo hints;
  hints.ai_flags = 0;
  hints.ai_family = AF_INET;
  hints.ai_socktype = SOCK_STREAM;
  hints.ai_protocol = 0;
 // return 0;
  err = getaddrinfo(gtsBridgeParam.ServerURL, NULL, &hints, &res);
  if(err)
    sprintf(SR_UART_txbuff, "Get AddrInfo error = %d %s\r\n", err, strerror(errno));
    at_uart_send(uart_dev, SR_UART_txbuff, strlen(SR_UART_txbuff));
    return 1;
  ((struct sockaddr_in *)res->ai_addr)->sin_port = htons(gtsBridgeParam.ServerPort);
  struct sockaddr_in local_addr;
  local_addr.sin_family = AF_INET;
  local_addr.sin_port = htons(0);
  local_addr.sin_addr.s_addr = 0;
  gtsBridgeParam.ServerSocketFd = socket(AF_INET, SOCK_STREAM, 0);
  //printk("client_fd: %d\n\r", client_fd);
  err = bind(gtsBridgeParam.ServerSocketFd, (struct sockaddr *)&local_addr, sizeof(local_addr));
  if(err)
    sprintf(SR_UART_txbuff, "bind error= %d %s\r\n", err, strerror(errno));
    return 2;
  //printk("bind err: %d\n\r", err);
  err = connect(gtsBridgeParam.ServerSocketFd, (struct sockaddr *)res->ai_addr, sizeof(struct sockaddr_in));
  if(err < 0)
    sprintf(SR_UART_txbuff, "Server connect error = %d %s\r\n", err, strerror(errno));
    if(errno == EAGAIN)
      return 3;
      return 4;
  return 0;
int SR_ServerSendData(uint8_t *buf, uint32_t size, uint32_t flags)
  return send(gtsBridgeParam.ServerSocketFd, buf, size, flags);
void SR_Cellular_Process(void)
uint8_t ui8buffer[15];
  if(gtsSR_ProcessState.CellRespPending)
     return;
         at_host_at_socket_write(AT_CEREG_2, sizeof(AT_CEREG_2));
         at_host_at_socket_write(AT_CFUN_1, sizeof(AT_CFUN_1));
       if(gtsSR_ProcessState.ConnInitFlg)
         gtsSR_ProcessState.Conn_State = SR_Conn_ResolveDNS;
     case SR_Conn_CellIdle:
     case SR_Conn_ResolveDNS:
         int err = SR_ResolveServerURL();
         if(0 == err)
           gtsSR_ProcessState.ConnInitFlg = false;
           gtsSR_ProcessState.Conn_State = SR_Conn_Connected;
         memset(ui8buffer, 0, sizeof(ui8buffer));
         sprintf(ui8buffer,"SR+CONN=%d\r\n",err);
         at_uart_send(uart_dev, ui8buffer,strlen(ui8buffer));
        sprintf(SR_UART_txbuff, "Parsed ServerURL: %s, Parsed ServerPort: %d\r\n", gtsBridgeParam.ServerURL, gtsBridgeParam.ServerPort);
void at_uart_send(struct device *uart_dev, const u8_t *tx_data, int size)
  for(uint32_t ui32Idx = 0; ui32Idx < size; ui32Idx++)
    uart_poll_out(uart_dev, tx_data[ui32Idx]);
static void isr(struct device *x)
  uint32_t lu32_len;
  uart_irq_update(x);
  if (uart_irq_rx_ready(x)) {
    lu32_len = uart_fifo_read(x, data_buf, SR_UART_RRB_SIZE);
    RingBuffer_InsertMult(&SR_UART_rxring, data_buf, lu32_len);
    gtsSR_ProcessState.UARTRxStartFlg = true;	// Start Inter Character Timer
    gtsSR_ProcessTMR.UARTRxGetTimeMS = 0;
int at_uart_init(char *uart_dev_name)
  int err;
  // Ringbuffer init
  memset(SR_UART_rxRingbuff, 0, sizeof(SR_UART_rxRingbuff));
  RingBuffer_Init(&SR_UART_rxring, SR_UART_rxRingbuff, 1, SR_UART_RRB_SIZE);
  RingBuffer_Flush(&SR_UART_rxring);
  uart_dev = device_get_binding(uart_dev_name);
  if (uart_dev == NULL) {
    LOG_ERR("Cannot bind %s\n", uart_dev_name);
    return EINVAL;
  err = uart_err_check(uart_dev);
  if (err) {
    LOG_ERR("UART check failed\n");
    return EINVAL;
  uart_irq_rx_enable(uart_dev);
  uart_irq_callback_set(uart_dev, isr);
  return err;
void SR_UartParser(void)
  volatile unsigned int bytes = 0;
  char *resultptr = NULL;
  int err;
  memset(SR_UART_rxbuff, 0, sizeof(SR_UART_rxbuff));
  bytes = RingBuffer_PopMult(&SR_UART_rxring, &SR_UART_rxbuff[0], SR_UART_RRB_SIZE);
  if(bytes <= 0)
    gtsSR_ProcessState.UARTMsgParseFlg = false;     // Clear UART Parsing flag
    return;
  //  at_host_at_socket_write(SR_UART_rxbuff, bytes);
//  printf("RxLen: %d, Rx Data: %.*s\r\n", bytes, bytes, SR_UART_rxbuff);
  resultptr = strstr(SR_UART_rxbuff, "SR+CON=\"");
  if(NULL != resultptr)
    resultptr += strlen("SR+CON=\"");
    memset(&gtsBridgeParam.ServerURL[0], 0, sizeof(gtsBridgeParam.ServerURL));
    u8_t lu8_UrlIdx = 0;
    while(('"' != *resultptr) && ((sizeof(gtsBridgeParam.ServerURL) - 1) > lu8_UrlIdx))
      gtsBridgeParam.ServerURL[lu8_UrlIdx++] = *resultptr++;
    resultptr++;
    resultptr++;
    gtsBridgeParam.ServerPort = atoi(resultptr);
    if(gtsBridgeParam.ServerSocketFd)
        sprintf(SR_UART_txbuff, "Closing opened socket\r\n");
        err = close(gtsBridgeParam.ServerSocketFd);
        if(err)
            sprintf(SR_UART_txbuff, "socket close error:%d %s\r\n", err, strerror(errno));
            return;
    gtsSR_ProcessState.ConnInitFlg = true;
    resultptr = strstr(SR_UART_rxbuff, "SR+MSG=");
      if(SR_Conn_Connected == gtsSR_ProcessState.Conn_State)
        resultptr = strtok(SR_UART_rxbuff, "=");
        resultptr += strlen("SR+MSG=");
        uint32_t  msglen = atoi(resultptr);
        resultptr = strtok(NULL, "\"");
        uint32_t  EncodedMsgLen = strlen(resultptr);
        memset(SR_UART_rxbuffbase64, 0, sizeof(SR_UART_rxbuffbase64));
        if(SUCCESS != Decrypt_Base_64_Data((char *)resultptr, EncodedMsgLen, SR_UART_rxbuffbase64, sizeof(SR_UART_rxbuffbase64)))
          return;
        int err = SR_ServerSendData(SR_UART_rxbuffbase64, msglen, 0);
	sprintf(SR_UART_txbuff, "Decoded Rxed Data Len: %d\r\nDecoded Rxed Data:", msglen);
        memcpy(&SR_UART_txbuff[strlen(SR_UART_txbuff)], SR_UART_rxbuffbase64, msglen);
	at_uart_send(uart_dev, SR_UART_txbuff, len + msglen);
      resultptr = strstr(SR_UART_rxbuff, "SR+RSSI?");
        resultptr = strstr(SR_UART_rxbuff, "SR+CELL?");
          if(gtsSR_ProcessState.RegistrationStatus)
            sprintf(SR_UART_rxbuffbase64, "SR+CELL=1\r\n");
            sprintf(SR_UART_rxbuffbase64, "SR+CELL=0\r\n");
          at_uart_send(uart_dev, SR_UART_rxbuffbase64, strlen(SR_UART_rxbuffbase64));
          at_uart_send(uart_dev, SR_UART_rxbuff, bytes);
void linux_NBIoT_write(struct device *uart_dev, unsigned char* buffer, int len)
	sprintf(SR_UART_txbuff, "SR+MSG=%u,\"",len);
	if(SUCCESS != Encrypt_Base_64_Data((char *)buffer, len, &SR_UART_txbuff[strlen(SR_UART_txbuff)], sizeof(SR_UART_txbuff) - strlen(SR_UART_txbuff)))
		return;
	sprintf(&SR_UART_txbuff[strlen(SR_UART_txbuff)],"\"");
#include <stdio.h>
#include <string.h>
#include <uart.h>
#include <zephyr.h>
#define HTTP_HOST "google.com"
#define HTTP_PORT 80
#define RECV_BUF_SIZE 1024
tsBridgeParam gtsBridgeParam = {0};
tsSR_ProcessState gtsSR_ProcessState = {0};
tsSR_ProcessTMR gtsSR_ProcessTMR = {0};
extern struct device *uart_dev;
char recv_buf[RECV_BUF_SIZE + 1];
const char *at_commands[] = {
	"AT+CGMM", "AT+CGDCONT?", "AT%XCBAND=?", "AT+CGSN=1",
	"AT+CESQ", "AT+CEREG=2", "AT+COPS?",
	/* Add more here if needed */
uint8_t SR_UART_txbuff1[1000];
int blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags)
	int err;
	do {
		err = recv(fd, buf, size, flags);
	} while (err < 0 && errno == EAGAIN);
	return err;
int blocking_send(int fd, u8_t *buf, u32_t size, u32_t flags)
	int err;
	do {
		err = send(fd, buf, size, flags);
	return err;
int blocking_connect(int fd, struct sockaddr *local_addr, socklen_t len)
	int err;
	do {
		err = connect(fd, local_addr, len);
	return err;
void app_socket_start(void)
	int at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
	for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
		int bytes_written = send(at_socket_fd, at_commands[i],
					 strlen(at_commands[i]), 0);
		if (bytes_written > 0) {
			int r_bytes =
				blocking_recv(at_socket_fd, recv_buf,
					      sizeof(recv_buf), MSG_DONTWAIT);
			if (r_bytes > 0) {
				printk("%s", recv_buf);
	printk("Closing socket\n\r");
	(void)close(at_socket_fd);
static int SR_Main_PowerUpInit(void)
    int err;
    err = at_uart_init(CONFIG_UART_0_NAME);
    if (err != 0) {
      //printf("ERROR: UART not initialized \r\n");
      return -1;
    err = at_socket_init();
    if(err < 0)
      //printf("ERROR: AT_Socket not initialized \r\n");
      return -1;
    SR_Timer_Init();
    return 1;
  static uint32_t su32_Tick;
  int err;
  err = SR_Main_PowerUpInit();
  if(err < 0)
    printf("ERROR: SR_Main_PowerUpInit.\r\n");
    while(1);
  printf("SUCCESS: SR_Main_PowerUpInit.\r\n");
  while (1) {
    if(gtsSR_ProcessState.UARTMsgParseFlg)
      SR_UartParser();
    at_host_at_socket_read();
    SR_Cellular_Process();
    if(gtsSR_ProcessState.SecFlg)
      su32_Tick++;
      if(0 == (su32_Tick % 60))
        //printf("Tick: %u\r\n", su32_Tick);
      gtsSR_ProcessState.SecFlg = false;
//#include <zephyr.h>
//#include <stdio.h>
//#include <uart.h>
//#include <string.h>
//#include <at_host.h>
//void main(void)
//	int err;
//	printf("The AT host sample started\n");
//	err = at_host_init(CONFIG_AT_HOST_UART, CONFIG_AT_HOST_TERMINATION);
//	if (err != 0) {
//		printf("ERROR: AT Host not initialized \r\n");
//		return;
//	while (1) {
//		at_host_process();
