i am facing two issue in nRF9160 cellular application.
1.Asset tracker Application:
i loaded Asset tracker example firmware in nRF9160 eval. board. when i run this application, error was displayed on console: "nrf_cloud_connect failed: 60".
2. custom firmware:
in this firmware when "getaddrinfo" API is called to resolved IP, i am getting error 22:No more processes. i have attached code.please review it.
/* * Copyright (c) 2018 Nordic Semiconductor ASA * * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic */ #include <logging/log.h> #define LOG_DOMAIN sr_uart #define LOG_LEVEL CONFIG_LOG_AT_HOST_LEVEL LOG_MODULE_REGISTER(LOG_DOMAIN); #include <zephyr.h> #include <stdio.h> #include <uart.h> #include <net/socket.h> #include <string.h> #include "SR_Main.h" //***************************************************************************** // Define Constant and Variable //***************************************************************************** #define INVALID_DESCRIPTOR -1 #define UART_RX_BUF_SIZE 4096 /**< UART RX buffer size. */ /** * @brief Size of the buffer used to parse an AT command. * Defines the maximum number of characters of an AT command (including null * termination) that we can store to decode. Must be a power of two. */ #define AT_MAX_CMD_LEN 4096 RINGBUFF_T SR_UART_rxring; // Transmit and receive ring buffers uint8_t SR_UART_rxRingbuff[SR_UART_RRB_SIZE]; // Transmit and receive buffers uint8_t SR_UART_rxbuff[SR_UART_RRB_SIZE], SR_UART_txbuff[SR_UART_SRB_SIZE]; // Transmit and receive uint8_t SR_UART_rxbuffbase64[SR_UART_RRB_SIZE]; struct device *uart_dev; static int at_socket_fd = INVALID_DESCRIPTOR; //***************************************************************************** // Functions //***************************************************************************** void at_host_at_socket_write(const void *data, size_t datalen) { if ((data != NULL) && (datalen > 0)) { //printf("Cell Tx: %d, Rx Data: %s\r\n", datalen, (char *)data); int bytes_written = send(at_socket_fd, data, datalen, 0); if (bytes_written <= 0) { LOG_ERR("\n Could not send AT-command to modem: [ %d ]", bytes_written); } gtsSR_ProcessState.CellRespPending = true; } } void at_host_at_socket_read(void) { uint8_t data_buf[SR_UART_RRB_SIZE]; int err; /* Read AT socket in non-blocking mode. */ int bytes = recv(at_socket_fd, data_buf, sizeof(data_buf), MSG_DONTWAIT); /* Forward the data over UART if any. */ /* If no data, errno is set to EGAIN and we will try again. */ if (bytes > 0) { // printf("Cell RxLen: %d, Rx Data: %s\r\n", bytes, data_buf); switch(gtsSR_ProcessState.Conn_State) { case SR_Conn_PowerOff: { if(!gtsSR_ProcessState.CellInitDone) { if(0 == memcmp(AT_SUCCESS, data_buf, AT_CMD_SIZE(AT_SUCCESS))) { gtsSR_ProcessState.CellInitDone = true; gtsSR_ProcessState.CellRespPending = false; } } else { if (!memcmp(AT_STATUS_1, data_buf, AT_CMD_SIZE(AT_STATUS_1)) || !memcmp(AT_STATUS_2, data_buf, AT_CMD_SIZE(AT_STATUS_2)) || !memcmp(AT_STATUS_3, data_buf, AT_CMD_SIZE(AT_STATUS_3)) || !memcmp(AT_STATUS_4, data_buf, AT_CMD_SIZE(AT_STATUS_4)))//|| //!memcmp(AT_STATUS_5, data_buf, AT_CMD_SIZE(AT_STATUS_5))) { gtsSR_ProcessState.Conn_State = SR_Conn_CellReg; gtsSR_ProcessState.CellRespPending = false; gtsSR_ProcessState.CellInitDone = false; gtsSR_ProcessState.RegistrationStatus = true; at_uart_send(uart_dev, data_buf, bytes); } else { at_uart_send(uart_dev, data_buf, bytes); gtsSR_ProcessState.RegistrationStatus = false; } } } break; case SR_Conn_CellReg: { gtsSR_ProcessState.Conn_State = SR_Conn_CellIdle; } break; case SR_Conn_Connected: { linux_NBIoT_write(uart_dev, data_buf, bytes); memset(SR_UART_txbuff, 0, sizeof(SR_UART_txbuff)); sprintf(SR_UART_txbuff, "Host Socket Rx Data Len: %d\r\n Data:", bytes); uint8_t len = strlen(SR_UART_txbuff); memcpy(&SR_UART_txbuff[strlen(SR_UART_txbuff)], data_buf, bytes); at_uart_send(uart_dev, SR_UART_txbuff, len +bytes); } break; } } } int at_socket_init(void) { at_socket_fd = socket(AF_LTE, 0, NPROTO_AT); // printk("Starting simple AT socket application\n\r"); if (at_socket_fd < 0) { printk("Socket err: %d, errno: %d\r\n", at_socket_fd, errno); } return at_socket_fd; } int SR_ResolveServerURL(void) { int err; struct addrinfo *res; struct addrinfo hints; hints.ai_flags = 0; hints.ai_family = AF_INET; hints.ai_socktype = SOCK_STREAM; hints.ai_protocol = 0; // return 0; memset(SR_UART_txbuff, 0, sizeof(SR_UART_txbuff)); err = getaddrinfo(gtsBridgeParam.ServerURL, NULL, &hints, &res); if(err) { sprintf(SR_UART_txbuff, "Get AddrInfo error = %d %s\r\n", err, strerror(errno)); at_uart_send(uart_dev, SR_UART_txbuff, strlen(SR_UART_txbuff)); return 1; } ((struct sockaddr_in *)res->ai_addr)->sin_port = htons(gtsBridgeParam.ServerPort); struct sockaddr_in local_addr; local_addr.sin_family = AF_INET; local_addr.sin_port = htons(0); local_addr.sin_addr.s_addr = 0; gtsBridgeParam.ServerSocketFd = socket(AF_INET, SOCK_STREAM, 0); //printk("client_fd: %d\n\r", client_fd); err = bind(gtsBridgeParam.ServerSocketFd, (struct sockaddr *)&local_addr, sizeof(local_addr)); if(err) { sprintf(SR_UART_txbuff, "bind error= %d %s\r\n", err, strerror(errno)); at_uart_send(uart_dev, SR_UART_txbuff, strlen(SR_UART_txbuff)); return 2; } //printk("bind err: %d\n\r", err); err = connect(gtsBridgeParam.ServerSocketFd, (struct sockaddr *)res->ai_addr, sizeof(struct sockaddr_in)); if(err < 0) { sprintf(SR_UART_txbuff, "Server connect error = %d %s\r\n", err, strerror(errno)); at_uart_send(uart_dev, SR_UART_txbuff, strlen(SR_UART_txbuff)); if(errno == EAGAIN) { return 3; } else { return 4; } } return 0; } int SR_ServerSendData(uint8_t *buf, uint32_t size, uint32_t flags) { return send(gtsBridgeParam.ServerSocketFd, buf, size, flags); } void SR_Cellular_Process(void) { uint8_t ui8buffer[15]; if(gtsSR_ProcessState.CellRespPending) { return; } switch(gtsSR_ProcessState.Conn_State) { case SR_Conn_PowerOff: { if(!gtsSR_ProcessState.CellInitDone) { at_host_at_socket_write(AT_CEREG_2, sizeof(AT_CEREG_2)); } else { at_host_at_socket_write(AT_CFUN_1, sizeof(AT_CFUN_1)); } } break; case SR_Conn_CellReg: { if(gtsSR_ProcessState.ConnInitFlg) { gtsSR_ProcessState.Conn_State = SR_Conn_ResolveDNS; } else { gtsSR_ProcessState.Conn_State = SR_Conn_CellIdle; } } break; case SR_Conn_CellIdle: { if(gtsSR_ProcessState.ConnInitFlg) { gtsSR_ProcessState.Conn_State = SR_Conn_ResolveDNS; } } break; case SR_Conn_ResolveDNS: { if(gtsSR_ProcessState.ConnInitFlg) { int err = SR_ResolveServerURL(); if(0 == err) { gtsSR_ProcessState.ConnInitFlg = false; gtsSR_ProcessState.Conn_State = SR_Conn_Connected; } else { gtsSR_ProcessState.ConnInitFlg = false; gtsSR_ProcessState.Conn_State = SR_Conn_CellIdle; } memset(ui8buffer, 0, sizeof(ui8buffer)); sprintf(ui8buffer,"SR+CONN=%d\r\n",err); at_uart_send(uart_dev, ui8buffer,strlen(ui8buffer)); memset(SR_UART_txbuff, 0, sizeof(SR_UART_txbuff)); sprintf(SR_UART_txbuff, "Parsed ServerURL: %s, Parsed ServerPort: %d\r\n", gtsBridgeParam.ServerURL, gtsBridgeParam.ServerPort); at_uart_send(uart_dev, SR_UART_txbuff, strlen(SR_UART_txbuff)); } } break; } } void at_uart_send(struct device *uart_dev, const u8_t *tx_data, int size) { for(uint32_t ui32Idx = 0; ui32Idx < size; ui32Idx++) { uart_poll_out(uart_dev, tx_data[ui32Idx]); } } static void isr(struct device *x) { uint32_t lu32_len; uint8_t data_buf[SR_UART_RRB_SIZE]; uart_irq_update(x); if (uart_irq_rx_ready(x)) { lu32_len = uart_fifo_read(x, data_buf, SR_UART_RRB_SIZE); RingBuffer_InsertMult(&SR_UART_rxring, data_buf, lu32_len); gtsSR_ProcessState.UARTRxStartFlg = true; // Start Inter Character Timer gtsSR_ProcessTMR.UARTRxGetTimeMS = 0; } } int at_uart_init(char *uart_dev_name) { int err; // Ringbuffer init memset(SR_UART_rxRingbuff, 0, sizeof(SR_UART_rxRingbuff)); RingBuffer_Init(&SR_UART_rxring, SR_UART_rxRingbuff, 1, SR_UART_RRB_SIZE); RingBuffer_Flush(&SR_UART_rxring); uart_dev = device_get_binding(uart_dev_name); if (uart_dev == NULL) { LOG_ERR("Cannot bind %s\n", uart_dev_name); return EINVAL; } err = uart_err_check(uart_dev); if (err) { LOG_ERR("UART check failed\n"); return EINVAL; } uart_irq_rx_enable(uart_dev); uart_irq_callback_set(uart_dev, isr); return err; } void SR_UartParser(void) { volatile unsigned int bytes = 0; char *resultptr = NULL; int err; memset(SR_UART_rxbuff, 0, sizeof(SR_UART_rxbuff)); bytes = RingBuffer_PopMult(&SR_UART_rxring, &SR_UART_rxbuff[0], SR_UART_RRB_SIZE); if(bytes <= 0) { gtsSR_ProcessState.UARTMsgParseFlg = false; // Clear UART Parsing flag return; } // at_host_at_socket_write(SR_UART_rxbuff, bytes); // printf("RxLen: %d, Rx Data: %.*s\r\n", bytes, bytes, SR_UART_rxbuff); // resultptr = strstr(SR_UART_rxbuff, "SR+CON=\""); if(NULL != resultptr) { resultptr += strlen("SR+CON=\""); memset(>sBridgeParam.ServerURL[0], 0, sizeof(gtsBridgeParam.ServerURL)); u8_t lu8_UrlIdx = 0; while(('"' != *resultptr) && ((sizeof(gtsBridgeParam.ServerURL) - 1) > lu8_UrlIdx)) { gtsBridgeParam.ServerURL[lu8_UrlIdx++] = *resultptr++; } resultptr++; resultptr++; gtsBridgeParam.ServerPort = atoi(resultptr); if(gtsBridgeParam.ServerSocketFd) { memset(SR_UART_txbuff, 0, sizeof(SR_UART_txbuff)); sprintf(SR_UART_txbuff, "Closing opened socket\r\n"); at_uart_send(uart_dev, SR_UART_txbuff, strlen(SR_UART_txbuff)); err = close(gtsBridgeParam.ServerSocketFd); if(err) { memset(SR_UART_txbuff, 0, sizeof(SR_UART_txbuff)); sprintf(SR_UART_txbuff, "socket close error:%d %s\r\n", err, strerror(errno)); at_uart_send(uart_dev, SR_UART_txbuff, strlen(SR_UART_txbuff)); return; } } gtsSR_ProcessState.ConnInitFlg = true; gtsSR_ProcessState.Conn_State = SR_Conn_CellIdle; } else { resultptr = strstr(SR_UART_rxbuff, "SR+MSG="); if(NULL != resultptr) { if(SR_Conn_Connected == gtsSR_ProcessState.Conn_State) { resultptr = strtok(SR_UART_rxbuff, "="); resultptr += strlen("SR+MSG="); uint32_t msglen = atoi(resultptr); resultptr = strtok(NULL, "\""); resultptr = strtok(NULL, "\""); uint32_t EncodedMsgLen = strlen(resultptr); memset(SR_UART_rxbuffbase64, 0, sizeof(SR_UART_rxbuffbase64)); if(SUCCESS != Decrypt_Base_64_Data((char *)resultptr, EncodedMsgLen, SR_UART_rxbuffbase64, sizeof(SR_UART_rxbuffbase64))) { return; } int err = SR_ServerSendData(SR_UART_rxbuffbase64, msglen, 0); memset(SR_UART_txbuff, 0, sizeof(SR_UART_txbuff)); sprintf(SR_UART_txbuff, "Decoded Rxed Data Len: %d\r\nDecoded Rxed Data:", msglen); uint8_t len = strlen(SR_UART_txbuff); memcpy(&SR_UART_txbuff[strlen(SR_UART_txbuff)], SR_UART_rxbuffbase64, msglen); at_uart_send(uart_dev, SR_UART_txbuff, len + msglen); } } else { resultptr = strstr(SR_UART_rxbuff, "SR+RSSI?"); if(NULL != resultptr) { } else { resultptr = strstr(SR_UART_rxbuff, "SR+CELL?"); if(NULL != resultptr) { memset(SR_UART_rxbuffbase64, 0, sizeof(SR_UART_rxbuffbase64)); if(gtsSR_ProcessState.RegistrationStatus) { sprintf(SR_UART_rxbuffbase64, "SR+CELL=1\r\n"); } else { sprintf(SR_UART_rxbuffbase64, "SR+CELL=0\r\n"); } at_uart_send(uart_dev, SR_UART_rxbuffbase64, strlen(SR_UART_rxbuffbase64)); } else { at_uart_send(uart_dev, SR_UART_rxbuff, bytes); } } } } } void linux_NBIoT_write(struct device *uart_dev, unsigned char* buffer, int len) { memset(SR_UART_txbuff, 0, sizeof(SR_UART_txbuff)); sprintf(SR_UART_txbuff, "SR+MSG=%u,\"",len); if(SUCCESS != Encrypt_Base_64_Data((char *)buffer, len, &SR_UART_txbuff[strlen(SR_UART_txbuff)], sizeof(SR_UART_txbuff) - strlen(SR_UART_txbuff))) { return; } sprintf(&SR_UART_txbuff[strlen(SR_UART_txbuff)],"\""); at_uart_send(uart_dev, SR_UART_txbuff, strlen(SR_UART_txbuff)); }
/* * Copyright (c) 2018 Nordic Semiconductor ASA * * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic */ #include <net/socket.h> #include <stdio.h> #include <string.h> #include <uart.h> #include <zephyr.h> #include "SR_Main.h" #define HTTP_HOST "google.com" #define HTTP_PORT 80 #define RECV_BUF_SIZE 1024 tsBridgeParam gtsBridgeParam = {0}; tsSR_ProcessState gtsSR_ProcessState = {0}; tsSR_ProcessTMR gtsSR_ProcessTMR = {0}; extern struct device *uart_dev; char recv_buf[RECV_BUF_SIZE + 1]; const char *at_commands[] = { "AT+CGMM", "AT+CGDCONT?", "AT%XCBAND=?", "AT+CGSN=1", "AT+CESQ", "AT+CEREG=2", "AT+COPS?", /* Add more here if needed */ }; uint8_t SR_UART_txbuff1[1000]; int blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags) { int err; do { err = recv(fd, buf, size, flags); } while (err < 0 && errno == EAGAIN); return err; } int blocking_send(int fd, u8_t *buf, u32_t size, u32_t flags) { int err; do { err = send(fd, buf, size, flags); } while (err < 0 && errno == EAGAIN); return err; } int blocking_connect(int fd, struct sockaddr *local_addr, socklen_t len) { int err; do { err = connect(fd, local_addr, len); } while (err < 0 && errno == EAGAIN); return err; } void app_socket_start(void) { int at_socket_fd = socket(AF_LTE, 0, NPROTO_AT); printk("Starting simple AT socket application\n\r"); if (at_socket_fd < 0) { printk("Socket err: %d, errno: %d\r\n", at_socket_fd, errno); } for (int i = 0; i < ARRAY_SIZE(at_commands); i++) { int bytes_written = send(at_socket_fd, at_commands[i], strlen(at_commands[i]), 0); if (bytes_written > 0) { int r_bytes = blocking_recv(at_socket_fd, recv_buf, sizeof(recv_buf), MSG_DONTWAIT); if (r_bytes > 0) { printk("%s", recv_buf); } } } printk("Closing socket\n\r"); (void)close(at_socket_fd); } static int SR_Main_PowerUpInit(void) { int err; err = at_uart_init(CONFIG_UART_0_NAME); if (err != 0) { //printf("ERROR: UART not initialized \r\n"); return -1; } err = at_socket_init(); if(err < 0) { //printf("ERROR: AT_Socket not initialized \r\n"); return -1; } SR_Timer_Init(); return 1; } int main(void) { static uint32_t su32_Tick; int err; err = SR_Main_PowerUpInit(); if(err < 0) { printf("ERROR: SR_Main_PowerUpInit.\r\n"); while(1); } printf("SUCCESS: SR_Main_PowerUpInit.\r\n"); while (1) { if(gtsSR_ProcessState.UARTMsgParseFlg) { SR_UartParser(); gtsSR_ProcessState.UARTMsgParseFlg = false; // Clear UART Parsing flag } at_host_at_socket_read(); SR_Cellular_Process(); if(gtsSR_ProcessState.SecFlg) { su32_Tick++; if(0 == (su32_Tick % 60)) { //printf("Tick: %u\r\n", su32_Tick); } gtsSR_ProcessState.SecFlg = false; } } } //#include <zephyr.h> //#include <stdio.h> //#include <uart.h> //#include <string.h> //#include <at_host.h> // //void main(void) //{ // int err; // // printf("The AT host sample started\n"); // // err = at_host_init(CONFIG_AT_HOST_UART, CONFIG_AT_HOST_TERMINATION); // // if (err != 0) { // printf("ERROR: AT Host not initialized \r\n"); // return; // } // // while (1) { // at_host_process(); // } //}
