Save data to application data area and share with bootloader
Hi all,
I using nrf52832 , sdk 15.1
- My app include : application + bootloader + application data area
- application define  appliation data area is 12K byte (FDS_VIRTUAL_PAGES 3 , FDS_VIRTUAL_PAGE_SIZE 1024)
- bootloader define NRF_DFU_APP_DATA_AREA_SIZE 12288 (12K)
- My application using FDS to save data to application data area.
- In my bootloader, I want to read this data from application data.
My problem :
- In bootloader , nrf_dfu_flash already has a fstorage instance that conflicts if I add FDS library to bootloader.
- When my app start, it consume a large current , I suspect that the flash reading process caused this. Because in my application, I init fds and read data from flash. I supply this device by one pin CR2032, my requirement is this device run in 2 years. But when pin < 2.6V , chip can't start because current start is big , it falls into a state that I don't know but this state consume current very fast. It very bad for me.
- When I save data to application data area, and restart to bootloader, Bootloader can override data to this area. I want to avoid this. So How to calculate a application data satisfy the conditions : application can save, remain when reset, not override by bootloader, bootloader can read, and when  update firmware, It not be erase by this process.
Please answer my question .
Thank !!!
     What error code/message did you get? Did you create a new fstorage instance ?
     Where are you saving the application data? Note that the Peer Manager uses FDS to store bond information at the already reserved pages(FDS_VIRTUAL_PAGES). If you want to store your your own data, you need to increase NRF_DFU_APP_DATA_AREA_SIZE.
