I will like to know if the nRF52832 is capable of working properly when placed in series with a 30 Ohms Resistor ( which is the battery resistance for our application) at a supply battery voltage between 2 V and 3 V.
Thank you.
Thank you.
How much current does your application draw? If we use 15mA as an example, this gives us 450mV
From the power-on reset chapter in nRF52832 Product Spec:
"A step increase in supply voltage of 300 mV or more, with rise time of 300 ms or less, within the valid supply range, may result in a system reset"
This means that it most likely will not work properly.
Oeyvind
