NRF52832 ADC sampling mode
my ADC work in this mode :timer+PPI+SAADC   the ADC is 12bit
I init ADC like these code
void saadc_init(void)
    ret_code_t err_code;
    nrf_saadc_channel_config_t channel0_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);// PIN and Channel config
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);// add callback funtion
    err_code = nrf_drv_saadc_channel_init(0, &channel0_config);//init channel
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAMPLES_IN_BUFFER);//set convert buffer
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAMPLES_IN_BUFFER);
sample every data 15us,and 16 data per channel
I only init one channel,and use the switch funtion to switch channel.the code like these
void ADC_swc(uint8_t channel)
	switch(channel)
		case 0:nrf_saadc_channel_input_set(0,NRF_SAADC_INPUT_AIN0,NRF_SAADC_INPUT_DISABLED);break;
		case 1:nrf_saadc_channel_input_set(0,NRF_SAADC_INPUT_AIN1,NRF_SAADC_INPUT_DISABLED);break;
		case 2:nrf_saadc_channel_input_set(0,NRF_SAADC_INPUT_AIN2,NRF_SAADC_INPUT_DISABLED);break;
		case 3:nrf_saadc_channel_input_set(0,NRF_SAADC_INPUT_AIN3,NRF_SAADC_INPUT_DISABLED);break;
		case 4:nrf_saadc_channel_input_set(0,NRF_SAADC_INPUT_AIN4,NRF_SAADC_INPUT_DISABLED);break;
		case 5:nrf_saadc_channel_input_set(0,NRF_SAADC_INPUT_AIN5,NRF_SAADC_INPUT_DISABLED);break;
		case 6:nrf_saadc_channel_input_set(0,NRF_SAADC_INPUT_AIN6,NRF_SAADC_INPUT_DISABLED);break;
		case 7:nrf_saadc_channel_input_set(0,NRF_SAADC_INPUT_AIN7,NRF_SAADC_INPUT_DISABLED);break;
		default:;break;
I found if I connect VCC to the ADC channel 1,
(1) the channel1 only first 8 data about 3600 but the later 8 data about 700,
(2) the channel2  is the later 8 data about 3600,first 8 data about 700.
question:I am not connect VCC to channel2,why channel2 have 3600
if I connect VCC to the ADC channel2,I also found the same phenomenon between channel 2 and channel 3
