DFU Bootloader button inverse polarity
I have tested the DFU and everything works fine. Normaly the device enters into DFU mode with a pressed button 7, meaning the level on I/O 7 is LOW.
But in my application I need normal operation with LOW level on button 7 and DFU mode with HIGH level.
So I change the buttons_init function from:
static void buttons_init(void)
 nrf_gpio_cfg_sense_input(BOOTLOADER_BUTTON_PIN, BUTTON_PULL,
 NRF_GPIO_PIN_SENSE_LOW);
to
 nrf_gpio_cfg_sense_input(BOOTLOADER_BUTTON_PIN, NRF_GPIO_PIN_PULLDOWN,
 NRF_GPIO_PIN_SENSE_HIGH);
But it does not work. The device still enter DFU mode with low level on pin7 and start the main application with high level.
Is there more to change?
Thanks a lot and best Regards
