ERROR: No CMD handler!
I added DFU functionality to my Mesh-client application as shown in your DFU-example.
At startup I get this log message:
nrf_mesh_dfu.c,  904, ERROR: No CMD handler!
coming from here:
uint32_t nrf_mesh_dfu_cmd_send(bl_cmd_t* p_cmd)
    if (m_cmd_handler == NULL)
        __LOG(LOG_SRC_DFU, LOG_LEVEL_ERROR, "ERROR: No CMD handler!\n");
        return NRF_ERROR_NOT_SUPPORTED;
Can someone please tell me, what I'm doing wrong here?
(using Mesh SDK 3.1.0 and SDK 15.2)
Regards
Gerry
  • Hello Gerry,
    Well, it seems like you are missing the CMD handler.
    In the DFU example in the Mesh SDK, this is typically set in main()->initialize()->mesh_stack_init()->nrf_mesh_init()->nrf_mesh_dfu_init()->dfu_cmd_handler_set().
    Does this get called in your project?
    BR,
    Edvin
  • Hi Edvin
    I found the place, thanks. Put a breakpoint there. The function is called (Line 643 of nrf_mesh_dfu.c). The return value is NRF_ERROR_NOT_SUPPORTED. Seems to be a problem with BOOTLOADERADDR(). Do I have to set the address in NRF_UICR->NRFFW[0] manually?
    Using Segger Studio. Same message, when I program the device with my script:
    cd pc-nrfutil-mesh_dfu
    cd dfu
    set /a "prior_version=%client_version%-1"
       echo {
       echo     "bootloader_config": {
       echo        "bootloader_id": 1,
       echo        "bootloader_version": 1,
       echo        "company_id": 89,
       echo        "application_id": 1,
       echo        "application_version": %prior_version%
       echo    }
       echo }
     ) > bootloader_config_default.json
    python device_page_generator.py -d nrf52840_xxAA -sd "s140_6.0.0" -o ../client.hex
    cd ..
    @echo:
    nrfjprog --recover -f NRF52
    REM use --verify to verify programming with --program
    nrfjprog --eraseall
    nrfjprog --program ..\..\Mesh_SDK\bin\softdevice\s140_nrf52_6.0.0_softdevice.hex --chiperase
    nrfjprog --program bootloader\mesh_bootloader_serial_gccarmemb_nrf52840_xxAA.hex
    nrfjprog --program ..\..\Source\connectivity_client\build\connectivity_client_Release\connectivity_client.hex
    nrfjprog --program client.hex
    nrfjprog --reset
    Regards Gerry
    No, you shouldn't write to this address yourself. This address is written by the bootloader itself. If you program the bootloader (found in SDK_for Mesh\bin\bootloader\gccarmemb\<your suitable bootloader>.hex) this value will contain the correct data.
    Can you try this?
    Edvin
    I think, this should be done on line 22 of my script:
    The CMD output of my script looks as follows:
    Wrote device page for nrf52840_xxAA with the s140_6.0.0 SoftDevice to ../client.hex.
    Recovering device. This operation might take 30s.
    Erasing user code and UICR flash areas.
    Erasing user available code and UICR flash areas.
    Applying system reset.
    Parsing hex file.
    Checking that the area to write is not protected.
    Programming device.
    Parsing hex file.
    Reading flash area to program to guarantee it is erased.
    Programming device.
    Parsing hex file.
    Programming device.
    Parsing hex file.
    Programming device.
    Run.
    The RTT-output, when the program starts:
     0> <t:          0>, main.c,   44, ___ Connectivity start client _________
     0> <t:          0>, mesh.c,  649, rom_base   26101
     0> <t:          0>, mesh.c,  650, rom_end    43A90
     0> <t:          0>, mesh.c,  651, rom_length 1D98F
     0> <t:          0>, mesh.c,  652, bank_addr   44000
     0> <t:       8223>, mesh.c,  673, Initializing mesh stack
     0> <t:       8705>, mesh.c,  696, Initializing and adding models
     0> <t:       8707>, mesh.c,  361, Setting up access layer and models
     0> <t:      18344>, nrf_mesh_dfu.c,  904, ERROR: No CMD handler!
     0> <t:      18690>, flash.c,  113, Read settings from flash
     0> <t:      18692>, flash.c,  115, provisioned_devices: 0
     0> <t:      18695>, flash.c,  116, next_unprov_address: 500
     0> <t:      18697>, flash.c,  117, next_unprov_index: 0
     0> <t:      18699>, flash.c,  118, node_count: 0
     0> <t:      18701>, flash.c,  119, network key: E.....4D
     0> <t:      18793>, main.c,   53, ___ Connectivity client initialized ___
     So still "ERROR: No CMD handler!" Can you see, what's going wrong here?
     Regards
        Gerry
    Can you please try to add --verify on the end of all your nrfjprog --program commands in your script?
    Also, can you do a flashdump after programming your nRF?
    You can use:
    nrfjprog --readcode my_flash_dump.txt
    And upload it here?
    BR,
    Edvin
