Add PWM library to freeRTOS (ble_app_hrs_freertos) example
Hi Sir/Miss,
I use below items to develop:
HW  : PCA10040 (nRF52832)
SDK: 15.2
Softdevice : s132
IDE  : SES V3.40
After I create my task (two same priority tasks to use GPIO to show clock tick), I want to add PWM library to freeRTOS.
I add nrf_drv_ppi.c, nrfx_ppi.c, nrfx_timer.c and app_pwm.c file to project and enable APP_PWM_ENABLED, TIMER_ENABLED, TIMER0_ENABLED, TIMER1_ENABLED, NRFX_PPI_ENABLED, PPI_ENABLED in sdk_config.h.
And setup the function like PWM library example code (just change 2 to 1 channel )
static volatile bool ready_flag;            // A flag indicating PWM status.
void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
    ready_flag = true;
//  PWM initial
void PWM_Init(void)
    //  for PWM initial, include "app_pwm.c", "nrfx_timer.c", "nrf_drv_ppi.c", "nrfx_ppi.c", "nrf_nvic.c", "nrf_soc.c"
    ret_code_t err_code;
    //  buzzer PWM initial
    APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(250L, buzzer_PWM_pin);
    //  Initialize and enable PWM
    err_code = app_pwm_init(&PWM1, &pwm1_cfg, pwm_ready_callback);
    app_pwm_enable(&PWM1);
And compiler it, SES doesn't display any error.
But, two tasks use GPIO that voltage is not correct. It has a 1.36V offset.
I check system on terminal. It shows fatal error and system reset, and setup breakpoint to check PWM initial err_code.
Err_code is 0x10001000.
I don't know what's meaning, and how to find error code list?
If I mistake on these step, please correct me.
Thank you.
