Hey everyone, I'm having an issue communicating with a QSPI flash on a custom development board, using the nRF52840. The flash is a Winbond W25Q16JVSSIQ. Schematic and pins used are the same as the nRF52840 DK and as far as I can tell, the flash I'm using uses the same commands as the default defines. I've been at this for a whole day and don't have much hair left to pull out. I've checked and double checked the hardware and it looks good to me, I have connectivity from the module to the flash.
The device seems to initialize ok, there are no errors returned from nrfx_qspi_init, but I can't get nrfx_qspi_cinstr_xfer to return anything other than 0... I've tried every combo of 'length' and tx/rx string lengths I can come up with, I just can't wrap my head around how this is supposed to work. I also never get a finished flag when doing nrfx_qspi_write. If I just don't wait, nrfx_qspi_read gives me a BUSY error.
Any help anyone can offer is much appreciated. I fought my way though getting an ADC, UART, and BLE set up, but this is killing me!
Here's my defines and function:
#define QSPI_STD_CMD_MFG_DEV_ID 0x94 #define QSPI_STD_CMD_WRSR 0x01 #define QSPI_STD_CMD_RSTEN 0x66 #define QSPI_STD_CMD_RST 0x99 #define QSPI_RX_BUFFER_SIZE 10 #define SAMPLES_IN_BUFFER 10 //used to buffer adc readings, and also to size the qspi tx buffer static volatile bool m_qspi_finished = false; static uint8_t m_qspi_buffer_tx[SAMPLES_IN_BUFFER]; static uint8_t m_qspi_buffer_rx[QSPI_RX_BUFFER_SIZE]; //this will also be the BLE transmit package size/2
static void qspi_handler(nrfx_qspi_evt_t event, void * p_context)
UNUSED_PARAMETER(event);
UNUSED_PARAMETER(p_context);
m_qspi_finished = true;
static void qspi_init(void){
uint32_t err_code;
static uint8_t temp_rx_buf[9];
static uint8_t temp_tx_buf[9];
nrfx_qspi_config_t config = NRFX_QSPI_DEFAULT_CONFIG;
err_code = nrfx_qspi_init(&config, qspi_handler, NULL);
nrf_qspi_cinstr_conf_t cinstr_cfg = {
.opcode = QSPI_STD_CMD_MFG_DEV_ID,
.length = NRF_QSPI_CINSTR_LEN_9B,
.io2_level = true,
.io3_level = true,
.wipwait = true,
.wren = true
err_code = nrfx_qspi_cinstr_xfer(&cinstr_cfg, temp_tx_buf, temp_rx_buf);
printf("qspi_init mfg id: %d device id: %d\r\n", temp_rx_buf[7], temp_rx_buf[8]);
temp_tx_buf[0] = 69;
err_code = nrfx_qspi_write(temp_tx_buf, 1, 0);
printf("nrfx_qspi_write err_code %d\r\n", err_code);
//APP_ERROR_CHECK(err_code);
while (!m_qspi_finished);
err_code = nrfx_qspi_read(temp_rx_buf, 1, 0);
printf("nrfx_qspi_read err_code %d\r\n", err_code);
printf("Test Data: %d \r\n", temp_rx_buf[0]);
Here's the sdk_config lines:
// <e> NRFX_QSPI_ENABLED - nrfx_qspi - QSPI peripheral driver //========================================================== #ifndef NRFX_QSPI_ENABLED #define NRFX_QSPI_ENABLED 1 #endif // <o> NRFX_QSPI_CONFIG_SCK_DELAY - tSHSL, tWHSL and tSHWL in number of 16 MHz periods (62.5 ns). <0-255> #ifndef NRFX_QSPI_CONFIG_SCK_DELAY #define NRFX_QSPI_CONFIG_SCK_DELAY 1 #endif // <o> NRFX_QSPI_CONFIG_XIP_OFFSET - Address offset in the external memory for Execute in Place operation. #ifndef NRFX_QSPI_CONFIG_XIP_OFFSET #define NRFX_QSPI_CONFIG_XIP_OFFSET 0 #endif // <o> NRFX_QSPI_CONFIG_READOC - Number of data lines and opcode used for reading. // <0=> FastRead // <1=> Read2O // <2=> Read2IO // <3=> Read4O // <4=> Read4IO #ifndef NRFX_QSPI_CONFIG_READOC #define NRFX_QSPI_CONFIG_READOC 4 #endif // <o> NRFX_QSPI_CONFIG_WRITEOC - Number of data lines and opcode used for writing. // <0=> PP // <1=> PP2O // <2=> PP4O // <3=> PP4IO #ifndef NRFX_QSPI_CONFIG_WRITEOC #define NRFX_QSPI_CONFIG_WRITEOC 2 #endif // <o> NRFX_QSPI_CONFIG_ADDRMODE - Addressing mode. // <0=> 24bit // <1=> 32bit #ifndef NRFX_QSPI_CONFIG_ADDRMODE #define NRFX_QSPI_CONFIG_ADDRMODE 0 #endif // <o> NRFX_QSPI_CONFIG_MODE - SPI mode. // <0=> Mode 0 // <1=> Mode 1 #ifndef NRFX_QSPI_CONFIG_MODE #define NRFX_QSPI_CONFIG_MODE 0 #endif // <o> NRFX_QSPI_CONFIG_FREQUENCY - Frequency divider. // <0=> 32MHz/1 // <1=> 32MHz/2 // <2=> 32MHz/3 // <3=> 32MHz/4 // <4=> 32MHz/5 // <5=> 32MHz/6 // <6=> 32MHz/7 // <7=> 32MHz/8 // <8=> 32MHz/9 // <9=> 32MHz/10 // <10=> 32MHz/11 // <11=> 32MHz/12 // <12=> 32MHz/13 // <13=> 32MHz/14 // <14=> 32MHz/15 // <15=> 32MHz/16 #ifndef NRFX_QSPI_CONFIG_FREQUENCY #define NRFX_QSPI_CONFIG_FREQUENCY 15 #endif // <s> NRFX_QSPI_PIN_SCK - SCK pin value. #ifndef NRFX_QSPI_PIN_SCK #define NRFX_QSPI_PIN_SCK 19 #endif // <s> NRFX_QSPI_PIN_CSN - CSN pin value. #ifndef NRFX_QSPI_PIN_CSN #define NRFX_QSPI_PIN_CSN 17 #endif // <s> NRFX_QSPI_PIN_IO0 - IO0 pin value. #ifndef NRFX_QSPI_PIN_IO0 #define NRFX_QSPI_PIN_IO0 20 #endif // <s> NRFX_QSPI_PIN_IO1 - IO1 pin value. #ifndef NRFX_QSPI_PIN_IO1 #define NRFX_QSPI_PIN_IO1 21 #endif // <s> NRFX_QSPI_PIN_IO2 - IO2 pin value. #ifndef NRFX_QSPI_PIN_IO2 #define NRFX_QSPI_PIN_IO2 22 #endif // <s> NRFX_QSPI_PIN_IO3 - IO3 pin value. #ifndef NRFX_QSPI_PIN_IO3 #define NRFX_QSPI_PIN_IO3 23 #endif // <o> NRFX_QSPI_CONFIG_IRQ_PRIORITY - Interrupt priority // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 // <4=> 4 // <5=> 5 // <6=> 6 // <7=> 7 #ifndef NRFX_QSPI_CONFIG_IRQ_PRIORITY #define NRFX_QSPI_CONFIG_IRQ_PRIORITY 6 #endif // </e>
Here are the command tables from the Flash data sheet:
