HI,
I intent to move a project from 52832 to 52810,but the flash size of 52810 is only 192k.so I want to know the flash layout(bootloader included) of 52810 like 52832 as follows:
HI,
Hi.
I'm a bit unsure what you mean by this question.
The "Flash layout" is the same, the available space is not.
Are you still using S132? Or are you going to use S112? The start addresses of the different SoftDevices can be found here.
If you are using S132 then I doubt you will be able to fit a bootloader as well.
Andreas
