Can't read a button state using: bsp_board_button_state_get()
Hi, i'm starting to develop on the nrf52840DK and trying to understand the Nordic SDK (using the lastest version at the time 15.3). Just edited the blinky example to read a button, if it's pressed a led goes on, my intention was to create the simplest program to achieve this but the led is always on and the button does nothing, my question is why?
#include <stdbool.h>
#include <stdint.h>
#include "nrf_delay.h"
#include "boards.h"
 * @brief Function for application main entry.
    /* Configure board. */
    bsp_board_init(BSP_INIT_LEDS || BSP_INIT_BUTTONS);
    bsp_board_led_off(3);
    while (true)
        if (bsp_board_button_state_get(1)) {
              bsp_board_led_on(3);
    I recommend looking at the Pin Change Interrupt Example.  This example configures PIN_IN pin for input, PIN_OUT pin for output, and configures GPIOTE to give an interrupt on pin change. This way your code will not be polling for pin change.
    Øyvind
  • Hi, i know that is a very inefficient program without the use of interrupts but i'm trying to use some basic and low level functions of the SDK an then go to interrupts, debounce, etc.
    I really can't understand what is wrong with the code above. The use of led functions work fine but buttons don't.
    Thanks for your answer.
    Ok, I see what you mean. I have a simple code, polling Button 1 for change, based on the blinky example and using the nrf_gpio library.
     * @defgroup blinky_example_main main.c
     * @ingroup blinky_example
     * @brief Blinky Example Application main file.
     * This file contains the source code for a sample application to blink LEDs.
    #include <stdint.h>
    #include "boards.h"
        //Configure LED 3 as output
        nrf_gpio_cfg_output(LED_3);
        //Configure Button 2 as input, active low
        nrf_gpio_cfg_input(BUTTON_2, NRF_GPIO_PIN_PULLUP);
        while (1)
            if (nrf_gpio_pin_read(BUTTON_2) == false)
                nrf_gpio_pin_toggle(LED_3);
                //Debounce delay
                //nrf_delay_ms(100);
      The problem is the init function. When doing it like this, it works as intended and exactly the same as above:
        //bsp_board_init(BSP_INIT_LEDS && BSP_INIT_BUTTONS);
        bsp_board_init(BSP_INIT_BUTTONS);
        while (true)
                  bsp_board_led_invert(3);
  • The error in my original code was a C syntax error, i was using the logical operator "||" instead of the bitwise operator "|" for the init flags. A silly mistake i couldn't see.
    Thanks for your support, i like the DevZone.
