How optimize high current consumption in sleep mode using nRF52840?
Hello to all,
We have developed our application & the following platform we are using:
  • SDK 15.0, Segger IDE on windows PC
  • Softdevice version is 6.0.0
  • Hardware version nRF52840 SoC.
  • Our product is battery operated, so high power consumption is serious an issue for us.
In our application we have used ble_app_uart example with SAADC because our sensor is analog. We also made custom PCB using nRF52840 and it working well not an issue. But our problem is very too much high current consumption is sleep mode means system OFF mode.
Here is below measured analysis with the help of Nordic Power Profile kit:
  1. The average current consumption while advertising is 962uA - 1.62mA I think this is OK.
  2. The average current consumption when sensor device enter into sleep mode is 562uA (Which is very high)
We have disabled all used peripheral before enter device into sleep mode as like below:
void sleep_mode_enter() {
  uint32_t err_code;
  NRF_LOG_INFO("Sleep mode Enter");
  flash_data_sending = false;
  start_measurement = false;
  nrf_gpio_pin_clear(SENSOR_PIN);  // OFF Sensor
  nrf_gpio_pin_set(GREEN_LED_PIN); // OFF Green LED
  nrf_gpio_pin_set(BLUE_LED_PIN);  // OFF BLUE LED
  stop_adc();
  err_code = app_uart_close();
  NRF_LOG_INFO("UART close: %d", err_code);
void stop_adc() {
  nrf_drv_timer_disable(&m_timer);
  nrf_drv_timer_uninit(&m_timer);
  nrf_drv_ppi_channel_disable(m_ppi_channel);
  nrf_drv_ppi_uninit();
  NRF_SAADC->TASKS_STOP = 1;
  nrf_drv_saadc_uninit();
We have tested our hardware and sure this not hardware problem because when our device enter into deep sleep mode system OFF that time the current consumption near about 0.7uA to 1uA. Even when our designed firmware upload into nRF52840 DK and measured consumption using PPK that time got same results.
Questions:
  1. Why this too much very high power consumption getting in sleep mode?
  2. Is any wrong in our sleep mode enter function and disabled module functions?
Will you please suggest any solution, We should need to optimize this consumption to increase battery life because our sensor devices is battery operated.
Looking forward your response..!!
Thanks in advanced..!!
  • You are correct, I'll edit the reply to avoid confusion. Thanks for the heads up.
    Simon
  • hi vishal i am also having the issue with sleep mode so can you contact me through email: [email protected]
    Actually i had current consumption of about 0.92ma in sleep and i disabled uart so that current reduced to 0.5 ma. After i read some  post devzone said that disabling ble_radio also reduces the power consumption. i did that by calling sd_ble_gap_adv_stop() and sleep current was 3uA average. Now after some days i did some modification in code again sleep current went to 0.92mA.
    i revert back to 3uA changes but still i could able to get the desired current consumption even i try in new SDK example.
  • Hi Simonr,
    Sorry for late reply I was busy for implementing other functionality.
    Now this time to solve this Issue, I have tried above but still getting same problem not able to ON and OFF UART module whenever I want to need.
    I have tried below for disabled UART:
    uart_init() for enabled uart but not reduce power consumption.
    Will please let me any other option I am usinf SDK 15.0 version. nRF52840 SoC.
    Thanks..
  • Hi Vishal
    Have you gone through your project to make sure that you're only using UART and not UARTE? I still think you are mixing these two functions. Also, do you at any point disable the radio? This can be done by for example calling sd_ble_gap_adv_stop(). Have you tried this? Sorry if I'm getting some details wrong, but it's been quite some time since the last time I looked at this case, so please tell me if I got something wrong.
    Simon
  • Hi Simonr,
    I have check in my project sdk_config.h setting
    #define NRFX_UARTE_ENABLED 0
    #define NRFX_UART_ENABLED 1
    #define UART_ENABLED 1
    Yes I have disabled radio by calling sd_ble_gap_adv_stop(). Radio is disabled no any issue. But problem getting of UART.
    I am still facing this issue. Should I need to migrate my project in SDK 15.3 Version? Any other solution.
    Thanks...
