board version pca10040
softdevice s132
sdk 15.3.1
ic nrf52832
softdevice s132
sdk 15.3.1
ic nrf52832
May I have more information about this case with the following questions:
BBBB Private
Amanda
I had the same error and it was solved by using nRF Connect or the latest nrfjprog to program instead of nRFgo Studio. I don't know if it is the same problem as yours.
https://devzone.nordicsemi.com/f/nordic-q-a/44768/sdk-15-3-cannot-program-default-bootloader
In SDK v15.3 we changed the bootloader start address register (NRF_UICR_BOOTLOADER_START_ADDRESS) from NRF_UICR_BASE + 0x14 in the UICR to MBR_BOOTLOADER_ADDR (at 0xFF8) in the MBR.
So to write the start address of the bootloader, you need to write into the MBR (This is to help improving security for the bootloader)
This causes the issue that you experienced. The tool will have trouble writing to the MBR/Softdevice area.
The workaround is to do an erase all, write the MBR/Softdevice and then flash the bootloader without sector erase.
If you don't want to do an erase all every time you write the bootloader, you can comment out what inside nrf_bootloader_info.c on the second time you write the bootloader so that the programmer would not write to the MBR.
Or you can merge the MBR/softdevice to your application and then flash with sectorerase.
Please use nRFConnect for desktop instead. See also this thread and this thread.
I just downloaded 15.3 and my nrf_bootloader_info.c seems to still place the bootloader address in UICR:
volatile uint32_t m_uicr_bootloader_start_address __attribute__ ((section(".uicr_bootloader_start_address")))
= BOOTLOADER_START_ADDR;
Is there an example for how to load the bootloader address into the flash location?
EDIT: Just looking in the linker script:
uicr_bootloader_start_address (r) : ORIGIN = 0x00000FF8, LENGTH = 0x4
it looks like the location of uicr_bootloader_start_address changed to be 0xFF8 but the name did not change (even though it is called uicr_bootloader_start_address, it is no longer in the UICR?)
