nrf51422 don't run on the second time
Hi, I have a wired problem with the nrf51422,
I'm loading the code using the J-link into my board or the evaluation board (PCA10007) that I have, the code runs perfect without any errors/warnings.
but after I disconnect the debugger, power off the board and turn it on back again , the board don't run...
I'm checking the board using nRF2779 dongle and ANT+ Display simulator V1.900 in HRM Display mode, in working mode I can see the packets and also to see the heart rate.
I've thought maybe the problem came from my code, so I've tried to run ant_hrm_tx example code, I've update is the system clock to NRF_CLOCK_LFCLKSRC_RC_250_PPM and the HRMTX_NETWORK_KEY to {0xB9, 0xA5, 0x21, 0xFB, 0xBD, 0x72, 0xC3, 0x45}
Did I missed something?
    ANT stack would not work if the LF clock tolerance is higher than +-50ppm (page 18 in nRF51422 Product Spec). You would need to use an external crystal with tolerance of <+-50ppm for ANT protocol.
    Do you have the same issue with our PCA10007 ?
