In my current zigbee project I have a sensor end device which should sleep when possible. I am handling the ZB_COMMON_SIGNAL_CAN_SLEEP event and have added zb_set_rx_on_when_idle(ZB_FALSE) to main. I am not sure if it makes any difference but this project uses TWIM for sensor communication and the app_timer.
Once the device boots (not previously joined to a network), the device polls until a connection is made with the coordinator. Immediately upon joining the network, the device sleeps indefinitely and commissioning is never completed. During this apparent sleep state debugging appears to continue normally. If zb_set_rx_on_when_idle() is set to ZB_TRUE, the device is able to be commissioned normally.
Included below are the following: zboss_zignal_handler, main, console output showing only LOG INFO output, and finally console output with ZIGBEE_TRACE_LEVEL set to 4.
zb_void_t zboss_signal_handler(zb_uint8_t param) { zb_zdo_app_signal_hdr_t *p_sg_p = NULL; zb_zdo_signal_leave_params_t *p_leave_params = NULL; zb_zdo_app_signal_type_t sig = zb_get_app_signal(param, &p_sg_p); zb_ret_t status = ZB_GET_APP_SIGNAL_STATUS(param); zb_ret_t zb_err_code; switch (sig) { case ZB_BDB_SIGNAL_DEVICE_FIRST_START: case ZB_BDB_SIGNAL_DEVICE_REBOOT: { if (status == RET_OK) { NRF_LOG_INFO("Joined network successfully"); //bsp_board_led_off(LED_2); nrf_gpio_pin_write(LED_1, 1); ret_code_t err_code = app_timer_start(zb_app_timer, APP_TIMER_TICKS(15000), NULL); APP_ERROR_CHECK(err_code); } else { NRF_LOG_ERROR("Failed to join network. Status: %d", status); //bsp_board_led_on(LED_2); nrf_gpio_pin_write(LED_1, 0); zb_err_code = bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING); ZB_COMM_STATUS_CHECK(zb_err_code); //zb_err_code = ZB_SCHEDULE_ALARM(zigbee_leave_and_join, 0, ZB_TIME_ONE_SECOND); //ZB_ERROR_CHECK(zb_err_code); } } break; case ZB_ZDO_SIGNAL_LEAVE: { if (status == RET_OK) { //bsp_board_led_on(LED_2); nrf_gpio_pin_write(LED_1, 0); p_leave_params = ZB_ZDO_SIGNAL_GET_PARAMS(p_sg_p, zb_zdo_signal_leave_params_t); NRF_LOG_INFO("Network left. Leave type: %d", p_leave_params->leave_type); // Retry join. zigbee_retry_join(p_leave_params->leave_type); // Should this equal ZB_NWK_LEAVE_TYPE_RESET? Thus call zigbee_leave_network ret_code_t err_code = app_timer_stop(zb_app_timer); APP_ERROR_CHECK(err_code); } else { NRF_LOG_ERROR("Unable to leave network. Status: %d", status); } } break; case ZB_ZDO_SIGNAL_DEVICE_ANNCE: { zb_zdo_signal_device_annce_params_t * dev_annce_params = ZB_ZDO_SIGNAL_GET_PARAMS(p_sg_p, zb_zdo_signal_device_annce_params_t); NRF_LOG_INFO("Device with a short address %hx commissionned", dev_annce_params->device_short_addr); } break; case ZB_COMMON_SIGNAL_CAN_SLEEP: { zb_zdo_signal_can_sleep_params_t *can_sleep_params = ZB_ZDO_SIGNAL_GET_PARAMS(p_sg_p, zb_zdo_signal_can_sleep_params_t); NRF_LOG_INFO("Can sleep for %ld ms", can_sleep_params->sleep_tmo); zb_sleep_now(); } break; case ZB_ZDO_SIGNAL_PRODUCTION_CONFIG_READY: { if (status != RET_OK) { NRF_LOG_WARNING("Production config is not present or invalid."); } } break; default: // Unhandled signal. For more information see: zb_zdo_app_signal_type_e and zb_ret_e NRF_LOG_INFO("Unhandled signal %d. Status: %d", sig, status); } if (param) { ZB_FREE_BUF_BY_REF(param); } }
int main(void) { zb_ret_t zb_err_code; ret_code_t err_code; zb_ieee_addr_t ieee_addr; init_log(); //lfclock_request(); init_timer(); leds_init(); initBME280(); // Create timer for reporting attribute; err_code = app_timer_create(&zb_app_timer, APP_TIMER_MODE_REPEATED, zb_app_timer_handler); APP_ERROR_CHECK(err_code); // Set Zigbee Stack logging level and traffic dump subsystem ZB_SET_TRACE_LEVEL(ZIGBEE_TRACE_LEVEL); ZB_SET_TRACE_MASK(ZIGBEE_TRACE_MASK); ZB_SET_TRAF_DUMP_OFF(); // Initialize Zigbee stack ZB_INIT("multi_sensor"); // Set device address to the value read from FICR registers zb_osif_get_ieee_eui64(ieee_addr); zb_set_long_address(ieee_addr); // Set static long IEEE address. zb_set_network_ed_role(IEEE_CHANNEL_MASK); zb_set_nvram_erase_at_start(ERASE_PERSISTENT_CONFIG); //zigbee_erase_persistent_storage(ERASE_PRESISTENT_CONFIG); zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN); zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000)); if (nrf_gpio_pin_read(11) == 0) { NRF_LOG_INFO("RX on when idle is false"); zb_set_rx_on_when_idle(ZB_FALSE); } else { NRF_LOG_INFO("RX on when idle is true"); zb_set_rx_on_when_idle(ZB_TRUE); } //Can sleep for 76 ms // Initialize application context structure UNUSED_RETURN_VALUE(ZB_MEMSET(&m_dev_ctx, 0, sizeof(m_dev_ctx))); // Register sensor device context (endpoints) ZB_AF_REGISTER_DEVICE_CTX(&multi_sensor_ctx); // Initialize sensor device attributes multi_sensor_clusters_attr_init(); // Set TX Power nrf_802154_tx_power_set(8); //NRF_LOG_INFO("Current TX power level: %d", nrf_802154_tx_power_get()); // Start Zigbee stack zb_err_code = zboss_start(); ZB_ERROR_CHECK(zb_err_code); //BME280 bme.setSensorSettings(MODE_NORMAL, BME280_OVERSAMPLING_1X, BME280_OVERSAMPLING_1X, BME280_OVERSAMPLING_1X, BME280_FILTER_COEFF_OFF, BME280_STANDBY_TIME_1_MS); while (1) { zboss_main_loop_iteration(); UNUSED_RETURN_VALUE(NRF_LOG_PROCESS()); } }
<info> app: RX on when idle is false <warning> app: Production config is not present or invalid. <error> app: Failed to join network. Status: -1 <error> app: Failed to join network. Status: -1 <error> app: Failed to join network. Status: -1 <error> app: Failed to join network. Status: -1 <error> app: Failed to join network. Status: -1 <info> app: Can sleep for 92 ms
<info> app: RX on when idle is false <info> zboss: 08 00 00 00 DE AD 0E 02|........ <info> zboss: 00 00 0B 00 90 0C 27 01|......'. <info> zboss: 01 00 00 00 DE AD 0A 02|........ <info> zboss: 00 00 0C 00 2B 08 F0 00|....+... <info> zboss: DE AD 0A 02 00 00 0D 00|........ <info> zboss: 2B 08 6A 01 DE AD 1E 02|+.j..... <info> zboss: 00 00 0E 00 AA 01 9E 01|........ <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <warning> app: Production config is not present or invalid. <info> zboss: 00 00 00 00 DE AD 1E 02|........ <info> zboss: 10 00 0F 00 AA 01 9E 01|........ <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 31 00 10 00 2B 08 7A 05|1...+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 31 00 11 00|....1... <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 52 00 12 00 2B 08 7A 05|R...+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 52 00 13 00|....R... <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 52 00 14 00 2B 08 FA 03|R...+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 52 00 15 00 AA 01 9E 01|R....... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 73 00 16 00 2B 08 7A 05|s...+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 73 00 17 00|....s... <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 94 00 18 00 2B 08 7A 05|....+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 94 00 19 00|........ <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 94 00 1A 00 2B 08 FA 03|....+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 94 00 1B 00 AA 01 9E 01|........ <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: B5 00 1C 00 2B 08 7A 05|....+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 B5 00 1D 00|........ <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: D6 00 1E 00 2B 08 7A 05|....+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 D6 00 1F 00|........ <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: D6 00 20 00 2B 08 FA 03|.. .+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: D6 00 21 00 AA 01 9E 01|..!..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: F7 00 22 00 2B 08 7A 05|..".+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 F7 00 23 00|......#. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 18 01 24 00 2B 08 7A 05|..$.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 18 01 25 00|......%. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 18 01 26 00 2B 08 FA 03|..&.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 18 01 27 00 AA 01 9E 01|..'..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 39 01 28 00 2B 08 7A 05|9.(.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 39 01 29 00|....9.). <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 5A 01 2A 00 2B 08 7A 05|Z.*.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 5A 01 2B 00|....Z.+. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 5A 01 2C 00 2B 08 FA 03|Z.,.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 5A 01 2D 00 AA 01 9E 01|Z.-..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 7B 01 2E 00 2B 08 7A 05|{...+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 7B 01 2F 00|....{./. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 9C 01 30 00 2B 08 7A 05|..0.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 9C 01 31 00|......1. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 9C 01 32 00 2B 08 FA 03|..2.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 9C 01 33 00 AA 01 9E 01|..3..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: BD 01 34 00 2B 08 7A 05|..4.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 BD 01 35 00|......5. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: DE 01 36 00 2B 08 7A 05|..6.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 DE 01 37 00|......7. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: DE 01 38 00 2B 08 FA 03|..8.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: DE 01 39 00 AA 01 9E 01|..9..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: FF 01 3A 00 2B 08 7A 05|..:.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 FF 01 3B 00|......;. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 20 02 3C 00 2B 08 7A 05| .<.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 20 02 3D 00|.... .=. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 20 02 3E 00 2B 08 FA 03| .>.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 20 02 3F 00 AA 01 9E 01| .?..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 41 02 40 00 2B 08 7A 05|A.@.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 41 02 41 00|....A.A. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 62 02 42 00 2B 08 7A 05|b.B.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 62 02 43 00|....b.C. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 62 02 44 00 2B 08 FA 03|b.D.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 62 02 45 00 AA 01 9E 01|b.E..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 83 02 46 00 2B 08 7A 05|..F.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 83 02 47 00|......G. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: A4 02 48 00 2B 08 7A 05|..H.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 A4 02 49 00|......I. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: A4 02 4A 00 2B 08 FA 03|..J.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: A4 02 4B 00 AA 01 9E 01|..K..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: C5 02 4C 00 2B 08 7A 05|..L.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 C5 02 4D 00|......M. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: E6 02 4E 00 2B 08 7A 05|..N.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 E6 02 4F 00|......O. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: E6 02 50 00 2B 08 FA 03|..P.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: E6 02 51 00 AA 01 9E 01|..Q..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 07 03 52 00 2B 08 7A 05|..R.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 07 03 53 00|......S. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 28 03 54 00 2B 08 7A 05|(.T.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 28 03 55 00|....(.U. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 28 03 56 00 2B 08 FA 03|(.V.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 28 03 57 00 AA 01 9E 01|(.W..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 49 03 58 00 2B 08 7A 05|I.X.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 49 03 59 00|....I.Y. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 6A 03 5A 00 2B 08 7A 05|j.Z.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 6A 03 5B 00|....j.[. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 6A 03 5C 00 2B 08 FA 03|j.\.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 6A 03 5D 00 AA 01 9E 01|j.]..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 8B 03 5E 00 2B 08 7A 05|..^.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 8B 03 5F 00|......_. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: AC 03 60 00 2B 08 7A 05|..`.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 AC 03 61 00|......a. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: AC 03 62 00 2B 08 FA 03|..b.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: AC 03 63 00 AA 01 9E 01|..c..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: CD 03 64 00 2B 08 7A 05|..d.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 CD 03 65 00|......e. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: EE 03 66 00 2B 08 7A 05|..f.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 EE 03 67 00|......g. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: EE 03 68 00 2B 08 FA 03|..h.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: EE 03 69 00 AA 01 9E 01|..i..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 0F 04 6A 00 2B 08 7A 05|..j.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 0F 04 6B 00|......k. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 30 04 6C 00 2B 08 7A 05|0.l.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 30 04 6D 00|....0.m. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 30 04 6E 00 2B 08 FA 03|0.n.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 30 04 6F 00 AA 01 9E 01|0.o..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 51 04 70 00 2B 08 7A 05|Q.p.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 51 04 71 00|....Q.q. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: 72 04 72 00 2B 08 7A 05|r.r.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 72 04 73 00|....r.s. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: 72 04 74 00 2B 08 FA 03|r.t.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: 72 04 75 00 AA 01 9E 01|r.u..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: 93 04 76 00 2B 08 7A 05|..v.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 93 04 77 00|......w. <info> zboss: 2B 08 E6 05 DE AD 12 02|+....... <info> zboss: B4 04 78 00 2B 08 7A 05|..x.+.z. <info> zboss: EA 00 00 00 00 00 00 00|........ <info> zboss: DE AD 0A 02 B4 04 79 00|......y. <info> zboss: 2B 08 E6 05 DE AD 16 02|+....... <info> zboss: B4 04 7A 00 2B 08 FA 03|..z.+... <info> zboss: 0A 00 00 00 FF FF FF FF|........ <error> app: Failed to join network. Status: -1 <info> zboss: 05 00 00 00 DE AD 1E 02|........ <info> zboss: B4 04 7B 00 AA 01 9E 01|..{..... <info> zboss: 02 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 00 00 00 00|........ <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: D5 04 7C 00 2B 08 7A 05|..|.+.z. <info> zboss: 00 00 00 00 01 00 00 00|........ <info> zboss: DE AD 16 02 D5 04 7D 00|......}. <info> zboss: 45 01 1D 01 9F 29 00 00|E....).. <info> zboss: 0B 00 00 00 00 00 00 00|........ <info> zboss: DE AD 1A 02 F5 04 7E 00|......~. <info> zboss: 2B 08 35 07 00 00 00 00|+.5..... <info> zboss: D2 31 00 00 0B 00 00 00|.1...... <info> zboss: 00 00 00 00 DE AD 12 02|........ <info> zboss: F5 04 7F 00 2B 08 36 07|....+.6. <info> zboss: E5 5C F6 FE 20 6D 68 71|.\.. mhq <info> app: Can sleep for 92 ms
With a few exceptions, my sdk_config matches what is included with the zigbee light switch example.
Any advice on how to further troubleshoot is greatly appreciated.
