Sending battery information from generic battery client model(mesh).
Hello
This is sumanth. I am working on implementing battery model in light switch program(mesh), I enabled the battery model in client and I would like send the battery information of client to server. I used the proper model ID , opcodes and able to see the Generic Battery Client model in mesh app. Now I want to send the battery level when i press a button in nrf52 DK as a status message to server and also display in RTT of client. I modified the program of light switch client(main.c) as below mentioned.
/* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
 * list of conditions and the following disclaimer.
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
#include "generic_onoff_client.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "example_common.h"
#include "ble_softdevice_support.h"
/*battery included*/
#include "app_onoff.h"
#include "battery_client_model.h"
#define APP_STATE_OFF                (0)
#define APP_STATE_ON                 (1)
#define haha                         (5)
#define APP_UNACK_MSG_REPEAT_COUNT   (2)
//edited
#define ONOFF_SERVER_0_LED          (BSP_LED_0)
#define BATTERY_ELEMENT_INDEX     (0)
//#define APP_ONOFF_ELEMENT_INDEX   (0)
static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
static bool                   m_device_provisioned;
static generic_battery_client_t m_battery;
static void battery_model_init(void)
    // Instantiate onoff server on element index APP_ONOFF_ELEMENT_INDEX
    battery_init(&battery_name, BATTERY_ELEMENT_INDEX);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App OnOff Model Handle: %d\n",battery_name.server.model_handle);
/* Forward declaration */
static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
                                               const access_message_rx_meta_t * p_meta,
                                               const generic_onoff_status_params_t * p_in);
static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
                                                       void * p_args,
                                                       access_reliable_status_t status);
static void app_generic_battery_client_status_cb(const generic_battery_client_t * p_self,
                                               const generic_battery_status_params_t * p_in);
const generic_battery_client_callbacks_t battery_cbs=
    .battery_status_cb = app_generic_battery_client_status_cb,
    .ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
    .periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
const generic_onoff_client_callbacks_t client_cbs =
    .onoff_status_cb = app_generic_onoff_client_status_cb,
static void device_identification_start_cb(uint8_t attention_duration_s)
    hal_led_mask_set(LEDS_MASK, false);
    hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                     LED_BLINK_ATTENTION_INTERVAL_MS,
                     LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
    hal_led_blink_stop();
static void provisioning_complete_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
    /* Restores the application parameters after switching from the Provisioning
     * service to the Proxy  */
    gap_params_init();
    conn_params_init();
    dsm_local_unicast_address_t node_address;
    dsm_local_unicast_addresses_get(&node_address);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
    hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
/* This callback is called periodically if model is configured for periodic publishing */
     __LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
/* Acknowledged transaction status callback, if acknowledged transfer fails, application can
* determine suitable course of action (e.g. re-initiate previous transaction) by using this
* callback.
                                                       void * p_args,
    switch(status)
        case ACCESS_RELIABLE_TRANSFER_SUCCESS:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n");
        case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
            hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
        case ACCESS_RELIABLE_TRANSFER_CANCELLED:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
            ERROR_CHECK(NRF_ERROR_INTERNAL);
/* Generic OnOff client model interface: Process the received status message in this callback */
    if (p_in->remaining_time_ms > 0)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
              p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
              p_meta->src.value, p_in->present_on_off);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "battery server: 0x%04x, battery state: %d, Remaining Time: %d ms\n",
              p_meta->src.value, p_in->battery_State, p_in->remaining_time_ms);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "battery server: 0x%04x, battery state: %d\n",
              p_meta->src.value, p_in->battery_State);
static void node_reset(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
    /* This function may return if there are ongoing flash operations. */
    mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
    if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
        node_reset();
static void button_event_handler(uint32_t button_number)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
    uint32_t status = NRF_SUCCESS;
    generic_onoff_set_params_t set_params;
    generic_battery_status_params_t set_params_t;
    model_transition_t transition_params;
    static uint8_t tid = 0;
    /* Button 1: On, Button 1: Off, Client[0]
     * Button 2: On, Button 3: Off, Client[1]
    switch(button_number)
        case 0:
        case 2:
            set_params.on_off = APP_STATE_ON;
        case 1:
        case 3:
            set_params.on_off = APP_STATE_OFF;
    set_params.tid = tid++;
    transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
    transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
    switch (button_number)
        case 0:
        case 1:
            /* Demonstrate acknowledged transaction, using 1st client model instance */
            /* In this examples, users will not be blocked if the model is busy */
            (void)access_model_reliable_cancel(m_clients[0].model_handle);
            status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
            hal_led_pin_set(BSP_LED_0, set_params.on_off);
            status = generic_battery_client_status_publish(&m_battery,&set_params_t);
            //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Battery State: %d\n", set_params_t.battery_State);
        case 2:
        case 3:
            /* Demonstrate un-acknowledged transaction, using 2nd client model instance */
            status = generic_onoff_client_set_unack(&m_clients[1], &set_params,
                                                    &transition_params, APP_UNACK_MSG_REPEAT_COUNT);
            hal_led_pin_set(BSP_LED_1, set_params.on_off);
    switch (status)
        case NRF_SUCCESS:
        case NRF_ERROR_NO_MEM:
        case NRF_ERROR_BUSY:
        case NRF_ERROR_INVALID_STATE:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
        case NRF_ERROR_INVALID_PARAM:
            /* Publication not enabled for this client. One (or more) of the following is wrong:
             * - An application key is missing, or there is no application key bound to the model
             * - The client does not have its publication state set
             * It is the provisioner that adds an application key, binds it to the model and sets
             * the model's publication state.
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
            ERROR_CHECK(status);
static void rtt_input_handler(int key)
    if (key >= '0' && key <= '3')
        uint32_t button_number = key - '0';
        button_event_handler(button_number);
static void models_init_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
    for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i)
        m_clients[i].settings.p_callbacks = &client_cbs;
        m_clients[i].settings.timeout = 0;
        m_clients[i].settings.force_segmented = APP_CONFIG_FORCE_SEGMENTATION;
        m_clients[i].settings.transmic_size = APP_CONFIG_MIC_SIZE;
        ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
    m_battery.settings.p_callbacks = &battery_cbs;
    m_battery.settings.timeout = 0;
    m_battery.settings.force_segmented = APP_CONFIG_FORCE_SEGMENTATION;
    m_battery.settings.transmic_size = APP_CONFIG_MIC_SIZE;
    ERROR_CHECK(battery_double_init(&m_battery,BATTERY_ELEMENT_INDEX));
static void mesh_init(void)
    mesh_stack_init_params_t init_params =
        .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
        .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
        .core.p_uuid             = NULL,
        .models.models_init_cb   = models_init_cb,
        .models.config_server_cb = config_server_evt_cb
    ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
static void initialize(void)
    __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
    ERROR_CHECK(app_timer_init());
    hal_leds_init();
#if BUTTON_BOARD
    ERROR_CHECK(hal_buttons_init(button_event_handler));
    ble_stack_init();
    gap_params_init();
    conn_params_init();
    mesh_init();
static void start(void)
    rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
    if (!m_device_provisioned)
        static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
        mesh_provisionee_start_params_t prov_start_params =
            .p_static_data    = static_auth_data,
            .prov_complete_cb = provisioning_complete_cb,
            .prov_device_identification_start_cb = device_identification_start_cb,
            .prov_device_identification_stop_cb = NULL,
            .prov_abort_cb = provisioning_aborted_cb,
            .p_device_uri = EX_URI_LS_CLIENT
        ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
    mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
    ERROR_CHECK(mesh_stack_start());
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
    initialize();
    start();
    for (;;)
        (void)sd_app_evt_wait();
I initialised the battery model function in main file i.e above program and functions on battery model in new file. I am trying to display the battery status params in RTT after publishing as status in below files.
#include "model_common.h"
#include <stdint.h>
#include <stddef.h>
#include <string.h>
#include "access.h"
#include "nrf_mesh_assert.h"
#include "nrf_mesh_utils.h"
#include "nordic_common.h"
#include "log.h"
#include "generic_onoff_server.h"
#include "generic_onoff_messages.h"
#include "generic_onoff_common.h"
//uint32_t battery_double_init(generic_onoff_server_t * p_server, uint8_t element_index);
static uint32_t status_send(generic_battery_client_t * p_server,
                            const access_message_rx_t * p_message,
                            const generic_battery_status_params_t * p_params)
    uint32_t err;
    generic_battery_status_msg_pkt_t msg_pkt;
    msg_pkt.battery_State = p_params->battery_State;
    if (p_params->remaining_time_ms > 0)
        msg_pkt.remaining_time = model_transition_time_encode(p_params->remaining_time_ms);
    access_message_tx_t reply =
        .opcode = ACCESS_OPCODE_SIG(GENERIC_BATTERY_OPCODE_STATUS),
        .p_buffer = (const uint8_t *) &msg_pkt,
        .length = p_params->remaining_time_ms > 0 ? GENERIC_ONOFF_STATUS_MAXLEN : GENERIC_ONOFF_STATUS_MINLEN,
        .force_segmented = p_server->settings.force_segmented,
        .transmic_size = p_server->settings.transmic_size
    if (p_message == NULL)
        //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Battery State: %d\n",msg_pkt.battery_State);
        err = access_model_publish(p_server->model_handle, &reply);
       // __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Battery State: %d\n",msg_pkt.battery_State);
        return err;
        return access_model_reply(p_server->model_handle, p_message, &reply);
static void battery_status_handle(access_model_handle_t handle, const access_message_rx_t * p_rx_msg, void * p_args)
    generic_battery_client_t * p_client = (generic_battery_client_t *) p_args;
    generic_battery_status_params_t in_data = {0};
    if (p_rx_msg->length == GENERIC_ONOFF_STATUS_MINLEN || p_rx_msg->length == GENERIC_ONOFF_STATUS_MAXLEN)
        generic_battery_status_msg_pkt_t * p_msg_params_packed = (generic_battery_status_msg_pkt_t *) p_rx_msg->p_data;
        if (p_rx_msg->length == GENERIC_ONOFF_STATUS_MINLEN)
            in_data.battery_State = p_msg_params_packed->battery_State;
            in_data.remaining_time_ms = 0;
            in_data.remaining_time_ms = model_transition_time_decode(p_msg_params_packed->remaining_time);
        p_client->settings.p_callbacks->battery_status_cb(p_client, &p_rx_msg->meta_data, &in_data);
static const access_opcode_handler_t m_opcode_handlers2[] =
    {ACCESS_OPCODE_SIG(GENERIC_BATTERY_OPCODE_STATUS), battery_status_handle},
uint32_t battery_double_init(generic_battery_client_t * p_client, uint8_t element_index)
    if (p_client == NULL ||
        p_client->settings.p_callbacks == NULL ||
        p_client->settings.p_callbacks->battery_status_cb == NULL ||
        p_client->settings.p_callbacks->periodic_publish_cb == NULL)
        return NRF_ERROR_NULL;
    if (p_client->settings.timeout == 0)
        p_client->settings.timeout= MODEL_ACKNOWLEDGED_TRANSACTION_TIMEOUT;
    access_model_add_params_t init_params =
        .model_id = ACCESS_MODEL_SIG(BATTERY_CLIENT_MODEL_ID),
        .element_index =  element_index,
        .p_opcode_handlers = &m_opcode_handlers2[0],
        .opcode_count = ARRAY_SIZE(m_opcode_handlers2),
        .p_args = p_client,
        .publish_timeout_cb = p_client->settings.p_callbacks->periodic_publish_cb
    uint32_t status = access_model_add(&init_params, &p_client->model_handle);
    if (status == NRF_SUCCESS)
        status = access_model_subscription_list_alloc(p_client->model_handle);
    return status;
uint32_t generic_battery_client_status_publish(generic_battery_client_t * p_server, const generic_battery_status_params_t * p_params)
    if (p_server == NULL ||
        p_params == NULL)
    return status_send(p_server, NULL, p_params);
battery_client_model.hgeneric_onoff_messages.hgeneric_onoff_common.h
When i am pressing the button on nrf52 DK it displays some fixed random values(like 0,31,177,0,0,0,31,0,177) for battery_state in RTT(mentioned in program).
Please go through the programs attached above and help me to sort the issue. I am also having few doubts i,e
1. What status handle in models do as we are defining it with some structures as arguments?
2. How the battery of client device is measured and accessed ?
3. How callback functions are helpful and used in accessing the hardware states of device.
Will be waiting for valuable replies.
Regards
Sumanth
