I am trying to debug a custom PCB for the NRF51822 - I can run a modified version of the HRS application (S110) that has been verified on the PCA10004. The LF clock source has been changed as per a previous post in these forums, so as to use the internal RC.
Sanity checking with just flashing some LEDs also works. However, I am stuck in debugging the RF part of it - there is currently no transmission happening. The VDD_PA pin is showing an average voltage of 70mV as compared to the ~2V I am seeing on the PCA10004 (Tx power +4dbm). This is using a multimeter as I don't have access to an oscilloscope at the moment.
I removed all passives connected to the VDD_PA pin to discard the possibility of a low resistance path to ground - but I still get the same reading on the multimeter.
Any ideas on what could be going wrong? Or tips on how to further debug the VDD_PA pin behavior?
Thanks, NK
