Issue with command line compilation of NRF9160 samples
I have configured the toolchain and SDK by following the NRF Connect getting started guide and followed the below steps to compile the mqtt_simple application (on master branch and using a MAC):
export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
export GNUARMEMB_TOOLCHAIN_PATH="/path/to/gcc-arm-none-eabi-Qx-2018/"
source /path/to/ncs/zephyr/zephyr-env.sh
cd /path/to/ncs/nrf/samples/nrf9160/mqtt_simple/
mkdir build && cd build
cmake .. -DBOARD=nrf9160_pca10090ns -GNinja
After executing cmake this is the output:
Zephyr version: 1.14.0
-- Selected BOARD nrf9160_pca10090ns
-- Found west: /usr/local/bin/west (found suitable version "0.5.5", minimum required is "0.5.4")
-- Loading /path/to/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
-- Overlaying /path/to/ncs/zephyr//dts/common/common.dts
Parsing Kconfig tree in /path/to/ncs/nrf/samples/nrf9160/mqtt_simple/Kconfig
Loading /path/to/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig as base
Merging /path/to/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf
/path/to/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:11: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
/path/to/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:12: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT
/path/to/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:15: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
/path/to/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:19: warning: attempt to assign the value 'y' to the undefined symbol AT_HOST_LIBRARY
Error: Aborting due to non-whitelisted Kconfig warning
'/path/to/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf:11: warning: attempt to
 assign the value 'y' to the undefined symbol LTE_LINK_CONTROL'.
Note: If this warning doesn't point
 to an actual problem, you can add it to the whitelist at the top of
/path/to/ncs/zephyr//scripts/kconfig/kconfig.py.
CMake Error at /path/to/ncs/zephyr/cmake/kconfig.cmake:191 (message):
command failed with return code: 1
/path/to/ncs/zephyr/cmake/app/boilerplate.cmake:397 (include)
CMakeLists.txt:9 (include)
Any help would be appreciated.
Kind regards
  • There has to be a new release tagged sometime soon, right?
  • Yes, there should be a new release tagged soon. In regards to the NCS master branch, there has been an update in this blog post here. Segger finally has support for the Zephyr master branch now!
    I have tested this myself & followed the following procedure (using Windows 10). Remember to run choco commands using an Administrator command prompt. First, I upgraded to the latest nRF Getting Started Assistant guide in nRF Connect. If you have already installed the toolchain, you can skip the first two commands:
    choco feature enable -n allowGlobalConfirmation
    choco install -y cmake --installargs 'ADD_CMAKE_TO_PATH=System'
    For all of the following choco install commands, I instead ran choco upgrade (see example below):
    choco upgrade git
    After each upgrade, I verified the upgrade by pressing the Verify button in the nRF Connect for Desktop app.
    In the "Clone the nRF Connect SDK" section, I ran the following command first:
    pip3 install west --upgrade
    I then created a new ncs folder. After running the "west init" command, I then ran "west update" when prompted to do so in the command prompt (if you want to use the master branch). If you want to use a tagged branch, see the command below this one. I was not able to verify the west init step unfortunately (most likely because I named by ncs folder ncs_master instead of ncs).
    I then deleted the old Segger v4.14 (the one used for NCS) & installed the new v4.16. I find it is helpful to make a shortcut of the emStudio.exe file. That way, you won't need to go to that folder every time you want to launch SES.
    The first time, I received an error code 1. I needed to change the zephyr base as described in the linked blog post.
    If you have any more questions regarding this, please open a new devzone case, as this thread is becoming large & slightly disorganized.
