Hey,
I am currently designing a custom PCB w/ the nrf51822 QFAA. This is the first PCB I've designed and I'd really appreciate any help.
1.) Since I am using BLE I am not using the internal buck converter. I am planning on using a 3V battery and directly powering my nrf51 and two sensors with it. My sensors require 3V although I've read it would be most efficient to power the nrf51 w/ ~1.8V. Would an external voltage regulator be worth adding for my case?
2.) I am mounting a coin cell battery on the other side of the PCB to save space. One of the VCC pads is under the 16 MHz clock. Do you think this will cause any problems?
3.) To save space I am not using the J-link debugger 10 pin header on my board. Instead I am planning to add vias and solder wires to program the nrf51822. Do you think this is OK? Will I need to add any external resistors to SWDIO or SWCLK?
4.) Lastly would it be wise to connect any GPIO pins I'm not using to ground or should I leave them NC?
Thanks!
