Problems using fstorage
Hi.
I modified the fstorage example to create the project.
I split Flash into three areas as shown below.
   *Flash Area(0x26000 ~ 0x2ffff) : Bootloader
   *Flash Area(0x30000 ~ 0x4DFFF) : Application 1 (written 34858 byte)
   *Flash Area(0x4E000 ~ 0x6BFFF) : Application 2 (Empty)
I have written code to copy the App_1 area to the App_2 area for testing, but it doesn't work.
nrf_fstorage_write return 0x10(NRF_ERROR_INVALID_ADDR).
static void start_Update_Firmware(void) {
  flash_Erase(fData.tFirmPage);
  for (uint8_t wSEQ = 0; wSEQ < fData.tFirmPage; wSEQ++) {
    flash_Read(wSEQ, rFData);
    flash_Write(wSEQ, rFData, sizeof(rFData));
/* Flash Event Handler Function                                               */
static void fstorage_evt_handler(nrf_fstorage_evt_t *p_evt) {
  switch (p_evt->id) {
  case NRF_FSTORAGE_EVT_READ_RESULT:
    //Read Success
    isRead = true;
  case NRF_FSTORAGE_EVT_WRITE_RESULT:
    //Write Success
    printf("Flash\t: Write Result : %08x\r\n", p_evt->result);
    isWrite = true;
  case NRF_FSTORAGE_EVT_ERASE_RESULT:
    //Erase Success
    printf("Flash\t: Erase Result : %08x\r\n", p_evt->result);
    isErase = true;
    printf("Flash\t: ???? Result : %08x\r\n", p_evt->result);
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
        /* Set a handler for fstorage events. */
        .evt_handler = fstorage_evt_handler,
        .start_addr = 0x30000,
        .end_addr = 0x6BFFF,
/* Flash Init Function                                                        */
void flash_Init(void) {
  ret_code_t rc;
#if Bootloader
  p_fs_api = &nrf_fstorage_sd;
  rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
  APP_ERROR_CHECK(rc);
  printf("Flash\t: Init Done\r\n");
/* Flash Write Function                                                       */
uint8_t flash_Write(uint8_t seq, uint8_t *pData, uint32_t dLen) {
  uint8_t rc;
  isWrite = false;
#if Bootloader
  //uint32_t wAddr = 0x30000 + (0x1000 * seq);
  uint32_t wAddr = 0x4E000 + (0x800 * seq); //Test Code
#else
  rc = nrf_fstorage_write(&fstorage, wAddr, pData, dLen, NULL);
  while (nrf_fstorage_is_busy(&fstorage)) {
    __WFE();
  printf("Flash\t: Write Result : %08x %08x %08x\r\n", rc, wAddr, dLen);
  return rc;
/* Flash Read Function                                                        */
uint8_t flash_Read(uint8_t seq, uint8_t *pData) {
  uint8_t rc;
  isRead = false;
  //uint32_t rAddr = 0x4E000 + (0x1000 * seq); //Read 4KB
  uint32_t rAddr = 0x30000 + (0x800 * seq); //Read 4KB   //TestCode
  rc = nrf_fstorage_read(&fstorage, rAddr, pData, 0x800); //Read 4KB
  printf("Flash\t: Read Result : %08x\r\n", rc);
    __WFE();
  return rc;
/* Flash Erase Function                                                       */
uint8_t flash_Erase(uint8_t tPage) {
  uint8_t rc;
  isErase = false;
#if Bootloader
  //rc = nrf_fstorage_erase(&fstorage, 0x30000, tPage, NULL);
  rc = nrf_fstorage_erase(&fstorage, 0x4E000, tPage, NULL);
#else
  while (!isErase) {
    __WFE();
  return rc;
Use SDKs: 15.2
IDE : SEGGER Embedded Studio for ARM 4.12
Hardware : nRF52832(BMD-300)
