I'm using nRF52840, with NFC pairing (based on SDK examples).
Thanks!
Thanks!
Just to avoid confusion: A 'scan' request will not cause a connected event, but a 'connect' request may trigger a connected event.
If you send a connect request but it doesn't trigger a connected event, then either the peripheral have whitelist that prevent the peer to connect and/or there is noise in the environment that prevent the packet to be received (this is a common scenario, for instance <5% of the cases).
Kenneth
Hi Kenneth,
It happens much more than 5%. Is there a way to solve it?
Thanks
Have you done any DTM (Direct Test Mode, see example in SDK) testing on the design to ensure that you have a good design?
Do you have any serial interfaces active (e.g. spi, uart, i2c..) while advertising that may impact the radio in some way?
