ADC on nRF9160 DK - Differential Inputs and more inputs
I have just got my SAADC up and running on my nrf9160, reading a single ended input.
Thanks for the support on this ticket, "ADC on nRF9160 DK - Example code problems"
I would like to expand this code in two ways.
1. Add additional channels
2. Add a differential channel
 I used the sample code I used previously
https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/adc/src
with the changes suggested by Martin.
I then tried to move everything to the second channel, basically changing all the "1st" to "2nd"
* Copyright (c) 2018 Nordic Semiconductor ASA
* SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <nrf9160.h>
#include <stdio.h>
#include <string.h>
#include <uart.h>
#include <adc.h>
#include <zephyr.h>
struct device *adc_dev;
#define CONFIG_BOARD_NRF9160_PCA10090
#if defined(CONFIG_BOARD_NRF52_PCA10040) || \
defined(CONFIG_BOARD_NRF52840_PCA10056) || \
defined(CONFIG_BOARD_NRF9160_PCA10090NS) || \
defined(CONFIG_BOARD_NRF52840_BLIP)
#include <hal/nrf_saadc.h>
#define ADC_DEVICE_NAME DT_ADC_2_NAME
#define ADC_RESOLUTION 10
#define ADC_GAIN ADC_GAIN_1_6
#define ADC_REFERENCE ADC_REF_INTERNAL
#define ADC_ACQUISITION_TIME ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 10)
#define ADC_1ST_CHANNEL_ID 0
#define ADC_1ST_CHANNEL_INPUT NRF_SAADC_INPUT_AIN0
#define ADC_2ND_CHANNEL_ID 2
#define ADC_2ND_CHANNEL_INPUT NRF_SAADC_INPUT_AIN2
static const struct adc_channel_cfg m_2nd_channel_cfg = {
.gain = ADC_GAIN,
.reference = ADC_REFERENCE,
.acquisition_time = ADC_ACQUISITION_TIME,
.channel_id = ADC_2ND_CHANNEL_ID,
#if defined(CONFIG_ADC_CONFIGURABLE_INPUTS)
.input_positive = ADC_2ND_CHANNEL_INPUT,
#define BUFFER_SIZE 1
static s16_t m_sample_buffer[BUFFER_SIZE];
static int adc_sample(void)
int ret;
const struct adc_sequence sequence = {
.channels = BIT(ADC_2ND_CHANNEL_ID),
.buffer = m_sample_buffer,
.buffer_size = sizeof(m_sample_buffer),
.resolution = ADC_RESOLUTION,
if (!adc_dev) {
return -1;
ret = adc_read(adc_dev, &sequence);
printk("ADC read err: %d\n", ret);
/* Print the AIN0 values */
for (int i = 0; i < BUFFER_SIZE; i++) {
float adc_voltage = 0;
adc_voltage = (float)(((float)m_sample_buffer[i] / 1023.0f) *
3600.0f);
printk("ADC raw value: %d\n", m_sample_buffer[i]);
printf("Measured voltage: %f mV\n", adc_voltage);
return ret;
int err;
printk("nrf91 saadc sampling AIN0 (P0.13)\n");
printk("Example requires secure_boot to have ");
printk("SAADC set to non-secure!\n");
printk("If not; BusFault/UsageFault will be triggered\n");
adc_dev = device_get_binding("ADC_2");
if (!adc_dev) {
printk("device_get_binding ADC_2 failed\n");
err = adc_channel_setup(adc_dev, &m_2nd_channel_cfg);
if (err) {
printk("Error in adc setup: %d\n", err);
/* Trigger offset calibration
* As this generates a _DONE and _RESULT event
* the first result will be incorrect.
NRF_SAADC_NS->TASKS_CALIBRATEOFFSET = 1;
while (1) {
err = adc_sample();
if (err) {
printk("Error in adc sampling: %d\n", err);
k_sleep(500);
I get an error,
Secure Boot: MSP_NS 200209b8
Secure Boot: prepare to jump to Non-Secure image
***** Booting Zephyr OS v1.13.99-ncs1-5561-gde69d2df908f *****
Example requires secure_boot to have SAADC set to non-secure!
Exception occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
***** Hardware exception *****
Current thread ID = 0x200200b4
Faulting instruction address = 0x40d60
Fatal fault in ISR! Spinning...
I guess Im missing another setting somewhere?
Also, does anyone have any code detailing how to set up additional differential channels?
Rod
Parents Reply
  • I have asked the developer for help, but unfortunately he is busy with other tasks at the moment. I am not sure when differential ADC measurements will be available. As for this question:
    RodWatt said:
    I can use  either AIN04 or 06 but can not seem to use the others. i.e. AIN0, 1, 2, 3, or 5 on the DK.
    I assume these are pre-defined for other uses on the DK. Can I re-assign these?
     This is most likely because not all GPIOs are accessible in the nRF91. See this list here for more info.
