How do I (simply) do a non-connectable advert on nRF52 using SDK 15?
I am porting a peripheral project from nRF51822 on SDK 11 to nRF52832 on SDK 15.  Currently I'm using15.0, with S132 6.0.0.  I used the template project for an initial pattern for working with SDK 15.
One thing it needs to do is (if I have the term right): "Peripheral Advertiser", i.e.
  • When unconnected it advertises normally, as a connectable peripheral.
  • While connected it advertises as unconnectable (so other centrals can still SEE it), but otherwise identically.
  • When the connection is ended, it reverts to the connectable advertisement.
I am having difficulty finding any simple explanation for how to do this.
  • Nearly everything I found was for earlier SDKs - but advertising changed massively between 14 and 15.
    • Under 15 it seems to have switched to advertising structures managed by the soft device in the latter's storage,
    • addressed by a handle/index rather than a pointer
    • not to be modified on-the-fly, but replaced by a new one (and the old one unavailable for reuse until the soft device has finished some post processing on it)
    • The automatic turn-on of advertising on connection drop (on_disconnected()) sets the type to BLE_ADV_MODE_DIRECTED_HIGH_DUTY, rather than, say,
  • The closest I did find on SDK 15 was https://devzone.nordicsemi.com/f/nordic-q-a/32824/dynamically-updating-advertising-data-in-sdk-15/126346#126346,
    • That seems to be an in-process debug of a rotating-triple-buffer scheme that is also supporting on-the-fly modification of the contents of the advertisement in other ways.
    • It also seems to involve replacing components/ble/ble_advertising/* with a roll-your-own substitute.
Can someone give me (or give me a pointer to) a simple (or as simple as practical under SDK 15) scheme for just doing the basic keep-advertising-while-connected, switch-between-connectable-and-unconnectable function.
(I WILL be needing on-the-fly adjustment of the manufacturing field in another month or so, so info on that would also be nice.  But I need the above right away.)
Thanks.
  • On Android 8.0, there is no 'Connect' button for the Non-Scannable, Non-Connectable advertising.
    On Android 6, the 'Connect' button is always there - Scannable on Non-scannable.
    So it looks like there is a flaw in nRF Connect, too.
  • Here's my modified template project (SDK 15.0.0)
    It doesn't build with SDK 15.3.0.
    I applied your changes to the main.c in the SDK 15.3.0 project, and that does work. The file is attached.
    All the changes for non-connectable advertising are controlled by #if ADVERTISE_WHILE_CONNECTED
    Note that you need to change NRF_LOG_DEFAULT_LEVEL from 3 to 4 in sdk_config.h in order to see the NRF_LOG_DEBUG messages.
    The choice between Scannable & Non-scannable advertising is also on a #if - in non_connectable_advertising_start():
    #if 0
        NRF_LOG_DEBUG( "Non-connectable, Scannable advertising" );
        adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
    #else
        NRF_LOG_DEBUG( "Non-connectable, Non-scannable advertising" );
        adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_template_main main.c
     * @ingroup ble_sdk_app_template
     * @brief Template project main file.
     * This file contains a template for creating a new application. It has the code necessary to wakeup
     * from button, advertise, get a connection restart advertising on disconnect and if no new
     * connection created go back to system-off mode.
     * It can easily be used as a starting point for creating a new application, the comments identified
     * with 'YOUR_JOB' indicates where and how you can customize.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "bsp_btn_ble.h"
    #include "sensorsim.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                     "Nordic_Template"                       /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    /*Application needs higher priority than BLE_ADV_BLE_OBSERVER_PRIO in this case */
    #define APP_BLE_OBSERVER_PRIO           0                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    /* YOUR_JOB: Declare all services structure your application is using
     *  BLE_XYZ_DEF(m_xyz);
    // YOUR_JOB: Use UUIDs for service(s) used in your application.
    static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    static void advertising_start(bool erase_bonds);
    static void non_connectable_advertising_start(void);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        switch (p_evt->evt_id)
            case PM_EVT_BONDED_PEER_CONNECTED:
                NRF_LOG_INFO("Connected to a previously bonded device.");
            } break;
            case PM_EVT_CONN_SEC_SUCCEEDED:
                NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                /* Often, when securing fails, it shouldn't be restarted, for security reasons.
                 * Other times, it can be restarted directly.
                 * Sometimes it can be restarted, but only after changing some Security Parameters.
                 * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
                 * Sometimes it is impossible, to secure the link, or the peer device does not support it.
                 * How to handle this error is highly application dependent. */
            } break;
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
            } break;
            case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                err_code = fds_gc();
                if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
            } break;
                advertising_start(false);
            } break;
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
            } break;
            case PM_EVT_PEER_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
            } break;
            case PM_EVT_PEERS_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
            } break;
            case PM_EVT_ERROR_UNEXPECTED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
            } break;
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
                // This can happen when the local DB has changed.
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        /* YOUR_JOB: Create any timers to be used by the application.
                     Below is an example of how to create a timer.
                     For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                     one.
           err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
           APP_ERROR_CHECK(err_code); */
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        /* YOUR_JOB: Use an appearance value matching the application's use case.
           err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the YYY Service events.
     * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
     * @details This function will be called for all YY Service events which are passed to
     *          the application.
     * @param[in]   p_yy_service   YY Service structure.
     * @param[in]   p_evt          Event received from the YY Service.
    static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                           ble_yy_service_evt_t * p_evt)
        switch (p_evt->evt_type)
            case BLE_YY_NAME_EVT_WRITE:
                APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
                // No implementation needed.
        /* YOUR_JOB: Add code to initialize the services used by the application.
           ble_xxs_init_t                     xxs_init;
           ble_yys_init_t                     yys_init;
           // Initialize XXX Service.
           memset(&xxs_init, 0, sizeof(xxs_init));
           xxs_init.evt_handler                = NULL;
           xxs_init.is_xxx_notify_supported    = true;
           xxs_init.ble_xx_initial_value.level = 100;
           err_code = ble_bas_init(&m_xxs, &xxs_init);
           // Initialize YYY Service.
           memset(&yys_init, 0, sizeof(yys_init));
           yys_init.evt_handler                  = on_yys_evt;
           yys_init.ble_yy_initial_value.counter = 0;
           err_code = ble_yy_service_init(&yys_init, &yy_init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for starting timers.
    static void application_timers_start(void)
        /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
           err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
                  /*Stop advertising to allow the advertising module to start
                    connectable advertising. It's not possible to change adv. params
                    on the fly, only data*/
                (void)sd_ble_gap_adv_stop(m_advertising.adv_handle);
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                non_connectable_advertising_start();
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
     * @param[in]   event   Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BSP_EVENT_DISCONNECT:
                break; // BSP_EVENT_DISCONNECT
            case BSP_EVENT_WHITELIST_OFF:
                break; // BSP_EVENT_KEY_0
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_on_disconnect_disabled  = false;
        init.config.ble_adv_fast_enabled            = true;
        init.config.ble_adv_fast_interval           = APP_ADV_INTERVAL;
        init.config.ble_adv_fast_timeout            = APP_ADV_DURATION;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        uint32_t    err_code;
        ble_gap_adv_params_t  adv_params;
        memcpy(&adv_params, &m_advertising.adv_params, sizeof(adv_params));
        err_code = sd_ble_gap_adv_set_configure(&m_advertising.adv_handle,
                                                &m_advertising.adv_data,
                                                &adv_params);
        err_code = sd_ble_gap_adv_start(m_advertising.adv_handle, m_advertising.conn_cfg_tag);
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Template example with non-connectable advertising while connected.");
        application_timers_start();
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • The advertisement module in SDK 15.3.0 includes an API for updating advertisement data on the fly
    But, as previously noted, it does not work:
    https://devzone.nordicsemi.com/f/nordic-q-a/41669/ble_advertising_advdata_update/183212#183212
    As a workaround in SDK 15.3.0, I use the Advertising Timeout and do the update there before re-starting advertising (which is similar to other suggestions):
    https://devzone.nordicsemi.com/f/nordic-q-a/41669/ble_advertising_advdata_update/187065#187065
    But with 's code here, I no longer get the Advertising Timeout event!
    So what's going on with that?!
    (the advertising is stopping after the specified duration)
  • I've expanded the example above to update advertising data while disconnected. It's built with SDK v15.3.0. Please see attached below.
    8816.ble_app_template.zip
    It works, but we should have made it more clear that you need to provide a new buffer when you update the data.
    Excerpt of the code comments for the  ble_gap_adv_data_t struct:
    /**@brief GAP advertising data buffers.
     * The application must provide the buffers for advertisement. The memory shall reside in application RAM, and
     * shall never be modified while advertising. The data shall be kept alive until either:
     *  - @ref BLE_GAP_EVT_ADV_SET_TERMINATED is raised.
     *  - @ref BLE_GAP_EVT_CONNECTED is raised with @ref ble_gap_evt_connected_t::adv_handle set to the corresponding
     *    advertising handle.
     *  - Advertising is stopped.
     *  - Advertising data is changed.
     * To update advertising data while advertising, provide new buffers to @ref sd_ble_gap_adv_set_configure. */
    Note the last line.
    Are you not getting BLE_GAP_EVT_ADV_SET_TERMINATED event on timeout?
  • update advertising data while disconnected
    It needs to keep updating the advertising data at all times - not just while disconnected.
    It could hardly be less clear!
    Note the last line.
    It remains as clear as mud!
    Please update that thread with a complete example.
    No - no event at all.
