How do I (simply) do a non-connectable advert on nRF52 using SDK 15?
I am porting a peripheral project from nRF51822 on SDK 11 to nRF52832 on SDK 15.  Currently I'm using15.0, with S132 6.0.0.  I used the template project for an initial pattern for working with SDK 15.
One thing it needs to do is (if I have the term right): "Peripheral Advertiser", i.e.
  • When unconnected it advertises normally, as a connectable peripheral.
  • While connected it advertises as unconnectable (so other centrals can still SEE it), but otherwise identically.
  • When the connection is ended, it reverts to the connectable advertisement.
I am having difficulty finding any simple explanation for how to do this.
  • Nearly everything I found was for earlier SDKs - but advertising changed massively between 14 and 15.
    • Under 15 it seems to have switched to advertising structures managed by the soft device in the latter's storage,
    • addressed by a handle/index rather than a pointer
    • not to be modified on-the-fly, but replaced by a new one (and the old one unavailable for reuse until the soft device has finished some post processing on it)
    • The automatic turn-on of advertising on connection drop (on_disconnected()) sets the type to BLE_ADV_MODE_DIRECTED_HIGH_DUTY, rather than, say,
  • The closest I did find on SDK 15 was https://devzone.nordicsemi.com/f/nordic-q-a/32824/dynamically-updating-advertising-data-in-sdk-15/126346#126346,
    • That seems to be an in-process debug of a rotating-triple-buffer scheme that is also supporting on-the-fly modification of the contents of the advertisement in other ways.
    • It also seems to involve replacing components/ble/ble_advertising/* with a roll-your-own substitute.
Can someone give me (or give me a pointer to) a simple (or as simple as practical under SDK 15) scheme for just doing the basic keep-advertising-while-connected, switch-between-connectable-and-unconnectable function.
(I WILL be needing on-the-fly adjustment of the manufacturing field in another month or so, so info on that would also be nice.  But I need the above right away.)
Thanks.
  • Please review and test the example I uploaded in my previous comment.  Just remove the code below from update_advertising_data() if you want the data to be updated while connected.
  • I had separately tried to do it without adjusting priorities:
    https://devzone.nordicsemi.com/f/nordic-q-a/47391/sdk-15-3-0-restart-non-connectable-advertising-after-timeout
    But that has its own issues!
    Will have a look at your latest ...
    I connected & disconnected, then left it connected for a while.
    When I came back, this had happened:
    Line 478 is the APP_ERROR_CHECK at the end of sleep_mode_enter():
    The code is unmodified, apart from the name displayed in the startup log.
    EDIT
    And again - this time while advertising:
    Is this just an artefact of having the RTT logger attached?
  • Just remove the code below from update_advertising_data() if you want the data to be updated while connected
    Actually, that code means that the Advertising Data is never updated after the first connection!
    This is due to a bug in the original Template code - which never clears m_conn_handle after a connection!
    We need to add it on the BLE_GAP_EVT_DISCONNECTED event:
  • I was not aware of this bug, thanks for pointing it out. Anyway, the main purpose of this demo was to show how you can use the "update" API.
    I forgot to disable timeout for the non-connectable advertisement, that's why sleep_mode_enter() got called.
    sd_power_system_off() will return with an error when the chip is in debug interface mode, see emulated system OFF mode: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/power.html?cp=3_1_0_17_1_0#unique_1199040052
« 2 3 4 5 6
