hi..... i am using nRF52832 and segger latest version 3.1 mesh sdk
i am trying to send the message from client to server side using light switch example , I have made some changes in light switch client example ,i have changed the boolen(APP_STATE_ON ,OFF) to character and then flashed , scanned , provisioned successfully but how to check my messages have transmitted or not ?
where can i see ? can we able to print the received messages in server side . here is my code ,where i have assign a character and sent to server side
client side
static void button_event_handler(uint32_t button_number) { __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number); uint32_t status = NRF_SUCCESS; generic_onoff_set_params_t set_params; model_transition_t transition_params; static uint8_t tid = 0; /* Button 1: On, Button 2: Off, Client[0] * Button 2: On, Button 3: Off, Client[1] */ char arr[5] = "code"; char ara[5] = "set"; switch(button_number) { case 0: case 2: set_params.on_off = arr; break; case 1: case 3: set_params.on_off = Ara; break; }
debug terminal(client side )
