Loss of notifications when sending them from peripheral to central as bulk transfer
I have read this thread Notification_Loss but could not understand my problem.
On peripheral side, I am making sure that error events are properly handled while doing the bulk transfer. Please see my code below:
uint32_t temp_data_burst_xfer(uint32_t* read_buffer_temp)
	 static uint8_t cnt = 0;			//Counting the chunks transfered
   uint32_t        err_code;
	while (cnt < TTL_CHUNKS_TEMP && burst_xfer_process)
			  cnt++;		// Next 20 byte block to send
        err_code =  Burst_characteristic_update(&m_our_service, read_buffer_temp, cnt);		//Sending 20 bytes [cnt represents which block]
				if (err_code == BLE_ERROR_NO_TX_PACKETS ||
            err_code == NRF_ERROR_INVALID_STATE ||
            err_code == BLE_ERROR_GATTS_SYS_ATTR_MISSING)
					if (err_code == BLE_ERROR_GATTS_SYS_ATTR_MISSING)		//Special handling of BLE_ERROR_GATTS_SYS_ATTR_MISSING
							 SEGGER_RTT_printf(0,"\n\r***  BLE_ERROR_GATTS_SYS_ATTR_MISSING ***\n\r");
					else if(err_code == NRF_ERROR_INVALID_STATE)
							SEGGER_RTT_printf(0,"Burst transfer halted due to error NRF_ERROR_INVALID_STATE \n\r");
				else if (err_code != NRF_SUCCESS)
						SEGGER_RTT_printf (0, "\r\n Error # 0x%x in 'mag_data_burst_xfer'\r\n",err_code);
            APP_ERROR_HANDLER(err_code);											//Unhandled
	if(cnt == TTL_CHUNKS_TEMP)
		burst_xfer_process=0;			//Burst transfer stopped
		cnt = 0 ;									//Reset for next record transfer
		return NRF_SUCCESS;
Where TTL_CHUNKS_TEMP == 25. So I am sending 25 notifications. I have verified that peripheral completes the process without any error (otherwise the peripheral would stop at APP_ERR_HANDLER).
However on server side, I receive only 15 or sometimes 10 notifications, please see the log below:
Connecting to our Service UUID 101
 0> Connection request sent to SenseaFlash
 0> our Service UUID Find Status = 0
 0> try to find Sensea_Tag service on conn_handle 0x0
 0> BLE DB Discovery just started
 0>
 0> *** Notification process started ***
 0> [0] = 0x1A 	[1] = 0x1A 	[2] = 0x1A 	[3] = 0x1B 	[4] = 0x1B
 0> *** Burst = 0 ***
 0> [5] = 0x1C 	[6] = 0x1D 	[7] = 0x1D 	[8] = 0x1D 	[9] = 0x1E
 0> *** Burst = 1 ***
 0> [10] = 0x1E 	[11] = 0x1F 	[12] = 0x1F 	[13] = 0x1F 	[14] = 0x1E
 0> *** Burst = 2 ***
 0> [15] = 0x1E 	[16] = 0x1E 	[17] = 0x1E 	[18] = 0x1D 	[19] = 0x1D
 0> *** Burst = 3 ***
 0> [20] = 0x1D 	[21] = 0x1D 	[22] = 0x1D 	[23] = 0x1D 	[24] = 0x1D
 0> *** Burst = 4 ***
 0> [25] = 0x1D 	[26] = 0x1D 	[27] = 0x1D 	[28] = 0x1C 	[29] = 0x1D
 0> *** Burst = 5 ***
 0> [30] = 0x1D 	[31] = 0x1D 	[32] = 0x1E 	[33] = 0x1E 	[34] = 0x20
 0> *** Burst = 6 ***
 0> [35] = 0x23 	[36] = 0x25 	[37] = 0x25 	[38] = 0x26 	[39] = 0x26
 0> *** Burst = 7 ***
 0> [40] = 0x29 	[41] = 0x29 	[42] = 0x29 	[43] = 0x27 	[44] = 0x28
 0> *** Burst = 8 ***
 0> [45] = 0x26 	[46] = 0x26 	[47] = 0x26 	[48] = 0x25 	[49] = 0x25
 0> *** Burst = 9 ***
 0> [50] = 0x25 	[51] = 0x24 	[52] = 0x26 	[53] = 0x27 	[54] = 0x28
 0> *** Burst = 10 ***
 0> [55] = 0x2C 	[56] = 0x2C 	[57] = 0x2C 	[58] = 0x2B 	[59] = 0x2D
 0> *** Burst = 11 ***
 0> [60] = 0x30 	[61] = 0x30 	[62] = 0x30 	[63] = 0x30 	[64] = 0x2F
 0> *** Burst = 12 ***
 0> [65] = 0x2D 	[66] = 0x2D 	[67] = 0x2D 	[68] = 0x2C 	[69] = 0x2C
 0> *** Burst = 13 ***
 0> [70] = 0x2B 	[71] = 0x2B 	[72] = 0x2B 	[73] = 0x2B 	[74] = 0x2B
 0> *** Burst = 14 ***
 0> [75] = 0xFF 	[76] = 0xFF 	[77] = 0xFF 	[78] = 0xFF 	[79] = 0xFF
 0> *** EOD detected at notif # 15 ***
Can anyone help me figuring out why I am not receiving the full no. of notifications?
I know there is ACK on link layer, is not that working? OR there is any overflow in the receiver (central)?
Please help.
    My guess is that your Burst_characteristic_update() returns BLE_ERROR_NO_TX_PACKETS() meaning your buffer is full. When it returns this, it also means that the softdevice didn't queue the packet that returned this.
    I see that you just filter out this return value. I bet that if you add the extra check like you do with BLE_ERROR_GATTS_SYS_ATTR_MISSING and NRF_ERROR_INVALID_STATE, you will see that it is printed.
    since you increase your counter, cnt++ regardless if Burst_characteristic_update() returns NRF_SUCCESS or BLE_ERROR_NO_TX_PACKETS, these packets are never sent.
    I suggest that you increase the count only if err_code == NRF_SUCCESS.
    Something like this:
       uint32_t        err_code;
    			  //cnt++;		// Next 20 byte block to send
                        if(err_code == NRF_SUCCESS)
                            cnt++;  // <-- add this
    					else if (err_code == BLE_ERROR_GATTS_SYS_ATTR_MISSING)		//Special handling of BLE_ERROR_GATTS_SYS_ATTR_MISSING
    					else if(err_code == BLE_ERROR_NO_TX_PACKETS)
    					        SEGGER_RTT_printf(0,"BLE_ERROR_NO_TX_PACKETS. Don't increase cnt++");
    		return NRF_SUCCESS;
    I also noted that you increment your counter before you start sending. I believe this means that you skip your first measurement.
    If you receive BLE_ERROR_NO_TX_PACKETS, and you want to save some battery, you can, instead of just keep trying to send until it receives NRF_SUCCESS, wait until you receive the BLE_GATTS_EVT_HVN_TX_COMPLETE event, and then continue sending notifications after this. This is described in the sd_ble_gatts_hvx() softdevice call.
    Edvin
  • Oh, what an obvious mistake I made.
    Thanks Edvin for the correction. The issue has been resolved with the following implementation of the code.
       uint32_t        err_code;
    					cnt++;
    				else if (err_code == BLE_ERROR_NO_TX_PACKETS ||
    							SEGGER_RTT_printf(0,"NRF_ERROR_INVALID_STATE \n\r");
    					else if (err_code == NRF_ERROR_INVALID_STATE)
    							SEGGER_RTT_printf(0,"BLE_ERROR_NO_TX_PACKETS\n\r");
    		return NRF_SUCCESS;
