PeerManager [1°pairing->1°NoPairing->2°Pairing without"delete_bonds()"]
I modified the "ble_app_uart" project on "nRF5_SDK_15.2.0_9412b96".
I added the "peer manager" function.
The first pairing works perfectly.
After performing the NoPairing function, it is no longer possible to perform a second pairing.
The message "peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 133" appears on the terminal.
To be able to perform a pairing again, the startup must press an EVAL button to execute the "delete_bonds()" function.
How can I solve this problem ?
See the terminal report below.
Thanks.
BR
Demetrio Magrin
static void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void peer_manager_init(void)
    ret_code_t err_code;
    err_code = pm_init();
    sec_param.bond              = SEC_PARAM_BOND;
    sec_param.mitm              = SEC_PARAM_MITM;
    sec_param.lesc              = SEC_PARAM_LESC;
    sec_param.keypress          = SEC_PARAM_KEYPRESS;
    sec_param.io_caps           = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob               = SEC_PARAM_OOB;
    sec_param.min_key_size      = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size      = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc     = 1;
    sec_param.kdist_own.id      = 1;
    sec_param.kdist_peer.enc    = 1;
    sec_param.kdist_peer.id     = 1;
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    //printf("\r\nUART started.\r\n");
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
From JLINK-RTT Viewer:
00> <info> app: Debug logging for UART over RTT started.
00> <info> app: Connected
00> <info> app: Data len is set to 0xF4(244)
00> <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 133
00> <info> app: Disconnected
00>
  • HI,
    you can refer to the example (https://github.com/jimmywong2003/nrf5-bond-with-2nd-central-example).  I enable the 2 peripheral role on the device.  if the device needs to bond with another host, need to press the button to trigger advertising without whitelist. If success, it would replace the existing host bonding record.
    Thank you for your suggestion.
    I need to be able to perform the pairing with the same device (central) without having to perform the "delete_bonds()" function that is activated by pressing the "BSP_EVENT_CLEAR_BONDING_DATA" button at the startup.
    I saw that the only way is to change the function as follows:
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Allow pairing request from an already bonded peer.
                // Note that this will enable a potential attacker to update an existing bond.
                // So there is a trade-off between security and user-friendliness.
                pm_conn_sec_config_t conn_sec_config = { .allow_repairing = true };
                pm_conn_sec_config_reply(m_conn_handle, &conn_sec_config);
    As written in the function:
    // Notes that this will enable a potential attacker to update an existing bond.
    I was wondering if there was another safer way to solve this problem.
    Thank you.
    BR
    Demetrio Magrin
  • I was wondering if there was another safer way to solve this problem.
    If you don't want any user-interaction at all when this happens, I don't see any other ways to do it.
