PeerManager [1°pairing->1°NoPairing->2°Pairing without"delete_bonds()"]
I modified the "ble_app_uart" project on "nRF5_SDK_15.2.0_9412b96".
I added the "peer manager" function.
The first pairing works perfectly.
After performing the NoPairing function, it is no longer possible to perform a second pairing.
The message "peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 133" appears on the terminal.
To be able to perform a pairing again, the startup must press an EVAL button to execute the "delete_bonds()" function.
How can I solve this problem ?
See the terminal report below.
Thanks.
BR
Demetrio Magrin
static void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void peer_manager_init(void)
    ret_code_t err_code;
    err_code = pm_init();
    sec_param.bond              = SEC_PARAM_BOND;
    sec_param.mitm              = SEC_PARAM_MITM;
    sec_param.lesc              = SEC_PARAM_LESC;
    sec_param.keypress          = SEC_PARAM_KEYPRESS;
    sec_param.io_caps           = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob               = SEC_PARAM_OOB;
    sec_param.min_key_size      = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size      = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc     = 1;
    sec_param.kdist_own.id      = 1;
    sec_param.kdist_peer.enc    = 1;
    sec_param.kdist_peer.id     = 1;
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    //printf("\r\nUART started.\r\n");
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
From JLINK-RTT Viewer:
00> <info> app: Debug logging for UART over RTT started.
00> <info> app: Connected
00> <info> app: Data len is set to 0xF4(244)
00> <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 133
00> <info> app: Disconnected
00>
