Hey everyone, I am trying to setup the external temp sensor instead of using the simulated data
I modified prj.conf to:
CONFIG_TEMP_USE_EXTERNAL=y
and Kconfig default to TEMP_USE_EXTERNAL
choice
prompt "Temperature measurement device"
default TEMP_USE_EXTERNAL
I am able to build and flash and run the program but get the following message.
ASSERTION FAIL [env_sensors[i]->dev] @ ../src/main.c:1034
Could not get device
***** Kernel Panic! *****
Current thread ID = 0x20021d5c
Faulting instruction address = 0x61166
Where in the config do I define the pins id like to use for the external sensor connected?
Thanks!
