Update advertising packet with battery level in nrf52832
Dear Sir,
I am using nrf52832.
SDK 15
soft device s132.
I need to add the battery level also to the advertising packet.
Currently I have done code to read the battery level using SAADC.
/**@brief Function for handling the ADC interrupt.
 * @details  This function will fetch the conversion result from the ADC, convert the value into
 *           percentage and send it to peer.
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
        nrf_saadc_value_t adc_result;
        uint16_t          batt_lvl_in_milli_volts;
        uint8_t           percentage_batt_lvl;
        uint32_t          err_code;
        adc_result = p_event->data.done.p_buffer[0];
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                  DIODE_FWD_VOLT_DROP_MILLIVOLTS;
NRF_LOG_INFO("saadc_event_handler = %d  \n",batt_lvl_in_milli_volts);
        percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
NRF_LOG_INFO("saadc_event_handler = %d  \n",percentage_batt_lvl);
        err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
        NRF_LOG_INFO("\n err_code = %d  \n",err_code);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
/**@brief Function for configuring ADC to do battery level conversion.
static void adc_configure(void)
    nrf_saadc_channel_config_t config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
        ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
    err_code = nrf_drv_saadc_channel_init(0, &config);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
And I  have used a timer to update the battery level each interval.The timeout handler is implemnted as follows
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 *          This function will start the ADC.
 * @param[in] p_context   Pointer used for passing some arbitrary information (context) from the
 *                        app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code;
    NRF_LOG_INFO("Battery \n");
    err_code = nrf_drv_saadc_sample();
Now I need to add this information in to advertising packet.
Can anybody help me and tell me how to do the same?
How can I see this battery value (which is sent from the device ) using some App ( like  nRFConnect/LE Scanner) in the phone?
