APP_UART never receiving data
I’m using nRF51-DK with SDK 12.3 with softdevice S130 (BLE is advertising). I would like to talk with a serial device that starts up with no HW flow control and later switches to HW flow control, after receiving a specific command. I’m using APP_UART with the following code, but:
  • The UART always displays an overrun error and it’s not able to receive any single byte either before or after the device turns on HW flow control.
  • The UART correctly transmits commands to the device (I’m actually able to transmit the command enabling HW flow control of the device).
// UART interrupt handler function
void uart_handle(app_uart_evt_t * p_event)
    //Error processing
		if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR){
				if(NRF_UART0->ERRORSRC==1) NRF_UART0->ERRORSRC=1;
				uint8_t readbyte;
				for(uint32_t i = 0; i < 6; i++) app_uart_get(&readbyte);
				app_uart_flush();}
    else if (p_event->evt_type == APP_UART_FIFO_ERROR) APP_ERROR_HANDLER(p_event->data.error_code);
    //Processing of received byte
    if (p_event->evt_type == APP_UART_DATA_READY){
			 uint8_t readbyte;
			 while(app_uart_get(&readbyte)==NRF_SUCCESS){
					...PROCESSING...}}
main(){
    // Initializes UART
    const app_uart_comm_params_t comm_params = {RX_PIN_NUMBER,TX_PIN_NUMBER,RTS_PIN_NUMBER,CTS_PIN_NUMBER,APP_UART_FLOW_CONTROL_ENABLED,false,UART_BAUDRATE_BAUDRATE_Baud115200};
    APP_UART_FIFO_INIT(&comm_params,256,256,uart_handle,APP_IRQ_PRIORITY_LOWEST,err_code);
    for (;;){...}
I tried:
  • To clear the error as displayed in the above code;
  • To comment out the IF blocks pertaining to APP_UART_COMMUNICATION_ERROR and APP_UART_FIFO_ERROR in the interrupt handler (leaving only the IF block if (p_event->evt_type == APP_UART_DATA_READY);
  • To move all processing into main, so that only the line if (p_event->evt_type == APP_UART_DATA_READY) SerialRX_EventFlag=true is left in the interrupt handler;
  • To start APP_UART with either HW flow control turned on or off.
In all cases, the result is the same: the code never completes successfully the app_uart_get(&readbyte) command.
What am I missing? Thank you for any help!
    In uart_handle() (sometimes also referred to as uart_event_handle() in the sdk example) you may just ignore the APP_UART_COMMUNICATION_ERROR event. Then you will miss overrun bytes, but otherwize work as intended. Have you tried that?
    As an example try the modified ble_app_uart example and try to overflow the UART, it will display an error, but resume operation as normal after error.
     * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "softdevice_handler.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           /**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
    #if (NRF_SD_BLE_API_VERSION == 3)
    #define NRF_BLE_MAX_MTU_SIZE            GATT_MTU_SIZE_DEFAULT                       /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */
    #define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
    #define CENTRAL_LINK_COUNT              0                                           /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           1                                           /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      180                                         /**< The advertising timeout (in units of seconds). */
    #define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_nus    Nordic UART Service structure.
     * @param[in] p_data   Data to be send to UART module.
     * @param[in] length   Length of the data.
    /**@snippet [Handling the data received over BLE] */
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
        for (uint32_t i = 0; i < length; i++)
            while (app_uart_put(p_data[i]) != NRF_SUCCESS);
        while (app_uart_put('\r') != NRF_SUCCESS);
        while (app_uart_put('\n') != NRF_SUCCESS);
        uint32_t       err_code;
        ble_nus_init_t nus_init;
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
    /**@brief Function for the application's SoftDevice event handler.
     * @param[in] p_ble_evt SoftDevice event.
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                break; // BLE_GAP_EVT_CONNECTED
                break; // BLE_GAP_EVT_DISCONNECTED
                // Pairing not supported
                break; // BLE_GAP_EVT_SEC_PARAMS_REQUEST
                break; // BLE_GATTS_EVT_SYS_ATTR_MISSING
            case BLE_GATTC_EVT_TIMEOUT:
                break; // BLE_GATTC_EVT_TIMEOUT
            case BLE_GATTS_EVT_TIMEOUT:
                break; // BLE_GATTS_EVT_TIMEOUT
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
                break; // BLE_EVT_USER_MEM_REQUEST
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                err_code = sd_ble_gatts_exchange_mtu_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                           NRF_BLE_MAX_MTU_SIZE);
                break; // BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST
                // No implementation needed.
    /**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice
     *        event handler.
     * @details This function is called from the SoftDevice event interrupt handler after a
     *          SoftDevice event has been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        ble_conn_params_on_ble_evt(p_ble_evt);
        ble_nus_on_ble_evt(&m_nus, p_ble_evt);
        ble_advertising_on_ble_evt(p_ble_evt);
        bsp_btn_ble_on_ble_evt(p_ble_evt);
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize SoftDevice.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        err_code = softdevice_enable(&ble_enable_params);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
                    err_code = ble_advertising_restart_without_whitelist();
    static volatile bool uart_error;
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' i.e '\r\n' (hex 0x0D) or if the string has reached a length of
     *          @ref NUS_MAX_DATA_LENGTH.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code=0;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                    (void) ble_nus_string_send(&m_nus, data_array, index);
                    index = 0;
                //APP_ERROR_HANDLER(p_event->data.error_communication);
                uart_error = true;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            APP_UART_FLOW_CONTROL_DISABLED,
            false,
        APP_UART_FIFO_INIT( &comm_params,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
        ble_advdata_t          advdata;
        ble_advdata_t          scanrsp;
        ble_adv_modes_config_t options;
        // Build advertising data struct to pass into @ref ble_advertising_init.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = false;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
        memset(&options, 0, sizeof(options));
        options.ble_adv_fast_enabled  = true;
        options.ble_adv_fast_interval = APP_ADV_INTERVAL;
        options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                     APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                     bsp_event_handler);
    /**@brief Function for placing the application in low power state while waiting for events.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    /**@brief Application main function.
        uint32_t err_code;
        bool erase_bonds;
        // Initialize.
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
        uart_init();
        ble_stack_init();
        gap_params_init();
        services_init();
        advertising_init();
        conn_params_init();
        printf("\r\nUART Start!\r\n");
        err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
        // Enter main loop.
        for (;;)
            power_manage();
            if (uart_error)
                printf("APP_UART_COMMUNICATION_ERROR");
                uart_error = false;
    Kenneth
  • Thank you Kenneth, that did solve the problem!
